DR Fence Trimmers - 3PT/PTO Driven - Comments?
   / DR Fence Trimmers - 3PT/PTO Driven - Comments? #1
rmonio
Platinum Member
New Market, MN
JD 4600, JD B
I am looking at buying one of these units for my JD 4600 to be used on my PVC (Gardner Fence) Horse fence that I have on my property. Does anyone have any experience with these units and will they work reasonably with the PVC fence, etc? Any help would be appreciated.
Thanks!
-Bob
   / DR Fence Trimmers - 3PT/PTO Driven - Comments? #2
I don't have experience with that type of fence but I do have a DR fence mower and it is useless for me. My lowest wire is lower than the DR can trim under due to the string head/hub underneath. My fault for not catching this but buyer beware.
   / DR Fence Trimmers - 3PT/PTO Driven - Comments? #3
If you have that much fence to trim you should consider buying a weed badger with the mowing head as it uses a low voltage limit switches to control the mowing heads ability to come close to fence posts. it will cost you more money but you will be able to weed along the fence line with the same attachment simply by exchanging the the mowing head with the weeding head.
   / DR Fence Trimmers - 3PT/PTO Driven - Comments? #4
The large diameter string that the dr has will destroy the pvc posts. I bought the tow behind one it works but not very well especially if your on a slope, I see they stopped selling it, i went back to a weed eater and wear a harness, that works better.
   / DR Fence Trimmers - 3PT/PTO Driven - Comments? #5
The DR was never what it was cracked up to be.
   / DR Fence Trimmers - 3PT/PTO Driven - Comments? #6
Any reason not to just round up under the fence?
   / DR Fence Trimmers - 3PT/PTO Driven - Comments? #8
I use weed and grass killer on the fence posts that I can't see from the house and weed eat the rest around 250 posts a few times a year. My thought was the dr would cut my time, it didn't, I think all the dr stuff is junk.
   / DR Fence Trimmers - 3PT/PTO Driven - Comments? #9
I have their walk behind brush mower with a Kawasaki on it and it is a good piece of equipment. But the under fence mower, no so.
   / DR Fence Trimmers - 3PT/PTO Driven - Comments? #10
So would your lowest wire allow a Wright Fence Mower to fit under it?..."The bottom wire, board, or pipe should be at least 7 inches from the ground for clearance."
Fence Mowers
Case IH 875 Disc Ripper (A59814)
Case IH 875 Disc...
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
Deere 335P (A53317)
Deere 335P (A53317)
1976 East Dump Trailer (A59814)
1976 East Dump...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
PowerBoss Admiral Plus 38C Ride-On Floor Scrubber/Sweeper (A59228)
PowerBoss Admiral...
