Ford 1920 3 point lift oscillating
   / Ford 1920 3 point lift oscillating
Just an update on this, the o ring on lift piston is toast, have the new oring on the piston, now to just figure how to get the new gasket over the cylinder, got to be a trick as the gasket fits but will not slip down over cylinder wall.
   / Ford 1920 3 point lift oscillating #12
Look at the link below and somewhere you find how to do it. in general you get one chance to do it. Screw it up and you'll be buying another seal. Check the orientation of the double lip on the seal. The lip will face the lift piston head assembly. The seal is nylon. make sure the piston is clean, put lube oil (hyd oil) liberally on it, soak the seal in the oil, put the piston facing up on work table , keep the seal with the lip up square and plumb over the piston and slowly try to push it over so it slides in the groove in the piston. Don't force it, don't pry it, don't use any tool to do it. Do it only by hand pressure. if you have time I'd take a small container, put some hyd oil in it (1/4" deep) and leave it in sun for 1/2 hr. The heat will expand the seal just slightly that might make the job easier. I have done without heating the seal.
JC,
http://www.tractorbynet.com/forums/...ng/90819-my-f-1700-testing-my.html?highlight=
I've got the o ring on the piston, I am having trbl getting the head gasket on, the cylinder is still connected to the head and opening in the gaskat will not slide down over the cylinder, does the cylinder come off the head, I noticed in the pictures the cyl is not connected to the head,, I may not be explaing this right.
   / Ford 1920 3 point lift oscillating #14
Yes, remove anything that might be attached to the 3 point, left the arm up manually(raise it) , put a 2x4 under the lift arm or tie it up there to something. that motion will move up a ram rod that pushes the piston up. This way was the most efficient way to take out head, cylinder and piston as a whole assembly to be separated outside of the tractor. too late for you doing it that way. push your arm in the cylinder all the way to the bottom and grab the end. you shuld be able to pull it out without much effort. If the o-ring is moving on you, put a small dab of rtv blue in the groove , put the o-ring in , let it dry out(cure ) for 10 minutes and then assemble the whole thing. O-ring will stay put.
JC,
Got it all back together this morning, hooked up the disc and it worked great, lift held at all levels with no hiccuping, took the disc off and drove back to shop and was just working it up and down and now it will only work using the draft control lever and it only lifts when the lever is up past the normal operating range
Houston, we have lift off, I hope this is last chapter in this saga, the original trouble was repaired with a new O ring on the piston in just a few minutes, the rest was a self inflicted wound, I had the sheet metal off in prep for a paint job, whatever you do DO NOT move the the 3 point lever lower than it is supposed to go with the sheet metal on, if you do it will in turn cause the wobbling pin to jump out of a pre-engineered slot and jump up behind another internal lever causing the lift not to work, it is hard to see and determine where its supposed to go, another good thing NOT TO DO is take a dowel and push the plunger in the in the control valve in while the engine is running, (trying to determine what causes oil to come to the piston), this will in turn release a small flood of oil, covering you and your assistant((grandson) and everhting forward from that point to be covered with oil. I didn't know jack when I started this and now I know just e-nuff to be dangerous, but it is lifting.
   / Ford 1920 3 point lift oscillating #17
Goods news :thumbsup: Glad it worked out and the fix was simple and cheap. I'll have to take time and decipher what all happened as you explain at a later time.
It is good to be jack of all trades... and master in none:) stay safe.
JC,
   / Ford 1920 3 point lift oscillating #18
ditto1 glad you got it going!
   / Ford 1920 3 point lift oscillating #19
Double hunter, you learned the way most of us do. Sure, you made a few mistakes, but you solved the problem. I think that learning method describes 99.9% of all TBN users. The remaining .1% have never tried and never will.:D
   / Ford 1920 3 point lift oscillating #20
yep! how's the saying go.. you gotta break a few eggs to make egg salad? :)
30ft Highway Trailer Co. Lowboy (A56436)
30ft Highway...
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
2025 J and C 6X12SA 12ft S/A Enclosed Trailer (A56859)
2025 J and C...
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
(7) Ten Hole 25 Inch Steel Rims (A57454)
(7) Ten Hole 25...
