How do you cut metal for finished projects?
   / How do you cut metal for finished projects? #11
i cheat......this is the plasma unit i use. Its set up in my shop, and cant live without it _MG_4810.jpgplate 2.jpgshop 3.jpg
   / How do you cut metal for finished projects? #12
I think since you have a chop saw get a plasma.
I primarily use a band saw, chop saw or torch. It depends on the job. I am hoping to get a plasma in the next few months. I am looking at a Thermal dynamics Cutmaster 42.
I think a plasma would be nice for cutting out gussets like you mentioned.
   / How do you cut metal for finished projects? #13
I have been using most everything that has been mentioned so far and they all work very well but they all have there limitations.
I would recommend that you start with a port-a-band, it can be portable or I built a base for mine and it works great as a stationary saw.
I would also recommend a carbide tipped saw blade that fits into a Skilsaw, it is like the blades that are used in the slow speed cutoff saw but has a higher RPM rating for use in a Skilsaw. These blades work well up about 1/2" thick steel. They can also be used on tube, angle or channel. This would be for straight cuts only.
At some point you can add the Plasma cutter and maybe a stationary band saw as well.
   / How do you cut metal for finished projects? #14
My struggle is that I see the fabrication that some of you guys do and I can't seem to get parts cut consistently. For just cutoff of tubing, pipe, bar stock and angle I get consistent parts but things like gussets and flat parts it is a real bear. My parts seem to require endless grinding to get two parts to match dont mention the time involved in getting a third part to match.
It is sounding like the bandsaw maybe the better choice but I am open. My daughter, the artist, wants the plasma cutter.
Cutting sheet metal I am okay with and do okay with sheet metal fabrication. It is the heavier gauge and plate that is my greatest challenge. I don't plan on fabricating more than typical farm implements. I'm thinking about a grapple.
I appreciate your responses.
You should be able to do what you are wanting to do with your O/A torch. Maybe you have too big a tip on your torch or it is dirty. Most people tend to use too big a tip size. I use a Victor size 000 for 1/8 inch thick, then size 00 for up to 1/4 inch, then size 0 for up to 1/2 inch, then size 1 for 3/4 inch, then size 2 for 1 to 1 1/2 inch thick.
If your main additional need is cutting plate then the plasma is the right tool if you can justify the extra expense of the cutter and air supply which again, MUST be dry air. The main place a handheld plasma cutter will hold an advantage is cutting thin (under 1/8 inch) and non ferrous material. Otherwise the properly set up O/A torch should do what you need
   / How do you cut metal for finished projects? #15
I started out with just a cutting torch and a grinder. In time I bought a smaller grinder and a HF style band saw. (30 yrs ago and before HF) When I bought my 14" bench style chop saw I thought I was in heaven. Fast accurate cuts that didn't need grinding. Later I bought a brick masons saw and use it with the half worn out chop saw blades that are too worn to make cuts in 2"-3" pipe or tubing. With a bushing to get it down to the 3/4" arbor, my blades are basically free. It does great on small pipe, bar or angle. Later I got a gas operated chop saw, (chainsaw with a 14" chop blade) and used it to build my shop using metal galvanized decking material. I use it a lot cutting bigger pipe, angle, tubing. I hate dragging in a 20' stick to cut on the inside saw so I make a rough cut out on the rack and then a finish cut inside. That gas chop saw is a scrappers dream too. And the blades wear down pretty close to nothing before I need to change it. Cutting decking the other day I was using old take off blades from the 14" inside saw. I had new ones but saving $$ by using old ones.
I use and like the thin slicing blades on a small side grinder but they get expensive, doesn't last very long and they eat up pretty fast.
I also have a port-a-band hand held band saw but it doesn't get much use. If I can get it inside and in a mounted saw, I do it that way. For portable cutting that or my 14" gas chop saw usually get things done.
For thin sheet metal I have a shear that came out of a welding shop (table or flat trailer mounted), a big scissors shear that is basically a 4' long pair of scissors (work great for expanded metal or thin sheet) and also have a 4' break-sheer-roller from harbor freight but it basically is only good for ductwork thickness or thinner.
Some of you guys talk about not having a steady hand with a torch. I learned to clamp a heavy piece of tubing or channel to my plate to use as a guide to let my torch rest against when cutting 1/8" or thicker. I still have to grind it but it comes out straight and not as much grinding.
I also had a buddy teach me how to cut circles out with a torch that look like they were cut with plasma, yes, I have to grind them but the finish product looks professionally cut and precise. YES, with a hand torch.
I dream of the day I have a big enough shop and funds to buy a large commercial sheer and press break but I don't see it anywhere near in the future. i guess we'll have to get it done the old slow way.
   / How do you cut metal for finished projects? #16
Well, don't leave us in suspense!
   / How do you cut metal for finished projects? #17
If you are making very exact parts and especially multiples of anything from flat metal, the NC plasma is ideal. If you can afford it, it opens a whole new world for your capabilities. Caution: right after getting an NC plasma, you will need a press brake.
   / How do you cut metal for finished projects? #18
Like has already been pointed out, a plasma can be a major investment. In addition to the plasma cutter, you will need a good compressor and drying system. I have a 60 gallon 220 compressor with multiple drying filters. Even with my 60 gallon compressor using the plasma can create quite a demand.
What about some of the plasma cutters that have built in air compressors?
For example:
Hobart Airforce 500534 250ci Light Weight Plasma Cutter with Air Compressor - Amazon.com
Hobart AirForce 500i Plasma Cutter 500548
Hobart AirForce 700i Plasma Cutter 500546
Just the portability might be nice.
Do these dry the air?
   / How do you cut metal for finished projects? #19
Unless I'm wrong, of the three you listed, only the 250ci has a built in compressor. I'm not familiar with units with built in compressors but I'd have to assume they have some sort of moisture separator built in also.
However, for the type of things you are talking about wanting to do I don't think you would be happy with the 250ci. While they say it is rated for 1/4 inch, they mean severing. In other words, the useful smooth cut capability of the unit is probably more like 1/8 inch. I'd also be worried about the durability of the compressor and how hard it will be to rebuild (or how costly to replace?)
If I were looking at the other 2 I'd probably go for the 700i for it's extra duty cycle and cut capacity. Once again however, you will need a clean and dry air supply. I really don't see the advantage of the dual voltage capability on the 500i since you have to have an air source anyway.
   / How do you cut metal for finished projects? #20
When I built my electric tractor I did it from scratch using metal found in a scrap metal yard.
All the metal was cut using one good quality 'Eclipse' hacksaw blade in a cheap hacksaw frame.
I have a 4 1/2" and a 9" disc cutter but after the initial 'keeping the noise down in the evenings due to the neighbours' I was determined to hand cut everything and then to try and make the blade last to the end of the project. So I did, and had the tractor on the road and running before I changed the blade in the saw.
2007 Isuzu FTR Truck, VIN # 4GTJ7F1357F700209 (A57453)
2007 Isuzu FTR...
2013 PETERBILT 389 (INOPERABLE) (A55745)
2013 PETERBILT 389...
2023 MADJAX GENESIS 300 ELECTRIC CART (A57192)
2023 MADJAX...
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A56436)
Magnolia Trailer...
Topsoil Trommel (A57454)
Topsoil Trommel...
1996 International 4700 Box Truck, VIN # 1HTSCABP2TH265415 (A57453)
1996 International...
