Wow! Looking good. Looks like you primed a still somewhat assembled structure in your last image. Any reason to stop disassembly there?
Battery box assembly, not front axel support.
Upon furthee scrutiny iy appears that the bolts are only protecting the threads and not holding anything in place. I think...
Like Soundguy, I also thought you meant the front axle support, which is a solid (and heavy) cast steel piece. Now that I know you meant the battery box assembly I can say that it was disassembled as much as possible, without cutting the welds. The bolts were left in place to protect the threaded holes, and so I could prime the bolts at the same time. Leaving bolts in place also reduces the possibility of losing them or losing track of where they went..
I hope to someday fix mine up that good. I cant wait to see the top coat and all back together. Thank you for sharing.
Thank you for taking the time to explain. If I lived nearby I drive you nuts with questions and you'd be looking to get a restraining order...
Note that special tools and techniques are required to fully disassemble/reassemble the oil pump.
Do you have the special tools and techniques? If so where did you get the tools and where did you learn the techniques?
