Is "breakout force" the amount a loader will lift?
   / Is "breakout force" the amount a loader will lift? #11
My OM says 800lb lift 'per ASAE'-something and breakout force >2k lbs. Presumably, if the lift cylinder circuit (valve) is activated (vs locked) are limited thusly, a much higher, simultaneous 'breakout force' (curl or what, then?) could force the lift arms down, back-feeding the system harmlessly. (pressure ~balanced in all activated cyls/circuits) :D
btw: This may bear out better in a closed center vs open center system due to valve/flow 'priority' within the stack ...
:stirthepot:
   / Is "breakout force" the amount a loader will lift? #12
that would be kinda hard wouldn't it?:)
Not if the "pins" are simply being used to describe a "point" of force alone that incorporates your rendition of break out force where the boom lift is also included, I did not take your answer to be that the measurement is shared or combined but more of an "either or thing" (lip or pins). I think your definition is what most of the manufacturers use. That is how much force can be generated when the bucket is buried into a pile to liberate it. It is a much more impressive number to add both the lift and curl capabilities of the loader happening at the same time even though neither is operating at 100% when engaging both.
   / Is "breakout force" the amount a loader will lift? #13
,,,,,,,,,,,:confused2:
   / Is "breakout force" the amount a loader will lift? #14
From the link that I gave, does any of that info tell how much the loader will lift?
   / Is "breakout force" the amount a loader will lift? #16
It does not appear to, but may be the numbers:
Lift to full height (at pin):
2500 lbs [1134 kg] (NSL)
2800 lbs [1270 kg] (MSL)
   / Is "breakout force" the amount a loader will lift? #17
I seriously doubt they would change the definition of breakout force with any revision to the specification.
Breakout force is lift cylinders only. It's so much higher because of how the cylinder/boom geometry changes with height.
"5.1.5 Breakout force a腎 pivot pin (Y): Vertical lifting force, in newtons
(pounds), the loader will exert at the bucket pivot pin centerline using the
lift cylinders only, with the bucket horizontal at ground line.
5.1.6 Breakout force (Z): Vertical lifting force, in newtons (pounds), the
loader will exert located 800 mm (31.5 in.) forward of the bucket pivot pin
centerline using the lift cylinders only, with the bucket horizontal at
ground line.
5.1.7 Bucket rollback force at maximum height (VV): Vertical lifting
force, in newtons (pounds), the bucket will exert, located 800 mm (31.5
in.) forward of the bucket pivot pin centerline, using the bucket cylinders
only, with loader at maximum height and bucket horizontal.
5.1.8 Bucket rollback force at 1.5 m (59 in.) lift height (XX): Vertical
lifting force, in newtons (pounds), the bucket will exert located 800 mm
(31.5 in.) forward of the bucket pivot pin centerline using the bucket
cylinders only, with the loader positioned to locate the bucket pivot pin
centerline at 1.5 m (59 in.) above ground line and bucket horizontal.
5.1.9 Bucket rollback force at ground line (ZZ): Vertical lifting force, in
newtons (pounds), the bucket will exert located 800 mm (31.5 in.)
forward of the bucket pivot pin centerline using the bucket cylinders only,
with the loader positioned to locate the bottom of the bucket cutting edge
   / Is "breakout force" the amount a loader will lift? #18
"5.1.5 Breakout force aè…Ž pivot pin (Y): Vertical lifting force, in newtons
ground line.
In other words, any of the above. I would suspect that a manufacturer is going to go with the highest number that they get from any one of these descriptions. Mostly it is a numbers game that mfg. play with the consumer and there is no way to tell which of the numbers they are using. None of my tractors will perform like my old grey market Yanmar with the Vietnam built FEL. It would lift the rear of the tractor with the FEL when it(the bucket) was hung under a stump, rock etc.
   / Is "breakout force" the amount a loader will lift? #19
Yes ~3485 at the pins. The bucket probably weighs ~ 400 and sits further forward, as will the load you put in it. Guessing then ... it should lift a bucket payload of ~2500 off the ground and maybe 1800 to full height.
,,,larry
   / Is "breakout force" the amount a loader will lift? #20
Kinda hard to understand why my FEL won't lift 2 55 gal poly drums of water with 2k+ lbs of 'BOF' (measured 'wherever') and using lift cyls only, not budge 'em the least. (can raise 1 full and one ~1/2 full to several feet)
Perhaps rather than properly define BOF we (and some OMs?) are misapplying the term to describe 'rollback force' . Kleenex, Ping Pong, Bush Hog, Ditch Witch are brand names broadly applied and commonly accepted as 'descriptive' vs bathroom tissue, table tennis, brush cutter or trencher. :scratchchin: ASAE's terms may be set in stone, but dictionaries are 'updated' as usages of terms evolve with popular culture.
Going 'by the book' depends on which book (vs popular terminology), and perhaps the numbers just aren't being parsed the same by all. I won't likely ever claim to fully understand BOF, esp if I'm not sure now to apply it. :confused3: ... :laughing:
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A54811)
2010 Turfco...
20 UTILITY TRAILER (A55745)
20 UTILITY TRAILER...
JOHN DEERE 5103 TRACTOR (A57192)
JOHN DEERE 5103...
KENWORTH T/A DAY CAB ROAD TRACTOR (A52706)
KENWORTH T/A DAY...
2007 Saturn Sky Convertible Coupe (A55853)
2007 Saturn Sky...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
