barbqranch
McMaster Carr shows 1/16 pipe plugs and taps.
			Let me "fire" this subject up again. My 1980 1500 pump DOES NOT have the drain/fill-level screws in the pump housing either. I only want to have to tackle this one time and be done with it. I do plan to remove the cover when I drill-n-tap and then clean it all out real good....BUT....my question is, what size bit and tap did anybody use?
A 1/4 x 20 looks about right as far as diameter goes, but I don't know how much of a boss I have for the course threaded bolt to grab and am thinking a fine thread should be used, or maybe even a 1/16th. pipe plug. I forget what the threads are on the plug that is a step below the 1/8 NPT plug, but I have a few of those that came out of Harley EFI lines I have accumulated over the years. The plug is used in a fuel pressure port for testing on the fuel injected models. A plumber friend of mine told me there was no such thing as a 1/16th. pipe plug when I went in to purchase a tap....but I have a few that I call a 1/16th. because they are a step below a 1/8th. and look like they will fit these bosses on the pump just fine.
In any event....what did somebody that has actually made this modification use?
Is this really a good idea? Is there a chance of ruining the pump? Is it necessary to drill into a closed system? Doesn't this pump have some other means of lubrication? I sure would get the answers before attempting to drill into a $600+ pump.:confused2:
JC, I am sitting here thinking about different ways the oil could be changed in a pump with only a fill plug and came up with this off the wall idea. Go to a farm or pet store and buy a large plastic syringe, attach to this a 6" piece of small clear plastic tube where the needle attaches. Push all the air out, insert it into the pump and pull up on the plunger till it fills the syringe. Empty it out put in the same amount of new oil re-insert the tube and push it into the pump. What do you think, will it work?Ray,
The lubrication of this pump is stand alone and not connected to crankcase oil as some other model. It is essential to replace this oil every 300 hrs. I know I was the only one who changed it amongst two other previous owners. @ 900 hrs and 30 years, it looked dirty but not too bad as there is no product of combustion missing with the oil like crankcase. what I suggested in previous post is not a bad idea. I would have done it myself if I did not have the drain and level holes tapped.
JC,
JC, I am sitting here thinking about different ways the oil could be changed in a pump with only a fill plug and came up with this of the wall idea. Go to a farm or pet store and buy a large plastic syringe, attach to this a 6" piece of small clear plastic tube where the needle attaches. Push all the air out, insert it into the pump and pull up on the plunger till it fills the syringe. Empty it out put in the same amount of new oil re-insert the tube and push it into the pump. What do you think, will it work?
