First decision: CUT vs construction backhoe
   / First decision: CUT vs construction backhoe #41
I understand some industrials have inching clutches (mine does but, it hasn't worked from my first day of ownership)
Do any tractors have inching clutches?
I don't know of any tractors that do, but some true TLBs have an inching function that you use to move the tractor forwards or reverse very lowly when you are sitting with the chair reversed in the backhoe position. It's handy & keeps you from needing to turn the chair back around to move a foot or two.
Our JD310SG TLB doesn't have it, not even sure if it is an option on the SG. The Kubota M59 does have the inching function and it works fine. Funny thing is that it isn't even mentioned in their sales brochure at the time. I had to look at the operator's manual to see what that lever did. I didn't know it had that function when we bought it.
For those saying, "What's an inching function?" It's just a lever you can reach easily without having to turn the chair back around from the backhoe position. Mechanically it isn't anything extra in the drivetrain. It tends to be a series of cables that advance the throttle just a little bit while simultaneously engaging the transmission... Notorious for getting out of adjustment and tricky to adjust. I bet your JCB is just out of adjustment because if the tractor works, the inching function almost has have the potential to work too.
rScotty
   / First decision: CUT vs construction backhoe #42
Maybe I'm using the wrong word for it (though I think it's what I was told it was)
In my case, I have a full fledged "clutch pedal"..... I was wondering why I had this clutch but the clutch didn't stop the machine!
I was told it's an inching clutch.... "the way I understand it" is...
If you are for example loading material into a dump truck, you want to get close to the truck so you can dump but not SO close, you ram into it. So you can apply the inching clutch and now, your forward/reverse movements are greatly slowed down giving you "micro-control" .
In my case, the left foot would be holding the clutch while the left hand is operating forward/reverse and the right foot is operating the throttle.
I don't know that's how it works....it's simply my interpretation of what I was told. Since I don't do anything like that and have never needed to be micro-careful, it's not a problem to me that it doesn't work.
When my chair is turned and I'm using the backhoe, I usually move the machine by reaching behind me to raise the front bucket then, use the hoe to push/pull or crab myself to a new position (which is a minor movement of machine, not something like 10 feet).
I have a hand throttle to the left of the seat (when you're facing the backhoe) so in rare occasions that I need to actually MOVE the machine forward, I will raise the stabilizers, reach behind me and raise front bucket. I can then click it into forward and use the hand throttle to gas it a little bit.
Frankly, by the time you go through these gymnastics, it's easier to simply turn the chair around and drive the machine.
For adjusting the backend of the machine though..... crabbing is the way to go. Fast, easy and can plant yourself where you want to be. Took me a couple tries to get accustomed to it because the machine can/will teeter/totter since you are only on two pivot points. Once you figure it out, it's easy to do.
   / First decision: CUT vs construction backhoe #43
Maybe he meant Tractor Loader Backhoe (TLB)?
Those are some meaty looking rocks. A compact tractor will have a heck of a time loosening and removing those without a lot of manual labor involved too. A construction TLB will work circles around a compact, doing earthwork. Just don't ask it to mow.
If it were me, I would buy an older Case 580 or Ford 555, preferably with 4wd. Do the heavy work with it and then if warranted, trade down to a smaller machine when you feel the backhoe is no longer needed.
Yep.
In the pics posted I didn't see an area the size of a CUT that didn't have a rock sticking up?? A CUT will only aggravate the operator in these conditions.
This property will require a LOT of patience and time.
   / First decision: CUT vs construction backhoe #44
My full-size backhoe has a stick on the steering column with 1-4 gears and 1-4 gears in reverse. There痴 no such rodeo action. It痴 much smoother than gear drive with a clutch. Probably 99 percent as smooth and precise as a HST. I can hit my machine in 1st gear and it won稚 move until I let off the brake. You can easily ease up on the brake for precise movements. Pretty much identical to an automatic transmission vehicle except I have all gears in reverse. Not that that痴 a useful feature. I壇 rate the power shift in my backhoe or whatever term you want to call it as being equal to a HST. There痴 no foot clutch in the backhoe. You致e got neutral and a button on the loader stick that engages neutral.
Yep. Very useable and controllable.
rScotty is proficient in his descriptions of what he's familiar with. But he's not all inclusive.
What is the deal with the Kubota l48? They seem to run less expensive than the l45 and l39.
Yep.
We started building on the property 13 years ago. After finishing the build, which was like a marathon sprint, I have done everything by hand. I am getting older and need some sort of tractor. Leaning hard toward l45 or deere 110.
   / First decision: CUT vs construction backhoe #47
Isn稚 that what the brakes are for? You can hold the machine locked with the brakes and either ease up on the brakes or increase the throttle until it moves as easy as you want. I agree probably not as smooth as a HST but I致e never seen a full size backhoe have that option.
I agree. In all of rScotty's self proclaimed experience I wonder if he's ever operated a good torque convertor setup. Not a human alive that can run a dry clutch as smooth as a good torque convertor in any traction situation.
With my 30 yr old TLB, at an idle on flat hard ground, I can engage my forward shuttle and get out of the tractor and walk away. It will simply sit there. Only will move if rpms are added.
For the OP I believe this setup to be the best for his situation. Money is going to be the limiting factor.
   / First decision: CUT vs construction backhoe #48
I think those would be very good choices and serve you very well!!!
   / First decision: CUT vs construction backhoe #49
Yes, expertise is sef-proclaimed on the internet. Nobody really knows who (or what) anyone is. I rightly claim a lot of expertise. PM me if you are curious. Otherwise, take it all with a gain of salt.
BTW, I disagree on the smooth torque converter vs good smooth dry clutch....but does it really matter? What we are talking about is ice & hillsides, not dry ground. I'd go along with you on dry ground. But on ice the tires will spin in the same situation that you describe because as I said the friction is too low to hold the machine in place. And on a hill it may slide.
Can you use one in that situation?? Well, of course you can. In fact I do. I use ours just like that. But I get out of shape sometimes too. And the coach is a newby and I've got 50 years experience. He's looking for advice; not answers.
rScotty
   / First decision: CUT vs construction backhoe #50
BTW, I disagree on the food torque converter vs good smooth dry clutch....but does it really matter? What we are talking about is ice & hillsides, not dry ground. I'd go along with you on dry ground. But on ice the tires will spin in the same situation that you describe because as I said the friction is too low to hold the machine in place. And on a hill it may slide.
rScotty
Yep, and I contend if tire slippage happens with the properly operated torque convertor machine it's going to happen with the dry clutch machine as well.
I also contend, for a novice, the torque convertor machine is much easier to learn to operate.
2016 Nissan Altima 2.5 Sedan (A55853)
2016 Nissan Altima...
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A55315)
2025 Mahindra 6075...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
2017 BX2680 Sub Compact Utility Tractor (A56435)
2017 BX2680 Sub...
