M59 hydraulics got slow and weak.
   / M59 hydraulics got slow and weak.
rScotty said:
I'm glad you said that. The technical stuff is fun, but it boils down to your needing your backhoe to move faster. That makes sense. Have you timed the cycle times on yours? That might answer all the questions. And for warranty issues timing it would be definite and repeatable. Somebody suggested doing that a while back. Sorry, but I forgot who it was. Anyway it sounded good so I took a stopwatch along with my M59 Kubota manual and timed the various loader and BH cycle times on ours. It was sort of surprising how closely it matched the published specs.
Normally I run at about 2/3 rated speed and less than that for light work. At full rated RPM it feels less efficient because of the boom speed. Of course the problem might be with me rather than the BH, but in my hands it sure slams and throws things around.
Regardless of the RPM, The M59 controls don't seem to allow the BH bucket to move in all directions at once. If it could do all motions simultaneously that would certainly speed up the BH work. Some industrial machines have that ability and I miss it.
rScotty
The full rpm/heat dissipation comment was explained that it is better for the cylinders to cycle with full power rather than being cycled at lower power where 'build up' psi is slower.
I can't believe we are discussing wether an industrial machine should be ran at rated rpm's.
Also, Scotty there are certain circuits that override each other but they can be feathered for full animation of multiple cylinders. That's where the slowness comes in. Flow, flow, flow.
Good to know yours is close to the shop manuals cycle times. I will time mine as well.
   / M59 hydraulics got slow and weak. #143
I have to agree with you Hersheyfarm. I have seen several posts on TBN from members talking about how gently they rev their engines and bragging about keeping their RPM's below 2,000 or some other value in the belief that they are "protecting" their engine. These Kubota diesels are designed to be run and run hard. When I am really working the backhoe I never operate at less than 2,500 RPM and it didn't hurt my B21, B26 nor do I think it will adversely affect the longevity of my L45. In fact I have noticed that when I operate the L45 with the Auto Throttle engaged that if I put my foot into it that Kubota will raise the engine RPM to over 2,500 and I can't believe they would do that if they thought it would hurt their engine. For the record, when I first start the L45 I disengage the Auto Throttle and use the manual throttle gently until the engine has reached operating temperature and then I turn on the Auto Throttle and put the L45 to work.
I have been following you troubles for some time and in fact based on your experience and that of a few other M59 owners I decided not to purchase one and instead bought the L45. I do hope you get your problems resolved soon as I use my machine commercially too and can only imagine the frustration you have been going through. I did encounter slow swing on the L45 once but it turned out one of the levers under the seat had moved and once it was pushed back in the problem was solved.
Wrt hydraulic oil temperature I have never measured mine but I know on the B21, B26 or the L45 after a couple of hours of steady backhoe or loader use there is no way that I could hold my hand on one of my cylinders. In fact when I have had to work on an open station on a cool day for long periods of time I have warmed my hands more than once by holding onto a cylinder to thaw my fingers out.
I hope your dealer gets your problem solved soon.
Regards,
Lauren
Regards,
Lauren
Thanks for the input. And for the record I love this machine. And I would have no problem buying kubota again, they know how to build equipment. This is a unique machine in its size and power, and I think kubota got hit with some kinks on its debut.
To this day I will not use stall guard because i feel it had something to do with pump failure. Auto throttle.. I hope not because it is an awesome feature.
   / M59 hydraulics got slow and weak. #145
I absolutely love the L45 and the HST+ features too. I have done a lot of loader work this summer - I hauled at least 100 six ton loads of fill from my place to my buddies up the road and I have found the Auto Down Shift and Stall Guard to be real time savers. I will let you know if I see any adverse effects as a result of Stall Guard but I am at 225 hours and so far no problems.
The M59 I looked at was an 08 with 550 hours on it and what really attracted me to it was it already had the Laurin cab on it. I could not arrive at a mutually agreeable price with the dealer that had it and my local dealer gave me a heck of a deal on an L45 that had been stuck at another dealers for some time so I went for the new L45 with a warranty instead.
Regards,
Lauren
   / M59 hydraulics got slow and weak. #146
I too use Stall Guard and Auto Down Shift all the time for loader work (usually with the throttle up at 2300 or better for something as hard as loader work). Most loader work can be done in HI-M range with these settings, while digging hard into a pile or bank. The M59 with the 7' bucket is a beast for loader work. Recently I loaded seven or so 12-14 ton loads of wet gravel road base into a dump truck to spread on some new road, took about 2-3 hours for the whole operation.
The HST functions only affect the tractor HST drive, not the hydraulic pumps, although if one is also operating the loader the hydraulic pump will be loaded as well, with maximum load on the engine. If air entrainment is bad enough it can result in cavitation which will destroy a hydraulic pump in short order.
   / M59 hydraulics got slow and weak. #147
where are you drawing the fluid from, the rear dip stick?
ill try the same with my m59 tomorrow
From the fill hole right beside the dipstick. I warm mine up for a few minutes and that's all it takes to se the bubbles.
   / M59 hydraulics got slow and weak. #149
That's how we've all been taking the samples, but there's a problem with that method. By all means do the test, but until we figure this out be cautious about what you see. It would be better not read too much into it just yet. I've been thinking about the science of our sampling method. So much "entrained air" just seemed completely wrong to me. What I pulled out of my sump simply is not consistent with how well my M59 hydraulics are working. Not just the M59 - I don't see how any hydraulic system could work with so much so-called "entrainment". Something's wrong here. So I've been thinking about what might have caused it. And I've come to the uncomfortable realization that there's a mistake and that I'm one of the ones that started it. All because I didn't look carefully enough at what I was seeing. Some of my initial assumptions were wrong. Could be that I'm the guilty party here.... :-( ...........ugh..........
Thanks to TbarD and then to Google for getting my mind working. It turns out to be well known fact that all hydraulic fluid normally contains about ten percent of dissolved air (by volume). That means that even the perfectly clear hydraulic oil in our photos actually contains quite a bit of air. The air is dissolved in solution and not visible. So the fluid looks perfectly clear.
And we know from physics class that any combination of reduced pressure and increased temperature will cause dissolved gases to form into bubbles. In fact, it turns out that I've done quite of a bit of this sort of experiment and somehow forgot just how a surprisingly little pressure difference will start fluids boiling. You can even boil the difficult ones - like ice water or infused epoxy - by using a cheap hand vacuum pump. Forming bubbles is not a gradual linear process; it is a step change. For example, we all know that at standard temperature and pressure water boils all of a sudden. Lower the temperature a few degrees and no bubbles. Lower the pressure a few PSI and boiling starts again. Think about pressure cookers....and about frothing gasoline as you fill your tank.
When we draw a sample from the rear dip stick hole on our tractors we do it by pulling the oil up with vacuum. That lowers the pressure on the fluid substantially. Add that lower pressure to a transmission oil that is a little bit warmer from being run and maybe a little bit entrained from normal pump action and simply drawing up a sample could be enough of a pressure change to cause the normal dissolved air to come out of solution in the form of bubbles....What I'm saying is that without a doubt some part of what we are calling "entrained air" is nothing more than an artifact of how we are collecting the samples. We just don't know how much we are causing. Might be near nothing and then again it could explain it all.
Bottom line: I believe we are making a mistake. The way we are collecting the oil sample is causing some part of the bubbles which we have been calling "entrained air". We need to be drawing the samples at normal operating conditions. And not by using a vacuum or syringe.
Enjoy!
rScotty
   / M59 hydraulics got slow and weak. #150
Scotty:
I was just using my BH yesterday and was thinking how well it worked. I quickly dug a drainage trench and then ripped out a large stump in about 1/2 hour. So my though is that my system is working as it should. It will be interesting to see if I get the same results.
I understand your analysis of the sampling method. It could very well be the problem. I'll do the test and report the results. Also, I have a lighted bore-scope, of sorts, I may stick that down in the sump to see what I can see.
Tanker Trailer (A59230)
Tanker Trailer...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2020 KENWORTH T680...
2015 Peterbilt 389 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 389...
Peterbilt 377 Semi-Truck (A56438)
Peterbilt 377...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
