Cutting 4x8 sheets
   / Cutting 4x8 sheets #12
Track saw is the bomb for cutting down sheets of plywood...
Buy a good brand, NOT some Chinese copy though!
SR
   / Cutting 4x8 sheets #14
Look for a used panel saw. It makes cutting large sheets a 1 man operation and is much safer.
I bought a used Dewalt panel saw for $400
Milwaukee panel saw
Or use this idea and make a version of your own, Homemade panel saw
   / Cutting 4x8 sheets #15
Are you cutting plywood every day, once a week or just a few times a month? I tend to cut plywood several times a year and can go months at a time without having to cut it. Depending on what I'm doing, most of the time I just lay it across the sides of my truck bed and cut it with my cordless circular saw. If I'm building a cabinet or something that needs more accuracy, I use my portable Bosch table saw with 5 rollers set up around it to support the sheet of plywood as I'm cutting it. Once I'm set up, I can do this by myself quickly and easily. When I finally build my big workshop, I'll probably build a table to go around my table saw to support the plywood and double as another counter to work on. I've always wanted a panel saw, I think that would be the best tool for the job, but I've never actually used one and don't want to spend the money on getting one. Can you rip strips of plywood an inch wide, 8 feet long on a panel saw? What about a track saw?
   / Cutting 4x8 sheets #16
   / Cutting 4x8 sheets #17
I have a Dewalt track saw. Works pretty good and less expensive than the Festool.
Thanks for all your replies. I am looking for something more efficient then a circular saw a guide. I've considered a track saw but it's not much better. I want something that I don't have to measure every cut. I like the idea of a panel saw and that's basically what I would like to build. Any thoughts on my design?
Here is a pretty nice homemade one. I only need to be able to crosscut not rip though. I would also make mine steel frame. And mine would be running on proper ball bearings. DIY panel saw - 2ManyProjects
   / Cutting 4x8 sheets #19
Your thread got me looking around the Internet for home made panel saws. I saw that one and a few others that looked pretty good. There was also a commercial made kit with all the hardware including a polycarbonate mount for the saw.
https://youtu.be/tVubVWzgm_s
That one starts at $259 US, You supply the saw and wood to construct the frame.
*Selling at Royal Auction Zephyrhills, FL Location* 5 (A59228)
*Selling at Royal...
Amada M-3060 Mechanical Metal Shear (Japan) (A59213)
Amada M-3060...
SKID STEER ATTACHMENT AUGER (A58214)
SKID STEER...
JOHN DEERE 772GP MOTOR GRADER (A58214)
JOHN DEERE 772GP...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
208315 (A58376)
208315 (A58376)
