M-Series Snag!!!
   / M-Series Snag!!! #1
Glowplug
3rd Planet from the Sun
Kubota M7040HD
Anybody who has read my two recent threads Loader Arms Too Big and M8540 Loader Decision knows that I have been getting very close to getting a Kubota M8540. Well, yesterday I put in an application for financing. Kubota approved me but with one stipulation. I had to pay an unbelievable amount as a downpayment. So now I had to rethink my whole situation. Either wait on my tractor purchase, take out a loan from my dealer for the additional money down, or get a smaller tractor. Now truthfully, the M8540 is too big a tractor for my property. If there is such a thing. My wife wanted me to REALLY downsize. When I first started looking at tractors I wanted a standard shift transmission. So I quickly decided I wanted an M-series. I quickly went from the M5040 to the M6040 to the M7040. I stayed with the M7040 for a great deal of time. But the past few months I had decided I wanted the M8540 with a Quicke Q35 loader. So after this turn-of-events I went to my dealer today and spent about 2 1/2 hours there. At this point I have decided to get the M7040 with a Kubota LA1153 loader. I checked on the financing and approval was no problem. Turns out that Kubota's problem was that I was financing a 3rd party loader (Quicke) as well as a Rhino mower. By changing to a Kubota loader there was not a problem. I could actually probably even get the M8540 with the Kubota LA1353 loader with no problem. But I actually feel better by going with the M7040.
The M7040 is truly probably a more practical size tractor for my needs. I definately want a hydraulic shuttle though and my dealer has none. So he's been on the phone much of the afternoon trying to locate one.
It looks like I'll get a M7040 with hydraulic shuttle, 4WD, ROPS w/ canopy, rear and canopy work lights, 2 rear remote valves, and LA1153 loader with hydraulic self-levelling valve and 3rd function valve with a 72" bucket and pallet forks.
I actually feel better with the M7040 over the M8540. I think it will be more practical. The Cat I/II 3ph on the M7040 will allow for a wider range and less expensive implements than the obligatory Cat II hitch on the M8540. The only things I believe I would miss from the M8540 would be the F12/R12 transmission and the hydraulic brakes. The larger displacement, turbocharger, greater hp and torque, greater lifting capacity for both the 3ph and loader, and greater pump capacity would all be nice but probably not noticed for my uses. Also by getting the Kubota loader instead of Quicke loader I would have a universal skid-steer type interface as opposed to a "euro" style interface. I could then have the ability to use the numerous available attachments with universal skid-steer type interface.
I actually feel better and I am somewhat relieved. I am still somewhat concerned with the F8/R8 transmission though.
I'll tell you what. Buying a tractor is a thousand times more time-consuming and nerve-wracking than buying a car. But in my opinion it's a thousand times more important to make the right decision. If a car gets me from point A to point B without a major problem that's all I care about. But a tractor. . .that's a lifestyle!!!
Anyway, I just wanted to post all this for everyone's information and enjoyment. I guess I don't truly have a question but any comments or words of advice would be appreciated.
   / M-Series Snag!!! #2
Glowplug said:
I actually feel better with the M7040 over the M8540. I think it will be more practical. The Cat I/II 3ph on the M7040 will allow for a wider range and less expensive implements than the obligatory Cat II hitch on the M8540. .
My New Holland TN70A allows CatI/II implements. I have learned that it is not wise or possible to use all CAT I implements on my TN70A.
Bob
   / M-Series Snag!!! #3
How much money did you save?
Bob
   / M-Series Snag!!!
Bob
Over 6 grand!! That's more than I thought I would. I was under the impression the M8540 was only about $2,500 more than the M7040 according to my calculations. That's one reason I didn't mind stepping up to the 8540, mainly for the loader and 12-speed transmission. But with that price difference I don't think they're worth it.
   / M-Series Snag!!! #5
Chuck,
For your lot size, buying an M-series really seems to be jumping into the deep end of the pool....especially for a first time tractor owner. If you absolutely KNEW you needed that big a tractor or if you just had the cash lying around, it'd be different. But, with what appears to be minimal tractoring experience, it's impossible to know. Also, obtaining money for this buy appears to be an issue.
What you may be overlooking is that, on small properties, the small tractors are, in many cases, far more useful and enjoyable to operate than the big beasts. They can get into much smaller areas, can turn around much easier, can easily operate much closer to obstacles, and don't weigh so much that you have to constantly think about damaging the ground you travel over. Spending half a day seesawing back and forth to get into, turn around and leave a tight area will quickly cool one's 'big tractor' enthusiasm. Don't forget, with a bucket sticking out the front and a implement hanging off the back, even an L-series approaches the length of a full-sized pickup truck.
For 16 acres, I would be looking at the low end of the L-series (L3400, L3430) or even a B3030. Since you might have heavy work lined up, maybe you should aim a bit higher. An L4330 or an L5030 could be worth considering. Both are available in either GST (Gear) or HST and there are currently sales incentives in place to move them. Another choice might be an L4400 for plenty of power in a light package with gears and a trim price tag. If you have to sell down the road (maybe you needed bigger or smaller), any of these will be much easier to move than an M8540.
See how the smaller machine works out for you, then you will KNOW what you need without breaking the bank or giving the wife a reason to say, "Told you so.". Don't forget, big tractors need big strong implements that also cost big bucks and need big space to turn around.
I'd say, listen to your wife. She seems to have a good grasp of the issues at hand. It'll make things easier for both of you down the road.
Not trying to offend or be condescending here, Chuck. We all had to start out somewhere. Some of us grew up with tractors, others grew up with different advantages. Would hate to see you spend big $ on an M8540 and get discouraged by it when the same $ would've bought two of something that would've made you very happy.
FWIW
Bob
   / M-Series Snag!!! #6
I have to agree with Bob, an even smaller tractor would be more efficient for your size lot (even if you doubled it). However, I don't have any trouble understanding how you came to escalate up to the big M's. Tractors, like boats, are addicting, especially in the catalog/internet shopping phase of the purchase decision. Bigger is almost always more attractive on paper. However, it is good to catch yourself and rethink the whole deal before you purchase. I don't doubt you'd be happy with the M7040 but I still think you'd be just as ecstatic to have a beautiful Lxx40 series in your driveway with perhaps a couple of extra implements rather than extra horsepower. That said, I understand the emotional pull for "bigger, better". I'm grateful I've caught myself before buying a 46 foot trawler I didn't need or a 44 ft sloop that was just perfect when what I really was trying to do was find a boat I could sail around by myself. (Finally settled on a 24ft sailboat :) ). I think you would be every bit as happy sitting on an L as an M and I just cannot imagine that one of those L's could not manage every single task you have in mind. Good luck.
PS. Think of all the brownie points you would earn by announcing to your wife that you had considered her opinion and decided to downsize. That simple speech could keep you on her good list for a long long time.:D
   / M-Series Snag!!!
You guys are absolutely trying to kill me!!!!!!!!:D
About a year ago when I first started looking at tractors seriously I checked out and researched the L-series. My dealer said he really didn't carry many of those but would be happy to help me out. Most of the buyers of tractors up around that dealer are farmers with significant Ag applications in mind.
I appreciate your advice but don't confuse me even more!:D
Besides, I'm trying to purchase the land beside of mine, 12 acres, for a total of 28 acres. It will require A LOT of work to get it in shape. I'd like to clear it, and eventually do some hay round bailing on it.
See ya!
   / M-Series Snag!!! #8
I have 2 machines I use mostly. A Ford 2120 43hp and a New Holland TN75D 75hp Cat I/II. I routinely work on less than an acre at a time with the TN with no problem. In my opinion it's not the size of the lot that matters much, it's what you are doing. Round bale haying takes a good size tractor.
Andy
   / M-Series Snag!!! #9
See ya!
Ok, You do have a smaller sized lot (even with the extra 12 acres). Clearing the land will require some power and a piece of equipment. But are you talking about grubbing out 36" oak stumps across all the acres? Then either of your choices are too small. Or are you talking about running a rough cut mower and planting seed? Then they are too big. Since we don't know what your land looks like (at least I don't), nor your goals including the amount of time you want to spend --we can't get real close to good advice. Only guesses and speculation. While fun for us, it's probably frustrating for you. Can you post some pictures of your land? Maybe even a sat photo link?
I am assuming that you have had machines in the L4330 range and the M range delivered to your property so you could test them out against your needs? Many dealers do that if you haven't.
Have you priced out the 3pt attachments? An 8' heavy duty rough cut mower with 4"-5" cutting capacity will run you in the 6+ grand range. If you need it you need it, but it's quite expensive if you don't NEED it. Cat II implements are much more $$$ than cat I. They are also larger.
Just for calibration, I have 15 acres I live on and an L3410 HST is a nice size. The L43 on up to L50 would also be fine. Much larger and for my land, it doesn't provide return on investment.
jb
   / M-Series Snag!!! #10
See ya!
Ah ha! I figured you likely had plans to add to your acreage. Actually, other than weight, you won't feel that an M series tractor is just too big once you get used to it. I say that about the weight because weight is the only issue with my larger tractor around my house. Like right now when the lawn is pretty soft, there is just no way I'm able to use a 12,000 pound tractor without making a huge mess. My rears are loaded on that tractor, and I'm about to unload them I think. That would put me closer to 10k with the FEL and mower. Even on my other property when doing heavy work, I'm not really sure that a couple thousand pounds is really making that big of a difference or not. I was more thinking of stability on some pretty steep hills, but I don't know.
Anyway, if you look through all the threads here I'd bet that the ratio of people going to larger tractors vs. the people going to smaller tractors is relatively significant. As a matter of fact, I can't recall off hand any thread on here where someone has gone down in tractor size. I'm sure there are some, but not too many. Also, it could get somewhat expensive to move up in tractor size about a dozen times or so if you keep missing by going too small. Besides, if you buy an M series tractor, you'll have more interest in purchasing the additional land, right? :)
   / M-Series Snag!!!
Actually the M7040 is a rather lightweight, small profile tractor for its hp when comparing it to JD5345, NHTN75, and especially Mahindra, etc.
   / M-Series Snag!!! #12
Well, that makes it sound about perfect for you then. You have the power now and you can always add weight later if you find you need more weight for heavy jobs. It's a lot cheaper to add weight than hp.
So, when do we see pics of you sitting on your new tractor with a big smile?
   / M-Series Snag!!! #13
I agree. I bet everyone recommending a smaller tractor has a smaller tractor, not that there is anything wrong with CUTS (unless there may be round bales in your future.) While I think the 8540 would be a bit large (need a big flat bed trailer to haul it due to width) the 7540 would be fine. Kubotas generallly have a short wheel base and are very manuverable. Weight shouldn't be a concern unless you plan on mowing your yard with it (which I doubt). Cat I implements will work on the 7540 and it will fit a standard 16 foot trailer. A larger tractor can do most all jobs a smaller one will do, not vice versa. I have never seen anyone I know say, "Gee, this tractor is just too big. I think I'll sell it and get a compact." Get the 7540, you won't be sorry.
   / M-Series Snag!!! #14
Yep.
I recently moved and need a much bigger tractor now. In fact I need two.
Had I not classed a size up to begin with, I'd really be in trouble.
Scary.
-Mike Z. :)
   / M-Series Snag!!! #15
I don’t know how much of your 16 acres you keep pretty but I think any of the tractors you have mentioned will be to big for those areas. Also don’t know what kind of clearing is required on the other acreage but Ag/Utility tractors just don’t remove stumps of any size well. Sounds like for hay work the tractors you’re looking at would be great. Now hay equipment for haying 25 acres is going to take many, many years to pay for it’s self. If you plan to hay others properties, then you are going to need a serious hauling rig to move that big stuff around. Hay work doesn’t pay that well unless you are doing hundreds of acres.
Personally, I would be looking more toward a backhoe for the clearing and a tractor with 30+ PTO hp to pull a 6’ mower. Then again, I have two backhoes and don’t use them commercially so who am I to talk.
Good luck on the purchase,
MarkV
   / M-Series Snag!!! #16
MarkV said:
I don’t know how much of your 16 acres you keep pretty but I think any of the tractors you have mentioned will be to big for those areas.]MarkV
I don't understand. Is 16 acres not enough space to turn a 7540 around in? Too small to mow with a 6 or 7 or 8 or 10 foot bush hog? I am not trying to be difficult but just how is it too big? I cut the 3 or so acres aroung my house with an M5400 or M9540 (which ever has a bush hog on it at the time.) They aren't too big.
   / M-Series Snag!!! #17
Well of course your right, my Grandfather mowed most everything with an ag tractor and a rotary mower. In my situation I finish mow about an acre and the size tractor we are discussing would do way to much damage with my turf and soil conditions. I should have been more specific, everyone’s situation differs.
MarkV
   / M-Series Snag!!! #18
tydp,
I can turn a NH8970 around in much less than an acre....if it's open field; so 16 acres ought to be plenty for turning a M7540....if it's kept open. But if there's trees, structures, gardens, swimming pools, fences, shrubbery, parked vehicles, and other stuff that people generally crowd onto their homestead; it can get challenging. Constantly watching what the bucket is swinging towards while trying to remember to check where the implement in back is going, gets tiresome. So does fixing what gets hit.
Plus, because of tight quarters, there are some jobs a small tractor can do easily that a big tractor can't do at all.
That's why it would be nice to know more about Chuck's property and plans. All we know at this point is that he plans to buy a big tractor and maybe do some haying.
On 52 acres and doing some haying (square bales), I got by with 35HP & 2WD and felt I was in 'high cotton' with 52HP. Maybe Chuck would find square bales easier to handle at first. If he does get into serious haying (it's always serious when the hay is down and thunderheads start forming), it won't be long before he'll want more than one tractor. If the first tractor was a bit small, it can be relegated to raking, moving wagons and backup duty if the big one fails.
FWIW
Bob
   / M-Series Snag!!!
Here are my planned tasks since everybody's so curious and doubtful:
  1. "Mow" 16 acres with 10' bush hog every 2 weeks. My pasture grows extremely fast and I have no horses, yet.
  2. Pull out 1.5 miles of 50 year old 3-plank fencing, fill in holes, and replace about 3/4 mile with 4-plank fencing.
  3. Remove hundreds of 3 - 4 inch saplings along fence lines.
  4. Plow, subsoil 2 acre garden
  5. Move dirt and general landscaping with 84" hydraulic scarifier box blade.
  6. Excavate (eliminate) 2 acre outdoor riding arena by removing 6" x 1 acre of sandy soil.
  7. Use removed "soil" for landscaping, backfilling, fillin in fence post holes.
  8. Occassionally snowplow 300' ashphalt driveway and 3/4 mile asphalt private road.
  9. Renovate, level 16-28 acres of pasture with 9' lift disc and cultipacker, planting seed with Herd spreader, and spraying fertilizer and weed killer with boom sprayer.
  10. Double the amount of fence and sapling removal if I aquire the extra 12 acres
  11. Hopefully round bailing hay on approximately 2 acres with Vermeer Rebel bailer. This is mainly for hobby, and for the neighbors horses, not for profit.
That's a few of the tasks I have planned. I have little time to spare to spend 40 hours per week on a tractor, mowing 16 acres every two weeks by pulling a 6' mower.
I have driven the M7040, M8540, and L-series. I don't know of many dealers that would be willing to bring a tractor to my property to try some heavy loader work or ground-engaging activities. I do not like the transmission on the L-series. That's just me.
I have a spreadsheet of the dozen or so implements I want to eventually get and don't yet have with exact prices that I have obtained from dealer quotes.
Eventually, once cleared of fences and saplings, my property will be essentially wide open rolling pasture. Now I do have some decent size trees between 6 and 18". I plan to have these removed with an excavator. Total number is approx 50 on the 16 acres. Double that for the extra 12 acres.
I don't plan on getting any other tractor, probably in the next two decades, so I had better be satisfied with the size.
I plan to, at some point, go ahead and obtain approx 200 acres of land in the country. I would plan to keep this mowed and eventually retire and build a small home on it.
Also, I will take it to my inlaws home probably a half dozen times a year for land clearing and brush hogging. They have about 50 acres, partially wooded, somewhat rolling mountainous.
As far as a big tractor on small property goes, why don't you ask Soundguy's opinion. He has a tractor for almost every acre he owns. Has about 12 acres, 9 tractors, largest tractor is 95hp. Just a comparison observation.
Like I said, I have been planning to buy a tractor for about 3 years now. During the first 2 years I had occassionally sat on some tractors and looked at spec sheets. But for the past year I have researched and studied this on a nearly daily basis.
I thought maybe some of this information may help some of you guys that want to know so much about my land and plans and are saying I don't know what I'm doing getting such a "big" tractor.
   / M-Series Snag!!! #20
I think the argument is more in line with the following analogy: if you are using a road vehicle primarily to commute and go to the grocery store, then do you really need an F350 or Hummer? Of course those vehicles can do the job but they are not the most economical or best matched to the primary tasks. If you are also hauling a horse trailer on weekends that is different.
With the tractor, I don't doubt commercial farmers would all have big Ag machines and would use them to care for a 16 acre plot. Glowplug, like most of us on TBN, is not a farmer but a professional and is buying a tractor to maintain his 16 acres of pasture and will also potentially clear an additional 12 acres in the future. He has not really documented any task that is the equivalent of "towing a horse trailer" in the analogy above to suggest that he really needs the bigger machine. No hay work for example. Clearly the M is a great tractor but the question is whether that is the equivalent of buying an F350 just to commute. Dargo pointed out some of the downsides to the bigger tractors, the primary one being weight. Size can be a disadvantage in some situations so that should be in the equation too. I presume the M7040 costs a bit more than an L too.
The "get a smaller machine" crowd (I'm one) is simply arguing that there is nothing he is proposing to do that cannot be handled easily with a 40-50hp CUT such as an L4640 or L5030 etc. Spending the extra $$ on a backhoe for example might actually be more useful for his tasks, current and future, than just adding tractor size/hp.
My final point is that Glowplug mentioned that his dealer just doesn't stock the L's and therefore he was essentially educated primarily about the Ms from the start. As his dealer doesn't even stock or advocate the bigger CUTs, there was an initial bias in his decision making (I recognize this is a bit presumptuous on my part) towards the M. If I recall correctly, Glowplug never owned a tractor before, and would therefore be relying on his dealer (and all the various yahoos here on TBN:D ) for his advice. It is hard to reverse oneself after you've set your sights on bigger and better and spent so much time mulling over details (as Glowplug surely has) but it is sometimes the right thing to do. I'm really just arguing that he should take a clean sheet of paper and reconsider the size issue completely rather than just retreating one step back from the M8540 of his dreams.:)
It will be interesting to see what Chuck decides. In the mean time I am going to hop into either my F350 or Hummer and run down to the corner store to buy some eggs and milk.;)
2016 Dodge Grand Caravan SE Plus (A59231)
2016 Dodge Grand...
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
2017 FORD EXPLORER (A59823)
2017 FORD EXPLORER...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
Forklift (A56857)
Forklift (A56857)
