Did a 1969 JD400 backhoe/loader have a dead end block?
   / Did a 1969 JD400 backhoe/loader have a dead end block? #1
jjarmstrong47
JD400 backhoe and David Brown 885
I want to take the backhoe off of my 1969 JD400. According to the manual that I have there should be a dead end block to plug in the main hoses and the plugs from the block are then used to plug the loader sockets.There doesn't seem to be a dead end block on this machine and I'm guessing that it might have been removed when the roll over cage was fitted. Was there one on the 1969? I know they had them by 1972. Should I perhaps just try fitting caps on the hose ends? Any advice would be appreciated.
   / Did a 1969 JD400 backhoe/loader have a dead end block? #2
JD 400 has closed center hyd system. When removing backhoe just remove & cap pressure & return hyd hoses separately that attach to BH control valve.
I have many yrs of experience with JD closed center hyd systems BUT limited experience with JD industrial models. I've never heard of a "dead end block" for closed center hyd's before now but I think you're referring to a AU40722(item 5).
Thanks, Jim. That's what I thought would be the way to go. The manual you sent me is for a 72 model and it shows a block with two plugs that you remove and plug into the loader and plug the hoses into the block. The only advantage I can see is that you have plugs to use on the loader but they are probably available from my local hydraulic dealer. Number 5 does look like what is shown in the manual.
   / Did a 1969 JD400 backhoe/loader have a dead end block? #4
You're welcome & good luck with your BH deleting.
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
LMC 6' SOIL CONDITIONER (A59823)
LMC 6' SOIL...
Case IH 330 Turbo Till (A59814)
Case IH 330 Turbo...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
iDrive TDS-2010H...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
