Creating a Lake
/ Creating a Lake
Sorry, I should have said. The tracks are of two deer. You can't see from the photo, but there's also racoon, squirrel and bird tracks.
/ Creating a Lake
It's been 7 months since I've worked on building my lake. I sort of got distracted buidling my house. /forums/images/graemlins/grin.gif
My parents are visiting and my Dad just loved running the dozer and clearing brush. He's not much of moving dirt, but he's perfect for what I need him to do.
Previously it was so wet in this area that I couldn't get the dozer in there, so I started at the top and was working on my keyway. Now, everything is dry and I can concentrate on clearing and burning.
Here's a pic of my Dad on the dozer clearing an open area for a burn pile.
Eddie
/ Creating a Lake
The dozer goes through just about everything!!!!
Eddie
/ Creating a Lake
Then he piled the brush and trees up nice and tight.
Eddie
/ Creating a Lake
It didn't take much to start the fire with all the small stuff that we're taking out. Mostly it's a tangle mess of sapplings, willows and bottomland vegitation.
Eddie
/ Creating a Lake
With a clear area around the fire, it's allot easier to clear brush and add it to the fire.
Every tree and bush in the background will have to come out and burn.
Eddie
/ Creating a Lake
This pic shows the location of the dam. On the right will be the lake. The trees on the left will remain.
Eddie
/ Creating a Lake
While my dad if operating the dozer, I'm on the backhoe taking out the trees that don't pop right out with the dozer.
Lots of people tell me you can take out any tree with a dozer, and I agree, but I can get the bigger trees out faster and easier with the backhoe.
So while my Dad is doing the bulk of the clearing, I'm going from big tree to big tree, laying them down.
Eddie
/ Creating a Lake
Sometimes two trees grow together so tight you have to take them out at the same time.
Eddie
/ Creating a Lake
Once they drop, I clean off the root balls with the teeth on the bucket so they will burn a little better.
Eddie
/ Creating a Lake #131
still looing great!!
I was thinking about your dam the other day - I thought you put it onhold for you new house - so I was right (I guess right every other year)
/ Creating a Lake
Thanks Holzster, I have a bad habbit of not finishing a project before starting another one. True to form, the house isn't done yet either. /forums/images/graemlins/grin.gif
Not allot of change, just more open dirt and fewer trees.
Eddie
/ Creating a Lake
We kind of started in the back corner of where the lake is going to be, and cleared enough room to start the fire. Then it's been a matter of clearing in a bigger circle working our way out.
As the opeing gets bigger, so does the fire. I'm trying to keep the fire long, thin and low to keep it under control.
Eddie
/ Creating a Lake
Too many suprises today. This tree should have pushed right over after I cut the roots, but it snapped instead. Something I'd prefer didn't happen. /forums/images/graemlins/shocked.gif
While digging out a stump and some brush, a possum tumbled out of the bucket. I was so suprised to see it fall out that I didn't even reckognize it. I thought is was a white bunny rabbit at first with a weird tail and no ears. /forums/images/graemlins/blush.gif
While pushing over a tree, a rat ran out from the roots to another tree that I'd already pushed over.
While cutting the roots of a tree, I pulled up the body of a small snake out, minus it's head. It was black with a white belly. Pretty sure it was a cotton mouth. /forums/images/graemlins/frown.gif
Plus an untold number of roots that snap out and fling a shower of dirt clods in my face. /forums/images/graemlins/grin.gif
Eddie
/ Creating a Lake
Things were going good for too long. Murphy decided to make an apperance.
One of the pins that hold the rake on the dozer fell out. The rake came off the blade and twisted. The steel on the rake is an inch and a half thick, so it don't give much. The brackets holding it on are one inch thick. They broke off.
After looking around for a couple hours, my Dad found the missing pin.
Eddie
/ Creating a Lake
This in one of the brackets to hold the rake on. I've ground off the old welds and smoothed it out.
Eddie
/ Creating a Lake
Here I am grinding the welds smooth on the dozer blade.
Eddie
/ Creating a Lake
Ready to weld.
Eddie
/ Creating a Lake
All welded up.
Eddie
/ Creating a Lake
Since it broke, I decided to strengthen it some . I found this piece of 3/4 inch scrap lying around. I cut it in half and put each piece on the inside bracket. The outside bracket will just have to survive on it's own. /forums/images/graemlins/grin.gif
Eddie
2014 GMC Yukon SUV (A61574)
2014 GMC Yukon SUV...
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
Towable Road Crossing / Pipe Bridge Trailer (A63689)
Towable Road...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
iDrive TDS-2010H...
