Problem with concrete floor in a quonset shop bulding 24/30
   / Problem with concrete floor in a quonset shop bulding 24/30 #11
Thats a lot of work congrats on getting it done!!!
   / Problem with concrete floor in a quonset shop bulding 24/30 #12
I put the chairs under the rebar just ahead of the pour.
We poured today..12 yards.
There is a thunder storm brewing now..sure hope it has dried enough to survive it with no damage.
We have it tied down because of the wind.
As long as it achieved initial set, the rain will actually do the concrete some good. Keep it wet for a week or so by spraying with water and covering with plastic will help it cure well also.
Sent from my LGL35G using TractorByNet
   / Problem with concrete floor in a quonset shop bulding 24/30 #13
Nice work, keep those photos coming.
We have the floor poured.
I will let it cure for a few days,then move the building onto the floor and anchor it down.
Side walk will have a small curve and tie into the apron in front of the door. (next pour)
   / Problem with concrete floor in a quonset shop bulding 24/30 #15
Looks great. What did you do with the buried container?
Eddie
Eddie
Eddie
Left it in place. We collapsed and cave in the top and filled it with the broken concrete. After we set the building we will push all the rest of the concrete in and I will fill the hole up with top soil. After it rains on it, it will settle and I will keep adding dirt as needed until it quits settling.
   / Problem with concrete floor in a quonset shop bulding 24/30 #17
Where is-was the entrance to the storm shelter?
It had an under ground hall way that connected the shelter to to an entry from within an old 2 story house that burned down about 25 years ago. Then the mobile home was installed at the end of the under ground hall way, but never was connected to the entry.
That hall way was also collapsed and will be filled in the same as the rest of the holes.
Under ground hall way
It also had a concrete slab covering it. It had also sunk in over the hall way.
   / Problem with concrete floor in a quonset shop bulding 24/30 #19
Nice save. Most folks don't realize that a shipping container has zero support except on the corners.....many have collapsed under just 2' of soil.
That is so true. About 1/2 of one side had collapsed inward due to the dirt side caving in on it..
294 (A52706)
294 (A52706)
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
Snorkel Uno 41D 4x4 Articulating Boom Lift (A59228)
Snorkel Uno 41D...
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
2023 John Deere 333G for Parts (A56438)
2023 John Deere...
