Loader Spool: Identical circuit upgrade from Ansung 17004 (2 spool) to 3 or 4 spool
   / Loader Spool: Identical circuit upgrade from Ansung 17004 (2 spool) to 3 or 4 spool #11
Youre good. The "T" I was referring to/ thinking of adding would connect to the first spool's T- line which goes back to the tank [to the T-line of the second spool. I don't think I would have to upsize that line as only one spool should be running through the T-line at a time that leads to the tank; correct?
Thanks
Yep that's right.
No matter if the flow to the tank is from one valve or two, it can only be as much as the pump puts out.
Well, I've searched for some time and I cannot find any information on this spool.
It is made in Italy, and the number looks like DOGDF2AACCZ150004
3044668
15/04/03
Any help would be appreciated. Thanks
   / Loader Spool: Identical circuit upgrade from Ansung 17004 (2 spool) to 3 or 4 spool #13
Very similar but made in Turkey,
good luck in your search.
Utility Cart (A59228)
Metal Box with 32 Ratchet Straps (A57454)
Metal Box with 32...
New/Unused 4000PSI Hot Water Pressure Washer (A57453)
New/Unused 4000PSI...
2018 KAUFMAN 44 FT CAR CARRIER TRAILER (A59575)
2018 KAUFMAN 44 FT...
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
Metal Sasquatch (A57454)
Metal Sasquatch...
