BX24 rear remotes/hydraulic top link
   / BX24 rear remotes/hydraulic top link #41
Renob good looking job. You will find lots of uses for the rear remotes.
Scott
   / BX24 rear remotes/hydraulic top link #42
Renob said:
Well it's done and it actually works. Thanks all for the expert advice.
Thanks for posting the photos.
A source of inspiration for others.
   / BX24 rear remotes/hydraulic top link #43
How would I go about ordering your kit for a BX-24 ?
Whatever1,
Are you asking me or Messick? Most of the sources for parts that I used are contained in this thread.
Most parts came from Surplus Supply. If you go the route I did, using the Backhoe ports, you need to get quick connects from kubota.
   / BX24 rear remotes/hydraulic top link #45
Surplus Supply has quick disconnects that fit my BX23. The BX24 probably use the same size. P/N 9-1626 top of page 58 in the 2007 catalog $13.49 each.
ron
   / BX24 rear remotes/hydraulic top link #46
ron
Ron, thanks for the helpful link and part number - that's much appreciated.
   / BX24 rear remotes/hydraulic top link #47
This is not a BX, but here is how I did it. Puts it a little more where you can use it easier. TnTOne.jpg
   / BX24 rear remotes/hydraulic top link #48
Forgive my ignorance, but isn't my bx2200 the same as a bx24 without the backhoe and therefore just missing the fittings for the backhoe? I can't imagine that it would be that easy. However, I have not looked that closely at a bx24,23, or 22 so I'm not sure. If someone knows the answer I would appreciate it.
Also, if all I need to do is add fittings to my bx2200 could someone with a bx24 post some pictures of the fittings so I can find where to add them to mine? I would love to add remotes without messing around with my loader and you guys with the backhoes came up with a great setup. Thanks for any input. - Toby
   / BX24 rear remotes/hydraulic top link #49
You might try Tractorsmart.com for a parts manual on the BX23 and compare the difference between the BX23 and your 2200.
ron
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
2017 Liebherr L566 X Power Articulating Wheel Loader, PIN# VATZ1484EZB044020, Liebherr Turbo Diesel (A59076)
2017 Liebherr L566...
John Deere 4820 Forklift (A57453)
John Deere 4820...
TUGGER TRAILER (A58214)
TUGGER TRAILER...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58216)
2008 TEXAS BRAGG...
INOP Mitsubishi MXR55 Mini Excavator (A57453)
INOP Mitsubishi...
