post hole digger
/ post hole digger #1
nedco
yanmar 1500
Purchased Yanmar 1500 and 4' bush hog, does good job on small jobs around the farm. Used post hold digger, tractor shook a lot but did acceptable job.
/ post hole digger #2
Welcome to TBN :welcome: - My post hole digger is not my favorite implement, more likely my least favorite. It's not too accurate and bounces around too much. One day I'm going to work on getting a better (longer) point put on the end of the agar bit. Hope that will help but I have too many rocks and roots, I guess.
/ post hole digger
I agree, the PHD is not a favorite but necessary at times. A friend with a large tractor came over and drilled several holes for a project. My Yanmar shook a lot but the holes are OK and as deep as those with the larger tractor, however I had to raise and lower several times to prevent auger lockup in the dirt.
/ post hole digger #5
Ditto, the PHD is not my favorite attachment. I found I have to drill my holes in the Spring. I had no trouble then, when the ground was still soft from the snow melt. Later in the summer the ground is like rock and it just doesn't do a thing. One hole I had to get drilled and the only way was to run a hose to the spot and let it trickle all day while I sporadically drilled.
2017 Nissan Sentra SR Sedan (A61574)
2017 Nissan Sentra...
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
New/Unused Landhonor Tree/Post Puller (A65583)
New/Unused...
Kuhn FC400RG (A60462)
2018 Ford Escape SE SUV (A61574)
2018 Ford Escape...
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
