Kubota L3560 Size vs. Others
   / Kubota L3560 Size vs. Others #21
Hi, first post. I've browsed this site for awhile, this thread is one in particular that came up during my research.
I'm close to pulling the trigger on an open station grand L. L3560 is what I had my eye on. HST and turf tires.
Dealer also has an L4760, that went out for a demo/ loan. Pulled a hayride at an apple orchard this fall, <50 hours, loader and 3 point unused.
Selling it as new (0% and full warranty) at good discount.
That BIG loader is very enticing...
I do not have a big property, just a large-ish lot. These are bigger machines than most people would be considering given my property size, I suspect.
I have some site work to do, grading and leveling and a retaining wall to build. I also have a large garage build planned, will build primarily alone, so loader will be assisting in that.
After that is complete- snow removal, parking trailers (10k lb camper) and general utility loader/ lifting work.
I know these are similar "frame size" with the 4 cyl models a tad longer. But the bigger tires on the 47 sure make it *look* bigger..!
What is the "effective size" of these 2 models? Is the maneuverability much different?
I'm concerned I'm tripping over spec and looking at machines that actually do border on too big...
I have no pto needs that I can ever see. HP isn't an issue.
Cost is secondary to my decision making. I want the right machine.
I won't be doing a backhoe, I'll rent a mini ex when the need arises, such as the garage foundation, etc.
Any input would be appreciated, I test them in the morning!
Those machines are pretty close to the same capabilities. The L4760 has quite a bit more HP if that’s important. The L3560 is a much nicer machine. And you are comparing one of the lowest HP class of that size Grand series machine.
   / Kubota L3560 Size vs. Others #22
Those machines are pretty close to the same capabilities. The L4760 has quite a bit more HP if that痴 important. The L3560 is a much nicer machine. And you are comparing one of the lowest HP class of that size Grand series machine.
Thanks for the response, I am interested in what you mean by the L3560 being nicer?
Are they not equipped the same, operator station wise?
They are similar in weight and 3 point lift but the LA1055 on the L4760 is much stronger than the LA805 on the L3560.
This is the L4760, not the standard L4701 I'm looking at.
   / Kubota L3560 Size vs. Others #23
I missed that part. Disregard the being nicer part. If the 47 has a series bigger loader that would be another advantage.
   / Kubota L3560 Size vs. Others #24
.......................That BIG loader is very enticing........................I do not have a big property, just a large-ish lot. These are bigger machines than most people would be considering given my property size, I suspect.........................................After that is complete- snow removal, parking trailers (10k lb camper) and general utility loader/ lifting work. ........................................I'm concerned I'm tripping over spec and looking at machines that actually do border on too big...........................I want the right machine..................................I won't be doing a backhoe, I'll rent a mini ex when the need arises....................
I see some of myself in your comments. Shop carefully. With mention of snow removal and cost being secondary, are you sure you really want an open station? Drive different tractors. You may be surprised at how nimble some of the larger-looking machines are.
   / Kubota L3560 Size vs. Others #25
Really leaning toward the L4760 for the bigger loader. With the building a want to raise I think I'll be glad I have as much lift as possible.
I'm thinking the actual maneuverability difference will be negotiable between the 2, even given the visually larger appearance.
"Tractors shrink when you get them home" is the line I keep using on my wife lol.
I gave cabs a hard look and I think open is what I want. Super comfy yes, it just felt frivolous for my uses. I'm not in it long periods of time. A canopy will keep enough weather off my head to be useful. it will only live outside till my building is up, then it will live warm and dry.
   / Kubota L3560 Size vs. Others #26
So, to add some information...I didn't want a novella for my first post... here's a problem you've heard 1001 times.
I had been shopping for awhile. Many makes and models on my radar. I have spreadsheets of specs, sat on/in dozens of machines (only operated a couple)
I liked Kubota, and I liked my salesperson there.
Looking at my property size, etc. and how he percieved my needs, recommended L2501.
I tested, liked, bought.
I week later I have him on the phone, "dude, It's too small...what can we do..?" It doesn't have the lift I was hoping for, either end.
He gets with Kubota and management, I can get out at minimal loss and into another.
So that's what I'm doing, and a further reason I am shooting larger than smaller.
   / Kubota L3560 Size vs. Others #27
........................I'll be glad I have as much lift as possible. ...............................I'm thinking the actual maneuverability difference will be negotiable between the 2, even given the visually larger appearance. ....................................................
My L4240 is not from the current series, so things could be different. For one thing, the loader is an L854, which I believe is capacity in KG.
Maybe be that the current geometry of the Grand L's has changed, but with my L3200 / L4240 measurements it could be the Grand L's you're looking at are more nimble than your L2501.
With regard to maneuverability you can check post 31 in the thread below:
https://www.tractorbynet.com/forums...risons/417276-new-ls-mt125-used-kubota-4.html
Original test without the 1210:
L3200HST or L4240HSTC - Which turns sharper? - OrangeTractorTalks - Everything Kubota
   / Kubota L3560 Size vs. Others #28
Put my name on L4670 today.
Much of what I need is loader work, I think it was the right choice.
I did pass on the demo unit, it had R4's and they wouldn't swap. An as-is deal. Oh well.
Had one on the lot, loaded turfs already on.
Be ready in a couple weeks, I ordered 3 remotes and TnT.
Super excited!
Ordering a rear blade, I like the 96 inch "deluxe" aka value scrape blade from Everything Attachments.
   / Kubota L3560 Size vs. Others #29
Just make sure the rear valves meet your demands. They are REALLY prone to leakdown problems. I'm on my 7th? And only 1 of my 3 is reasonably solid. Really irritating when your TnT cylinders extend all the way on their own in under an hour. Not really an issue for hydraulic angle or offset as those cylinders aren't fighting gravity. Cold weather hides issues a bit.
   / Kubota L3560 Size vs. Others #30
Unfortunately I've read all too much on that issue...
I'm hoping they are tighter than has been reported.
They can't all be bad...can they?
I definitely intend to monitor it.
   / Kubota L3560 Size vs. Others #31
Congrats! Pictures will be required:)
   / Kubota L3560 Size vs. Others #32
Super excited!
Congratulations. Looking forward to seeing pictures of the new Kubota so I can drool over it. :thumbsup:
   / Kubota L3560 Size vs. Others #33
Here's what I have so far, it will look a lot nicer at home 😀
That's the 72" hd roundback bucket. I also will have a canopy.
   / Kubota L3560 Size vs. Others #34
:thumbsup: Very nice, MB tractor is nice to deal with, good people there
   / Kubota L3560 Size vs. Others #35
No, all aren't bad, just most in my experience. I have 1 good one out of 3 at this point on mine. Think I've had a total of 6 or 7 on there as they replace them looking for a good one.
   / Kubota L3560 Size vs. Others #36
Mine aren't a problem except when shock loaded (e.g. hitting an unseen hole/rough-spot at speed when carrying a large heavy implement fully raised, or clipping some immovable object that torques the implement) at which point I would pretty much expect the system's high pressure relief methods to take effect. ...though I've also had some of that shock-loading loosen fittings as well, which is part of why there's always (at least one) adjustable wrench in my tractor's tool box. Other reason for the adjustable wrench (with size markings) is to help reduce the amount of time figuring out which sockets, or fixed size wrenches I need to grab when doing planned/intentional maintenance.
   / Kubota L3560 Size vs. Others #37
Yup, that's MB in Tilton NH.
Tim is my salesperson and I've been happy with him.
   / Kubota L3560 Size vs. Others #39
Looks like you got the high capacity loader.
Are those regular turf tires or those fancy new radials?
   / Kubota L3560 Size vs. Others #40
Regular turf tires.
The big loader for sure. That was my reason for getting the 4760, otherwise I would have gone with the 3560. The hp wasn't a requirement for me.
2020 Westfield MKX 100-83 Auger with Swing Hopper (A61307)
2020 Westfield MKX...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2008 Volvo XC90 AWD SUV (A59231)
2008 Volvo XC90...
2413 (A60432)
2413 (A60432)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
