Input on a high volume, low weight hauling need.
   / Input on a high volume, low weight hauling need.
The more I look at that Sure-Trac utility trailer, the more I like it. That might be the key to my issue.
   / Input on a high volume, low weight hauling need. #23
Go and check them out you can make side boards like the one in the video , And you could use it on the road also.....
   / Input on a high volume, low weight hauling need. #24
consider something similar to wagtails invention.
use pallet forks and build a treated wood floor with sidewalls -make it wide, maybe 7ft
with a quickattach it could sit beside the barn till full and then pick it up and deliver it to the back 40.
personally i put it in the manure spreader and then spread it when the spreader is full. if you get a pto driven spreader you back up to the pile and use the pto to put it on the pile.
   / Input on a high volume, low weight hauling need. #25
Build yourself a manure catapult. Call it Fling-**it-Hi.
Evacuate and spread it all in one motion.
Ah yes...the Trebushart :D
I don't think you are going to find the combination you want, directly, especially if you want it under 200 lbs (which seems impossible to me). But you could hybridize and have an alum bed/tub made for a tilt frame/dump trailer perhaps. Or an Alum/plastic tub and make a tilting frame for that compact running gear. You are probably going to have to go custom to some degree.
   / Input on a high volume, low weight hauling need. #26
You have a nice tractor, I dont understand why you arent using a nice manure wagon with it. Load it up and haul away once a week. Self unloading as well. Heck of a lot simpler than trying to make some light weight solution to a problem that has been solved a century ago. IMHO an ATV/UTV is the wrong tool for the job if you already have a tractor.
Moving the compost pile closer to the barn would be my go to.
   / Input on a high volume, low weight hauling need. #27
I won't store manure in my manure spreader mainly because its an old 1940’s vintage wooden machine. I keep it stored under cover. Works great and is either towed by my horse team or behind my side by side.... depending on my mood.
I store manure in compost pile and spread 2 times a year.
   / Input on a high volume, low weight hauling need. #28
I too thought big bucket, but it's still too far to drive. I am adverse to working with highly corrosive manure for the most part. Used sheit spreaders are very cheap. Maybe take off or disconnect the paddles and just use the moving floor to unload. I don't know much about how sheit spreaders work.
   / Input on a high volume, low weight hauling need. #29
mine uses tire movement to operate, but i suppose there are pto versions out there. Would not think its too useful just to transport. Once fill mine its off to the pasture to fling it i go. IMG_0337 small.jpg
   / Input on a high volume, low weight hauling need. #30
I think AG has gone so BIG that there are a lot of older smaller spreaders out there. Many guys get them just to move stuff, like firewood around the farm.
CAT 289D3 (A58214)
CAT 289D3 (A58214)
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
2010 Honda Accord Sedan (A59231)
2010 Honda Accord...
2007 Ford F550 Superduty. 6.0 Powerstroke - 90k Miles (A56438)
2007 Ford F550...
2016 Case Magnum 310 (A60462)
2016 Case Magnum...
