Bad news big repair
   / Bad news big repair #181
I have bought multiple new tractors from them, but I am well past 3 years. It’s a 2010.
Make a call or send an email message to the customer care dept. of Kubota. They have answered even to my question although I'm located on the other part of globe. Tell them your situation, I don't believe they won't help.
I'd think after 19 pages you'd figure out the answers you want aren't here.
Actually it would be just the opposite. I’m hoping there will be a few others who think outside the box. A few suggestions were submitted to repair the ECU. My own thought that the plug could have corrosion and other suggestions.
Rick, Sometimes it takes more than a few days for respondents who know more than the ”wire up a switch” technique, which is an obvious easy way out and has been insisted by you in your 12-15 posts. I could have done last year with wire and a relay in my shop. It works, but I don’t prefer that way because I’d rather fix the factory system, which you obviously don’t get.
But then again, a plug-in block heater has been suggested a dozen times, too, even though its known I don’t have winter access to electricity.
   / Bad news big repair #183
Sometimes it takes more than a few days for respondents who know more that the ”wire up a switch” technique, which is an obvious easy way out and has been insisted by you in your 12-15 posts and I could have done last year with wire and a relay in my shop.
"So I’m out of answers. Any thoughts on other possible avenues to pursue?"
That's a copy and paste from your post #1. So don't tell me what you prefer. Just get busy and fix it. Check all those connections, ohm out the relevant conductors, take all the suggestions others have given and figure it out. Or take it back to the dealer and tell them to do all that and replace the ECU if necessary.
Did you call Ag Express today to see if they could test or repair that ECU like I suggested privately?
   / Bad news big repair #184
The old diesel engines never had glow plugs. We used to stuff a newspaper up the air intake and set fire to it. The hot air works better than any glow plugs.
So get busy and fix it. Check all those connections, ohm out the relevant conductors, take all the suggestions others have given and figure it out. Or take it back to the dealer and tell them to do all that and replace the ECU if necessary.
Did you call Ag Express today?
I have. Last year and this year. Everything checks out that I can test as well as a kubota dealer.
Chill out man.… Just because I already know about an easy fix back a year ago, you don’t have to get so angry. Everyone knows the wire up a switch method to the GPs.
Im hoping for help/suggestions to get the factory system working again. It may not happen, but that’s why I’m asking. To eliminate any other possibilities. There’s a lot of smart people here. I have already been PMd by a few with some good suggestions other than yours.
   / Bad news big repair #186
I like keeping factory oem crap the way it is also but if the factory gives u free KY jelly for $6000. Then have at it. Like the $20 relay and diode option
Agree.
The $6000 solution was offered by the dealer, not me.
That’s why I posted the thread, to see if there’s something the dealer and me haven’t thought of. No way I’m spending $6000 on an ECU.
I didn’t know if the ECU could be repaired or if there’s something I overlooked, like corroded wires to the ECU.
Going to check for corroded wires next week. Once that’s done, the only thing left is a bypass homemade system.
Another largely undiscussed issue is this could just be the beginning of problems. The ECU could begin to lose other vital functions, so just wiring up a switch could be the least of my worries.
   / Bad news big repair #189
Funny, yesterday you said you needed to check the ECU connection for corrosion. That's an excellent thought. Maybe if you ever get over your blind indignation about me still walking around and breathing you'll look at it. You might want to go back over yesterday's activity here and actually do some of the stuff you said needed doing.
I'll answer your PM here. You came out of the gate today attacking me for a factual non confrontational post (which I immediately provided actual substantiation for). You then insult your own intelligence by asking why I am angry? I simply have a low tolerance for people that change their version of reality based on what day it is.
   / Bad news big repair #190
He's PM'd you as well huh...did it go like this...
   / Bad news big repair #191
Purchased my M135X in warmer months almost 3 years ago (April 2019). Never thought to see if the glow plugs worked. They actually won’t work if it’s over 41*.
Last winter, I realized the glow plugs weren’t working. Ohmed out wires, looked at wiring for mice damage, water damage, bad grounds, etc. Ohmed out wiring. Thats when I learned the glow plug system in larger kubotas is more complex than I thought. All 4 glow plugs passed electrical testing.
The glow plugs have 2 sensors one for air temp, one for water temp. The ignition switch is also part of the circuit. Then there are 2 relays and a fuse. All of this is controlled by the ECU. Last winter, I replaced
Key switch
water temp sensor
air temp sensor
both relays
fuse
Still no glow plugs. With nothing left to replace or test, I succumbed to a very reputable Kubota dealer. They basically did all the same things I did and replaced one of the new sensors I had already placed.
Still nothing. They called Kubotas double secret probation hotline and Kubota thinks it’s the ECU.
ECU price $6000 :(
ECU Not returnable and no guarantee it will fix glow plugs.
Can you put in a block heater? I'll bet they are less than a $100 and are a better starting aid.
Not when the tractor sits out in fields and is used to load spreader. Which is for about 2 months in late fall/winter. No access to power.
I did. Theres corrosion.
Feel better?
Unsubstantiated and undocumented fears of an engine derate.
Fear of an electrical fire cause by installation of an alternative glow plug control circuit.
Thats 2 and all the time I'm going to waste on you right now. My BS tolerance is low today.
BTW, if you can't run a couple wires and a switch without burning your tractor to the ground you might want to have someone else handle the troubleshooting and repair.
Going back on your promise, RickB?
   / Bad news big repair #199
Then should be a bar that bolts to the top of the glow plugs. Disconnect their b. s. and run +12v to that bar threw a switch. You just need to be a responsible, big, boy and remember to turn it off. Isn't it pitiful that a simple glow plug to heat cylinders turns into an electrical nightmare? Everything designed for dummies these days, that's why we are getting dumber.
BLUE DIAMOND HYD 16" SERIES 2 COLD PLANER (A60429)
BLUE DIAMOND HYD...
CAT 312C EXCAVATOR (A58214)
CAT 312C EXCAVATOR...
2025 GPS Trailers (A56857)
2025 GPS Trailers...
2015 Ford F-350 4x4 Ext. Cab Pickup Truck (A59230)
2015 Ford F-350...
7ft Pull-Behind Rake Tractor Attachment (A59228)
7ft Pull-Behind...
2474 (A60432)
2474 (A60432)
