BX22/23/24 Owners...Regrets?
   / BX22/23/24 Owners...Regrets? #11
I''ve owned mine 4 years, 300+ hours, no regrets. It was perfect for my previous property and is still perfect for many of the tasks at hand here.
My plan, if financially possible, is to keep it and add a larger tractor, preferrably a L5030, although I may go with a L3830 or L4330 and spend the difference on hydraulics & implements. I do have needs for which the BX is really too small, but for what it does, it does it all very well and a larger tractor would not be nearly so flexible. Most large tasks just take more time with the BX. I am getting into fencing, cattle, goats, and large areas to bush hog (rough ground) among other future plans, so I really need a larger tractor. For mowing, light loader work, backhoe, tilling, 4ft bush hog work, and getting into tight areas to do work, it is great. A large part of wanting to keep it is to not be without a backhoe. I don't use it often, but nothing like having one when you need it and I have some projects like water and electric lines that it will perfect for.
Terry
   / BX22/23/24 Owners...Regrets? #12
Terry
   / BX22/23/24 Owners...Regrets? #13
Just turned 150 hrs on a BX23 and the only regret I can think of is that I should have went with turfs. This spring has been extremely wet and the bars are "marking" some spots in the low land.
Spent this past Memorial Day weekend finish mowing a couple acres, planting trees & shrubs, moving compost & mulch around and other general yard maintenance and this machine was in it's element.
And it's the best mower I've had also, which is it's primary duty.
Volfandt
   / BX22/23/24 Owners...Regrets? #14
Volfandt
   / BX22/23/24 Owners...Regrets? #15
I've had my bx24 for about a month now. I have a 5+ acre lot with about 1 acre that I mow with the 24. I love it !
Just spread 8 yards of mulch on Monday with the FEL, have leveled a couple of spots that were always a problem with mowing, used the BH to dig out a couple of stumps that I had been mowing around for years, and have all kinds of projects planned including a small garden pond.
I use a 54" mower as there are some areas with trees that anything larger would cause problems getting through. The mower does a much better job than my old Wheelhorse tractor did. The lawn never looked better ! I had the mulching kit put on and have yet to see a clump of grass. No bagging, or raking for me !
I have only ripped down the clothseline once as I rolled through the middle forgetting about the ROPS and ran into the top of the garage once.
There are a few lower limbs on a couple of trees that I need to trim due to the ROPS, but overall the agility of the 24 outdoes the old Wheelhorse. I was figuring I would have a lot more weedwacking to do with the larger tractor, but actually have a little less.
Would I make the purchase again? In a flash !!!
   / BX22/23/24 Owners...Regrets? #16
   / BX22/23/24 Owners...Regrets? #17
~16 months, 650+ hrs. Zero regrets.
   / BX22/23/24 Owners...Regrets? #18
   / BX22/23/24 Owners...Regrets? #19
I have had my BX22 over two years. And no regrets it is the best thing I ever bought. I use it almost everyday for something. I could somtimes use a bigger machine but then most of the time a bigger one would not fit where i need to go like horse stalls and back yard. I would buy another one.
465 hours and nothing has broke except the silly air filter strap which they all did/do.
   / BX22/23/24 Owners...Regrets? #20
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
FIAT ALLIS FD145 CRAWLER DOZER (A52707)
FIAT ALLIS FD145...
2004 Ford F-250 Liftmoore 2,700 LB 1 Ton Crane Service Truck (A53422)
2004 Ford F-250...
BUSH HOG 2820 LOT NUMBER 125 (A53084)
BUSH HOG 2820 LOT...
2007 Freightliner B2 School Bus (A55852)
2007 Freightliner...
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
