Refueling effort
   / Refueling effort #11
Easiest and cheapest method I've come up with is called a Han-D-Pump from TSC. Sells for $12.95 (at least it did when I bought mine 3 years). Hook it to the plastic five gallon can, set the can on the running board, and pump. Takes about 90 seconds to fill my little NH if it is empty. Had to replace the fuel line on it last year after the original deteriated. I think I spent $6 and got a little longer hose, but other than that it has been fine. I have a 15 gallon barrel and a couple of barrel pumps but this works easier w/o having to move the barrel around and no mess. I may buy a second 5 gallon can though so I don't have to buy fuel every week. 2 cans would last me almost 3 weeks in the summer.
OK, found it on TSCs website. I guess it is up to $13.89 now. Tractor Supply Company - Han-D Fuel Transfer Pump
   / Refueling effort #12
:eek: Well I have a novel way of doing this--or at least it has not been mentioned yet. I just swing into the BP station when I am on my way to or from church. Last time I put in 15 liters--must have been almost bone dry. (I need to check how much that tank holds.) (That means that I put in right at 4 gallons [3.96] which means that fuel here is $6.67 a gallon) :( :eek: ouch!!! I am glad that the little 3 cylinder is thrifty on fuel!!
Mike
PS. It holds 16 liters or 4.2 gals
   / Refueling effort #13
:eek: $6.67 a gal JEEZ LOOEEZ I thought $3.65 a Gal was a rip :eek:
   / Refueling effort #14
I have a 16 gallon steel drum and a rotory hand pump from Harbor Freight ($30). When the drum is empty, I thow it in the back of the truck and head out for the Off Road Diesel pump 6 miles away. Once I get back i slide the drum into the FEL and set her back down next to the shop where it will sit until I burn up 16 more gallons. :D
   / Refueling effort #15
I would do somthing of the like adam but i dont have a truck yet ;) my fueling situation will change drastically when i am able to nab a nice farm truck :D Most of the goodies I need I have to get a truck to haul. so untill then Im stuck a hauling.
   / Refueling effort #16
I fuel my tractors from a pair of hundred gallon aluminum tanks on a trailer. It's proven to be very handy, and one of my better creations. The toughest part of the entire thing is hooking it up to my truck on my own. I can do it, but it takes me a few tries.
Here's a thread that I had on how I made it and why I did what I did. Allot of the things that I did came from the suggestions and advice that I received from here on TBN.
http://www.tractorbynet.com/forums/projects/47762-fuel-tailer.html
Eddie
   / Refueling effort #17
"I fuel my tractors from a pair of hundred gallon aluminum tanks on a trailer."
My fondest hope is to get to the point that I use my tractors enough to make that the solution for me, too.
When I bought my old backhoe I got two five gallon fuel cans. As luck would have it the style they are makes them easy to use; one will balance on the loader frame and I can rotate it one-handed while guiding the spout into the tank with the other hand.
I had figured if it got to be too often that I had to go for more fuel before the end of a workday I'd buy a couple more cans. I had no idea how thrifty the old three cylinder Ford would be. If there's not room in its fifteen gallon tank for five more gallons at the start of a day I won't need to add fuel before quitting time. And if I top off the tank at the start of a day there's rarely room for five gallons at the end.
Wm
   / Refueling effort #18
I keep an old piece of a towel or cotton rag between the fuel cover and fuel cap. I place that on the hood of the tractor. Then hoist myself with 5 gallon fuel container up onto the platform of the tractor, with aid of steering wheel, container in left hand with right hand on steering wheel. Sit container on towel/rag. Open fuel cover. Get kerosene syphon bought at TSC. Insert syphon into container. Remove fuel cap. Pump syphon until it keeps going. Lift syphon when tank is almost full.
Ralph
   / Refueling effort #19
Usually, I do what Ralph just described...the siphon method. Only I use an old length of fuel hose and the time honored method of sucking on the hose to get it started.
A little off topic...but good info about siphoning...
Through the years, I have siphoned gas from my truck into 5 gallon jerry cans for the mower, atv, weedeater, etc. I discovered that the newer trucks, (gas), have a check valve which discourages siphoning. I believe the check valve's purpose is for safety...to prevent fuel from escaping in the event of a rollover. However, if you use a fairly narrow, flexible line, (like vinyl), it can be pushed past the ball in the check valve. I don't know if the newer diesel trucks also have the valve...
   / Refueling effort #20
I have a 16'x20' shop inside my pole barn. I made the ceiling/upper level floor joist extra stout. I then bought one of those 300 gallon clear plastic fuel grade containers that sits up there. I then got the right fittings to put on a spin on filter and 15' of hose with a nozzle. I get it filled about 3 times a year by the local co-op and it works great. No electric, no pumps, just gravity. I have less than $100 in the setup and have used it for 3 years now.
Chris
2023 Kubota L6060HST Compact Utility Tractor (A56436)
2023 Kubota...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52709)
2003 LEEBOY L150...
2020 Caterpillar 259D3 Compact Track Loader Skid Steer (A55973)
2020 Caterpillar...
INBOARD DRIVE (A58374)
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
2015 VERMEER RTX450 TRENCHER (A58214)
2015 VERMEER...
