Nimco part numbers
   / Nimco part numbers #11
   / Nimco part numbers #12
Your welcome TJ, I am glad it all worked out for you. For others in the future-can you take pictures and list any adapters you needed?
   / Nimco part numbers #13
I have a leaking o-ring on a Nimco control valve for my Agco ST35 with SL46 FEL. The oil leaks from the joystick base plate when the bucket is curled. The AGCO parts books lists a couple Nimco controls as being used on the SL46: the CV-112, CV-422, and CV-432. MY valve has a plate with the number 2S-40272 and a serial #219029. The base of the valve has 1M-4132-2 stamped in it.
Question: How do I interchange the numbers I have to a Nimco assembly number in the CV-XXX format.
you need a seal kit of a part number # 4s-40320 Agco # 71512160
if Agco doesn't help you can go through IFP - 763-252-1181
   / Nimco part numbers #14
I hate people that spam!
   / Nimco part numbers #15
Hey guys, after mowing for a few hours today, I noticed that the valve is hot! I can touch it but it seems too warm for comfort.
Is it because I put the adapters on the valve? sae 10 to sae 8 to fit the new valve???
I know the valve is set at 2000 relief pressure do I need to change that? and if so how do I?
Any help would be appreciated.
Thanks
   / Nimco part numbers #16
I have the same problem with the Nimco valve 2S-40272. I am a new member and I sure do need some help. I understand that the 9-7401 control valve from surplus center will work as a replacement for the 2S-40272 valve. I am not sure about the adapters for the hoses to connect to the 9-7401 valve.
I am asking anyone to please advise me on this. Thanks
   / Nimco part numbers #17
JJ, My name is wpettit, would you please look at my post from yesterday about the control valve on my 1246 MF loader and email me a answer. I am knew to this and
am not sure how to navigate. thanks,eddie
   / Nimco part numbers #18
This is the valve you posted. The ports are SAE-8
https://www.surpluscenter.com/item.asp?catname=hydraulic&qty=1&item=9-7401
When you order, just tell them what you have now, and they will send the valve with the fittings, or order only the valve, and go to your local hyd shop and they will help you set up the valve with the correct adapters.
You need to be able to ID the hose ends you have now, JIC, NPT, etc.size.
Look through this site, and you will educate yourself
http://www.discounthydraulichose.com/
http://www.discounthydraulichose.com/category_s/55.htm
   / Nimco part numbers #19
JJ, Thanks for the info on the valve. Eddie
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A56438)
2016 KBH...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
2010 CHEVY SILVERADO 3500 HD PICK UP TRUCK (A59575)
2010 CHEVY...
2021 Deere 331G (A53317)
2021 Deere 331G...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
VOLVO EC460CL EXCAVATOR (A58214)
VOLVO EC460CL...
