MF1540 or MF431
   / MF1540 or MF431
Do you think the 1540 is capable of pulling the type of mower needed to cut hay? It was mentioned earlier that factory remotes are available; is that all that's needed for this type mower?
Gary
   / MF1540 or MF431 #22
The type of mower that has been talked about, I believe just needs one remote. You will need two before everything is done or everyone else does. /forums/images/graemlins/grin.gif I think that it would do just fine with a drum mower. I don't know about the other types on this tractor. I have a 1440 but have never mowed hay with it. spb1971 might know how a 1540 would handle a mower.
   / MF1540 or MF431 #23
I would suggest you either go with the 431 or if you like the style of the 1540, move up to the 1547. I think the 1540 would handle it to a point but if you were to get into heavy conditions you really need more HP.
   / MF1540 or MF431 #24
I'll also add to JerryG's wise suggestion to definitely go with 4WD (or MFWD). I have three tractors, ranging from 28 - 73 hp, and the two with 2-wheel drive only are relegated to light chores, like raking...and ....raking, and occasionally..raking.
Even bushhogging or cutting hay and especially plowing, 4wd is such a necessity. And I should add - in my experience, a 4wd will pull as much as a 2wd tractor with 25% more hp than the 4wd (weight being similar - let's not talk about those 20 ton avery's and rumely's). Not to mention the impact the front wheel drive has on FEL work...
oh and for many balers out there now (4X5 and larger), you need a good 60 pto hp to run 'em efficiently..
   / MF1540 or MF431
Thanks again for the help!
I think I'll go with the 1540, 1525 loader, auxiliary hydraulics. I'd love to go with the 1547 but size restrictions and budget won't allow it. Later on I'll look at a mower and rake it can handle, and leave the baling to someone else.
Gary
   / MF1540 or MF431 #26
I really thing that you will like the MF 1540. When you get it let us all know.
   / MF1540 or MF431 #27
Post some pictures as well. Glad to see another member of the Massey family!
   / MF1540 or MF431 #28
If you ever plan on doing any square baling with the tractor, get the 431. The plunger action on the square baler will rock the 1540 back and forth and that would be uncomfortable for the operator. The 431 has enough mass it won't make any difference.
   / MF1540 or MF431
Here it is leaving my pasture on it's way back to the dealer; never got it off the trailer. It had a hydraulic leak where the loader lines connect. I guess I'll try it out Monday.
For some reason no pic. I'll try again.
We'll try this one...
   / MF1540 or MF431 #30
Bigger picture!
Sorry to hear about the leak, you would think they would check ALL that over. Just like what happen to me, get the tractor and the guy wanted to show me how the mower worked, well no shear pin... I guess the other guys played a joke on the guy that delivered my tractor and took the bolt out, it was funning to see the guys face when nothing happen when he hit the PTO.
Is your loader bucket on backwards? I have never seen anyone haul with a loader like that.
   / MF1540 or MF431 #32
Ok that pic is better, the smaller pic just looked as if the bucket was on the other way.
Yes I would very bothered that you had a leak on a new trator.
By the way... What do you have going on in that other picture?
   / MF1540 or MF431
Second pic shows House, Barn, Paddocks, and the '48 Ferguson...
   / MF1540 or MF431 #35
Very nice!
Just wondering, did you ask to have your rear wheels set out that wide? Again just asking nothing wrong with it, it will had about 4"+ to the rear track.
   / MF1540 or MF431
It came that way, but actually I didn't know there was an option? What are the pro's and con's?
   / MF1540 or MF431 #37
Nice ride! Are you going to have a pull contest between the two tractors?
   / MF1540 or MF431 #38
</font><font color="blueclass=small">( It came that way, but actually I didn't know there was an option? What are the pro's and con's? )</font>
I'm not really the person to ask. I can think of one con and one pro.
Con... Tractor is wider, maybe will not fit where it would of before.
Pro... Wider is better to "help" stop roll over (lessen the chance).
Take a look at my pics and see if you see where it would be better to have the wheels set "in" or to keep it the way you have it. My tractor is at its inner most setting.
   / MF1540 or MF431 #39
my manual said there are four positions the wheels can be set at. i think they setup mine at the widest one also.
   / MF1540 or MF431
I can't help wonder which one will be standing in another 58 years...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
2015 FORD F-250 XL SUPER DUTY EXT CAB TRUCK (A59823)
2015 FORD F-250 XL...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58214)
2011 NORAM POWER...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
