Kerosene vs propane
   / Kerosene vs propane #11
My experience has been that the kerosene heaters throw out much more heat. I had 2 with similar btu ratings and the kerosene version was an order of magnatude hotter.
   / Kerosene vs propane #12
I use a diesel/kero salamander in my garage, works great. I figured in my area it's easier to get diesel or kero then it is to mess with a propane tank.
   / Kerosene vs propane #13
As you know, a BTU is a unit of measurement. So, that should not be the case.
Perhaps there is a difference in fan size that caused the air to feel warmer, or cooler at a given distance. Perhaps one heater did not work as advertised. Or, perhaps you compared the input rating, and not the output rating. There will be a difference there, from manufacturer, to manufacturer.
25,000 btu's is like 25,000 feet of distance, it's the same amount, no matter how it is produced.
   / Kerosene vs propane #14
I have a kerosene heater - salamander style. Works OK for my shop size - roughly 22x26 feet. But it is noisy and smelly. A tank last about 4-5 hours roughly. And it needs electricity to run.
I am considering going to propane less noise and no smell I hope. The shop is not tight by any means and I usually keep a door or window slightly open. And the unit is non-electric.
http://www.princessauto.com/farm/he...btu-convection-propane-heater?keyword=heaters
Lloyd
   / Kerosene vs propane #15
Without a noisy fan using expensive electricity, Kero doesn't propel heat very far nor very fast. That's a down side.
LP tanks can be a bit cumbersome. That is their down side.
   / Kerosene vs propane #16
Not sure but I've never seen high btu propane units in that salamander configuration, the kero ones go over 200,000 btu.
I have a 400,000 btu propane LB White.
It'll warm you up. :)
I prefer propane but I have several of both and each kind of has it's place.
For the barn I would use kero.
   / Kerosene vs propane #17
If you are looking for localized heat, I have a 35,000 btu kerosene that I use like JB mentioned. It's cheap to run but it'll keep you warm. I've got a couple of each, but for enclosed area's, I use the propane. I think some people here are confusing kerosene salamanders with kerosun heaters.
Well had to do something, Lowe's all out, Home Depot out and I was able to get the last one at Tractor Supply. Ended up with a Mr Heater 125000 btu forced air kerosene. I think that this unit will fit our needs. Thanks all for the input.
Cary Mr. Heater - America's Most Popular Portable Heaters
   / Kerosene vs propane #19
Good choice. I use a 125k in a 2400 sf shop. It will burn kerosene or diesel, the latter is much more effiecient. Propanc, even with the same BTU rating seemed more localized. This unit, a DynaGLO Pro heats the shop, provides heat to work under a tractor, or can warm the alley of the horse barn. Drawbacks, noisy and smelly over time in an enclosed space with diesel.
Milwaukee Box with Electrical Supplies (A57454)
Milwaukee Box with...
John Deere 750 Tractor (A57453)
John Deere 750...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
International 424 Loader Tractor (A59814)
International 424...
2019 Deere 35G (A53317)
2019 Deere 35G...
