B2320, B2620, and B2920
   / B2320, B2620, and B2920
The engine on the B2920 is larger (77 cu in v.s. 68 cu in) than the engine on the B2630. I think it is not physically larger, but uses a longer stroke.
   / B2320, B2620, and B2920 #72
SnowRidgeME said:
Well I tried a B2920 today! Very pleased! I found my tractor. The engine is smooth running, not as loud as the 2630's, comfortable seat. The sales person hadn't tried it yet either until today, he was impressed, big competition to the JD 2320 was his words, big improvement to the 7610. Only odd design is in regards to the PTO. The selector for selecting Neutral, 540, or mid PTO is also the same lever to engage, i.e., no longer two levers. The clutch needs to be depressed to shift from Neutral, 540, or mid (2500). Also, when the mid is on, the rear is also on rotating at 960RPM, kind of strange for that speed. When the clutch is depressed the PTO stops. Since it is an HST, only time clutch is pressed is to select/engage PTO and to start the tractor.
am I reading this correctly clutch on HST??
   / B2320, B2620, and B2920 #73
bandit67 said:
If the mid and rear run together and there's no way to control each independently, then that would be another step backwards for me (I already had live independent PTO on the sub). I'm not taking steps backwards to move up to a bigger machine.
Elsie71 said:
I'm not sure this is a step backwards, but certainly not a step forward.
What I meant was that this would be a step backwards from my subcompact. I am not moving "up" to a bigger, more expensive machine with less features, or that is lacking features, that I want and already had in a previous "lesser" machine.
   / B2320, B2620, and B2920 #74
Just a quick question... how did you guys find out this business with the mid and rear PTO running together? I've not heard a thing about it. It does seem strange, as they've not done tractors like that in the past. I do know alot of people would really light a higher RPM rear PTO, but I see the point that there are times that you would not want to have it running. The L's are all like that also.
   / B2320, B2620, and B2920 #75
Messick's - I can't tell from the photos of the new tractors that are available on this site, but I think that the only choices for the PTO control are high, neutral and low like my old B7100. I hope I am wrong on this. Could someone check a B7510 or a B7610 to see how they operate? As I said, when I put the PTO on high on my 7100, the rear PTO runs at the higher speed and the mid PTO runs as well, and the high speed has to be on to run the mower.
   / B2320, B2620, and B2920 #76
I tried a B2920 this past weekend, the PTO choices are 540 where just the rear turns, neutral, or 2500/960 where the mid pto runs at 2500 and the rear simultaneously runs at 960. The clutch needs to be depressed to stop the PTO and allow one to change the selector.
MessickFarm, what do you mean by 'The L's are all like that also'?
   / B2320, B2620, and B2920 #77
The B3030 with the 72" mower is a drive over. I just use the FEL. Its much faster than blocking the mmm wheels. The 60" is not but that may be small enough to slide out.
   / B2320, B2620, and B2920 #78
Got some pricing from the local bota dealer on some new units.
I WILL HAVE SOME B2620 MODELS ARRIVING SOON IN MY INVENTORY, THE MSRP ON THIS UNIT IS $12,488.00, SELLS FOR 11,200.00, THE 2920 TRACTOR
WILL SELL MSRP FOR 13,353.00, SELLS FOR 11,975.00. LOADERS WILL SELL FOR 2,460 FOR 2320, OR 2,820.00 FOR LOADER ON 2620. MOWERS ARE SELLING FOR $1,955
   / B2320, B2620, and B2920 #79
msiewert96 said:
THE 2920 TRACTOR
Could you or anyone find out what the MSRP for the BH65 is?
(INOP) VOLVO L110H WHEEL LOADER (A50459)
(INOP) VOLVO L110H...
72in Rock Bucket Skid Steer Attachment (A50322)
72in Rock Bucket...
2017 Honda Civic (A50324)
2017 Honda Civic...
2007 CHEVROLET SILVERADO 4X4  DUALLY TRUCK (A51222)
2007 CHEVROLET...
2024 Ford F-350 Super Duty XLT FX4 - Like-New, Loaded, Only 780 Miles (A52128)
2024 Ford F-350...
Toro Sprayer Cart (A50324)
Toro Sprayer Cart...
