Constructing new 36x40x12 Pole barn
   / Constructing new 36x40x12 Pole barn #31
I had mine put up by CHUPPS Builders (Amish crew out of Apple Creek/Holmesville area) that is South of chardon 40 or 50 miles but probably well in their driving distance. I am heading out to do some work for their brother this weekend. I dont have the builders phone number anymore but was real good with best quality materials thru amish hardware place in Kidron Ohio. https://www.lehmans.com/
This is a pic of my barn (click it to see progress of over 100 photos) this was just after they finished my place in 2002 and cost me 20K they provided everything to that point including man doors and roll up door. It is 50x50 11 foot 1st floor and 11' 2nd floor. the 12' leantoo off one side. PM me and I can give you his brothers phone number (Amish down there have cell phones.) and he should be able to get his brothers phone # for ya.
(click pic it to see progress of over 100 photos)
Note concrete I had done in 2011 by Amish crew was GREAT Ron Weever, (very busy but did really great job.) cost me 7800 for 60 yards of 6000PSI mix with fiber, I did under layment-insulation & mesh & in-floor radiant tubing myself. I have his # for if when ya want to go that way. He is out of Holmesville area as well.
Mark
   / Constructing new 36x40x12 Pole barn #32
Spiker, that Bobcat looks like the one they used here.
   / Constructing new 36x40x12 Pole barn #33
Murph did you have Chupps do some work too? There job has held up real well I done a lot more to the barn in years since then. Removed and rebuilt the stairs for one as I didn't want what the provided as it took up space where I needed it. Made a L shaped set using the old stairs and new platform w some new low steps.
I like the siding but think it would have been better as Metal after the fact for Roof but Wood Siding was much easier for installing windows and doors after fact. Will probably add vinyl siding to that thing someday soon.
Mark
   / Constructing new 36x40x12 Pole barn #34
I had J&M build it but they are from the same place. My Amish came from Fredricksburg. They don't have the cell phones in their name but own them.
   / Constructing new 36x40x12 Pole barn #35
I just priced a pole shed for a customer of mine, came to about $28 per foot including labour, materials, steel siding & roof, compacted gravel pad, doors, the whole package.
Having built them before, I don't understand how anyone could build one in 2 days.
Day 1 - set posts in concrete
Day 2 - everything else
Just doesn't add up to me neither in theory or practice. To have enough guys to try to get it done in 1 day, you'd be tripping over each other
I've done 30 x 50 Cover-All buildings in 2 days with 2 guys but that's a whole different game.
   / Constructing new 36x40x12 Pole barn #36
Don't set in concrete, they set the poles on concrete cookies then place poles.
   / Constructing new 36x40x12 Pole barn #37
Is the cookie purchased pre-made or just a footing poured in the bottom of the hole before setting the post? Never heard of them up here
   / Constructing new 36x40x12 Pole barn #38
yes. premade. after framing they pour the floor.
   / Constructing new 36x40x12 Pole barn #39
These cookies are available all pre cast in several sizes and grades. Mine were 18" x 8" of 6000psi fiber added design. The holes were 36" and 4~5' deep initially and dirt removed bottom compacted some and the cookie tossed in. The Amish boys used the POST (6x6x14~28') to flatten the concrete cookie into the bottom of the hole like a hammer! They picked them up and dropped them onto the cookie 10 or 15 times each to set the cookie into bottom of hole so it could not move during back-filling. They back filled the holes with crusher run (I provided gravel on-site) and dirt out of the hole. They compacted the crush-run gravel and added clay cap on top & compacted it more. I went back over the posts after they finished using spud bar and added some Portland cement to top of each post & spud bar tamped that in. That left me with a rounded humped up area HIGHER than the surrounding area so water sheds away from the posts.
here is pic of what SOME of the posts looked like, this one shows where I put in threaded rod for mounting beam/bender after concrete was put in. It is actually dug down and dirt removed and mixed in 3pt mixer to make a larger high psi mounting point for a car lift someday...
(click pic for full size pic.)
I think somewhere in the photos shows some of the landscaping around the barn to move water away from it. I also used 4" tile around the barn and plastic to move it farther away underground. My posts should be really dry for 50 years or more...
Mark
When I wrote of concrete cookies, I was speaking of a poured in hole footing made of concrete. I never even thought of looking into a pre cast footing. At 24 in round and 8 in thick ill bet they would be heavy. I suppose I could transport them to each hole with my fel,the slide them in and beat them into place. Might be wothwhile not to have to worry about trying to get a mixer truck to each hole in mid spring when ground is soft.
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
2020 KENWORTH T680 SLEEPER (A59904)
2020 KENWORTH T680...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
CAT 930M (A58214)
CAT 930M (A58214)
1994 JAGUAR XJ-SERIES (A58214)
1994 JAGUAR...
