Air Filters??
   / Air Filters?? #42
I don't know about the relative abilities of paper and oil bath air cleaners but the hassle of servicing oil bath air filters is precisely why paper elements are far superior; they're more "people proof". I don't know anybody with an oil bath air cleaner who services it as much as they should.
A sermon:
I believe that, while they're not exactly precision instruments, restriction indicators are important to prevent over-servicing. Every time you pull out the air filter you let a little dust into the engine; it's even worse if you're doing the service at a dusty worksite. Changing filters too often means that you're exposing your engines to this more often than necessary.
All that trouble light is truly good for with regard to air filters is looking for holes/tears in the element.
I can't abide cleaning air filters with compressed air. You can put small tears or holes in the filter paper and, with dust blowing everywhere, some will get into the filter's clean side. If this is done near the filter box then even more harm is done.
The temptation to use compressed air is always there. I was in one rock pit where the primary filters lasted a few shifts and the there was a compressor on the service truck.... Fight the temptation and eat the cost of replacing them, add a pre-cleaner or have them professionally cleaned; up here in Canada, Finning offers filter cleaning services.
Tagline idea: Toilet paper bypass filters take the **** out of your oil.
   / Air Filters?? #43
Thinking back a bit, there was a outfit back in the 60s made this machine for cleaning paper air filters. Of course that was back in the days when a buck was a buck and a candy bar cost a nickle and people still fixed things rather than just replace them.
I remember dirst truck I ran with a paper filter thing hanging on the fender, that sucker was the size of a trash can and had this little dial indicator gizmo on it so the driver could tell when the filter was dirty. Whoever came up with that indicator should have been took out and horsewhipped. Onliest way a driver could see if that thing was red or green was if he stuck his face up against the windshield and craned his neck. Why they didn't put the thing on the dash is way beyond me.
Tell you something else any driver who can't tell when his air filter is dirty ain't a driver he's a steering wheel holder. Good lord when you're running 1 or 2 gears lower than what you should be toget up a hill first thing you know is the engine ain't workin proper.
I went to carrying a spare air filter in the sleepercab after first time I got caught out on a job in Nevada where the sand was blowing so bad I had a bandanna across my face so I could breathe comfortable. Dang fine sand dust gets into everything.
Now ike I was saying, I think it might have been in one of the PIE barns where I saw that cleaner machine. They had them a cabinet with what for all the world looked like the guts of a paintshaker like the hardware store has and a blower and a vacuum cleaner all hooked up. They put the filter in there and there was clamps that held 2 ends on the filter. When you hit the swiitch the filter went to shaking like a wet dog, and the blower blew air into the filter while the vacuumcleaner sucked on the whole box carrying off what came out of the filter itself. Fellow there showed me how it worked, and said they got about 3 times the life out of filters using it. Made sense figuring the territory PIE ran in.
I suppose a fellow could make up a plywood box and get himself some sort of vibrator to do the shaking, after all youwouldn't need to shake a tractor filter as much as a truck filter. I figure a sawzall hooked to a shaft just might handle the shaking part given the way a sawzall will rattle your cage if the blade gets hung up. Best not try using the sife's good vacuumcleaner though, them wimmen get right riled about that sort of thing.
   / Air Filters?? #44
(removed),thank you very much for your trucking memories-very cool.I still remember Pacific Intermountain Express,then Ryder/PIE.Been awhile though.Thanks again for sharing.
   / Air Filters?? #45
Never looked into the truth of it, but I was told PIE reinvented the road tractor to pull the mountains back in the 40s & 50s. They put huge compressors on their tractors with a pair of tanks mounted on the back of the cab so they had enough brakes to stop going downhill. I recall quite a few of their tractors were also air starters. If you parked next to one of them at a truckstop I could count on that dang thing winding up like a siren in the morning. They also had mostly cabovers with a real squared off cab.
I was hauling for a company that carried heavy loads mostly power transformers so I got all over the country. Mostly I hauled East of the Big Muddy though. One thing for sure we might have worked harder back then but those were better times fortrue. I see the equipment today and can't hardly believe some of what I see. Back in 1950 if you'd have told people a driver would pitch a hissey if his rig wasn't air conditioned people would have laughed at you.
   / Air Filters?? #46
Kubota B2910 Inner (left) and Outer (right) air filters:
   / Air Filters??
It's an Option, when I asked my dealer about it, I was told that I didn't need it. The reason I changed my air filter (2x) was the fact that I used my tractor a bunch building a couple of roads and it was very dusty. Now that the roads are done... I'll be changing my tune instead of air filters...
Well, I bought both of the filters...
I put in the single outer...
I might put the other one in if it will work....
whatcha think of this nasty filter?
J
   / Air Filters?? #49
My L5030 has both inner and outer, I just don't change the inner as often.
   / Air Filters?? #50
Well, I bought both of the filters... I put in the single outer...
J
So, did you buy the inner filter, too?? (yes, you guessed it... I need a Photo!!! even a blurry one :D)
That dirty filter was about what mine looked like...
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
2014 Ford Fusion Passenger Car, 2.5L Engine - Only 90,875 Miles (A56438)
2014 Ford Fusion...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
