Jtullis13
Platinum Member
Thanks Careyo63 & California. One more thing I forgot to address. I have the PTO overrun clutch on my 2210d that Fredrick's put on, does that make a difference with either tiller, the rs1400 or US model?
No the tiller will be slowed down as long as it's lowerd into the ground. The overrun clutch comes into play mostly from the inertia from a mower. There is nothing to slow it down in turn without a overrun clutch the mower will turn the PTO drive shaft causing it to turn the rear wheels.Thanks Careyo63 & California. One more thing I forgot to address. I have the PTO overrun clutch on my 2210d that Fredrick's put on, does that make a difference with either tiller, the rs1400 or US model?
Hard to say it just depends on how it's set up. The top link bracket is set up to push the tiller out and up to were a top link would basically just go up and you may run into a problem. So many variables with different brands. The 650$ could end up costing 850$ having to buy longer ams longer/shorter Dr.shaft or even both. Then the tiller itself may have problems or going to have problems with worn out parts,tines Etc.. I would start with giving Fredricks a call and go from there. At least your know that it will work and is setup for your tractor properly. I had problems getting mine setup Yup!! gave me the wrong drive shaft LOL.. So at least you know they will stand behind it and make sure you get or have everything you need.
So I called Fredrick's today and was told that a 4ft tiller is $650, a 4.5ft is $725, & a 5ft is $850 and it wold cost around $400 to ship it to me, so I guess I'm not sure what to do. That's a lot of money when you add in the shipping. I would really like a 5ft tiller that is made for my 2210 but $1,250 is a lot to spend! What does anyone else think? Any one from that area coming to Nebraska or Iowa that would want to make a few dollars? I would pay you but to $400 though.
Not Fremont California. I live in Fremont Nebraska and as someone has said "middle of nowhere" is somewhat correct. So the availability of yanmar tillers are non-existent. So maybe I just need to spend the $400 on the shipping
