Rear wheel seal on YM2000
   / Rear wheel seal on YM2000 #41
Not talking about sliding off with heat, just sliding the new one on with heat. I would use car docs suggestion of removing the old one if your not going to remove the axle housing. You could definitely harm your bearing by heating right next to the bearing.
I was planning on cutting it out witha tiny cut off wheel or making a grrove then spreading it with a chisel.
Then heating and using a pipe or something to set it flush. I have been worried about doing anything as that bearing is there.
I need to clean up the axle tube so that i can mount the carrier gasket cleanly. The "glue" or whatever they use in the VN places is awfull and sticks like crazy. Its hard to scrap with a razor. I could barely wire wheel it off the carrier plate without several passes. But i am worried to use the wire wheel on the axle flange as i am worried about wire and bits going in the bearing even though i layed a rag over them and covered them. That and my splayed out wire wheel with stray wires, im worried may hit the bearing cages.
   / Rear wheel seal on YM2000 #43
Not sure what you mean by "set it flush". I'm thinking it goes right up against the bearing. That may be what you are talking about. In any event, if you heat the new one, take some welders gloves you can slide it right against the bearing. Hold it for a few seconds with something and your good to go. Don't heat it till it turns blue. Somewhere around 250 degrees and it will slide right on.
   / Rear wheel seal on YM2000 #44
A little 320 sand paper on the axle will help a lot also and some 90 wt on the surfaces it will likely drive on w/o any additional persuasion. fwtw I use schd 80 pvc sometimes as drivers its cheap and its clean beats finding a pipe in the iron pile.
Remember spray oil is your friend! I always start a day or so if I can ahead of attempting removing something spraying stuff letting it do its thing. hth
I been spraying this one with oil as well as the bearings to keep a light film of oil on it as there exposed now.
I did not realize 250F would do it and i would be able to move it with welding gloves!!!! Thats good news.
You were correct, by drive it flush, i meant flush to the bearing race.
Im gonna go cut and whack on it today when i get home after i put a bit of heat to it. Parts should be on the porch when i get home today according to hoyes site.
   / Rear wheel seal on YM2000 #46
Clemson you might try this first before using the cut off wheel-to further illustrate my procedure in 1 dimensional internet haha take a sharp chisel and set it at right angle to the collar (have it running the direction of the axle) and strike it and turn the axle 90 degrees and strike again and so on a couple times around and the collar will be stretched and will move easily. I have done this as long as I have been working on cars we all do it that way. hth
The cut off wheel method is for hard metals or difficult ones fwtw same end result stretching the collar just different way about it. Hard metals will simply break at the cut soft metals will stretch.
Will try that, although the only chisels i think i have are for an air hammer. I guess i will use those. I am following what your saying, im my Young weak mind i dont see how that will streach the soft collar? Streach the outside of it but the inner diameter i dont see it? Not saying this does not work, cause you clearly have done more of this that me.
On the other had i can see how scoring it and then chiseling it will streach it. I have cut half way through plety of things and streached them to remove them or split the bolt or nut or whatever.
Wow, cant beleive we have gone 5 pages on this so far!! Clearly you can see i like to talk!! Anyone finding this thread should have no question where to start!
   / Rear wheel seal on YM2000 #48
It works real good just be patient keep re-striking the same places as you turn the axle the grooves will get deeper and that is what moves the metal you dont have to be using super hard blows either.
If its a hardened steel you will need to cutoff wheel it you will know if it wont dent.
I use a cut off wheel on inner bearing races and WITH SAFETY GLASSES ON chisel them they break real easy.
edit: I dont think air chisels will work with a hammer they may be to springy and not heavy enough to transfer the energy needed? I may be wrong but I wouldn't use mine for this I know that. I have a 3/4" square chisel about 10" long I use and it gets the job done pretty quick. fwtw
I know we had a thread on this, but with these paper gaskets. What was your method of sealing with a paper gasket. Was it just the paper and no silicone or thin coating of silicone and paper?
I always have put paper and thin coats of silicone on both sides?
   / Rear wheel seal on YM2000 #50
I use either paper or glue never both as a rule.
If I have no choice but to use glue and paper at the same time for instance- reusing one thats stuck on and still useable I may glue it or a situation a gasket wont stay put I only glue one side and I try to do the side that is the roughest surface.
Reason being is glue is a lube sotospeak and will cause gaskets to squish out at the bolt holes not good. This is not 100% a sure thing but is the way I reason out each situation, if a gasket is thick and the flanges are thick also probably a person could glue both sides just fine but you get the jist I hope.
2013 Nissan V8 Titan (A57148)
2013 Nissan V8...
Ford Engine & Transmission (A57149)
Ford Engine &...
250 Traffic Cones (A57454)
250 Traffic Cones...
12 X 20 CAR PORT (A58216)
12 X 20 CAR PORT...
SD Lanch SDLGC100 Crew Electric Golf Cart (A57149)
SD Lanch SDLGC100...
LOT: (6) Ratcheting Chain Binders (A59076)
LOT: (6)...
