How to kill a maple stump?
   / How to kill a maple stump? #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
At some point our property was logged leaving behind half a dozen big leaf maple stumps. They are huge. One may be 7 feet I diameter. When maples get cut they sprout new growth. They look overly bushy. Tried roundup with little success. Anyone have other suggestions?
   / How to kill a maple stump? #2
Are you talking about foliar applications? I would use the cut-stump method -- cut off the sprouts and immediately spray the cuts with undiluted glyphosate (41%) to prevent regrowth.*
Steve
* I think the label says dilution up to 25% with water or diesel is OK for the cut-stump method. Or is it 50%?
   / How to kill a maple stump? #3
I've killed some big stumps with road salt. I had some bags that hardened up and just broke it up as much as I could and spread them around the stump.
   / How to kill a maple stump? #4
Mix 41% strength Glyphosate with 25% diesel, and use a paint BRUSH to generously apply it to the freshly cut sprout stubs.
   / How to kill a maple stump? #5
Steve
The Roundup is a great idea but do not dilute with water or it won't work. I do not dilute with anything but use full strength concentrate. Cut the branch off and immediately, if not sooner, paint with glyphosate concentrate. That will do the trick and you can search for threads I've done on the process. It's easy and works. It is the only method I use and only rarely does a new sprout reappear.
That's for killing the new growth. To get rid of the old stump you can burn a lot of it with a wood fire and a leafblower to keep the embers going on the stump. I've done threads on the process.
   / How to kill a maple stump? #6
Dig it out.
Thanks all. Will try the full blown mix. These stumps are probably 4 to 7 feet wide,
   / How to kill a maple stump? #8
How long have the trees been down, or do you know?
I've taken a few Locusts down and they try to sprout for two to three years afterwards. I just keep cutting the sprouts off and they eventually give up.
   / How to kill a maple stump? #9
If you have deer and other wildlife around, they will love you for doing that. :)
   / How to kill a maple stump? #10
41% Glyphosate diluted with diesel works just fine!
75% Glyphsoate/25% diesel.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2008 DRAGON PNEUMATIC TRAILER (A58214)
2008 DRAGON...
2022 CATERPILLAR 242D3 SKID STEER (A60429)
2022 CATERPILLAR...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56438)
2023 Kubota...
2004 Komatsu HM400-1 (A60462)
2004 Komatsu...
2003 PETERBUILT PB330 DUMP TRUCK (A60430)
2003 PETERBUILT...
