Ripper teeth?
/ Ripper teeth? #1
Suess
Minnesota
I have a couple of streets that get so hard the heavy pull type grader won't cut in. I'm thinking of building a ripper bar using shanks found on box blades less the box blade. How would these work on hard gravel streets. I could build it with alot of weight if needed. I see agri supply sells the shanks for about $14 each. I don't need to go very deep but need to brake up the gravel a bit so I can work with it. I was thinking 3 shanks 25 to 30" apart not sure how many a 7610 Kubota will pull or if the shanks would stand up to the other tractor a 80 hp 4wd. Any advice and or suggestions would be appreciated.
/ Ripper teeth? #2
Check out the shanks on a pulverizer. They are simply angle cut flat bar, which should be thinner than the tip of a shank.
They would wear down quickly on gravel, but would be cheaper to make, if you have the tools, than buying ripper teeth.
my two cents.
ron
/ Ripper teeth? #3
I was able to do pretty much what you want with my BX and box blade rippers. It worked well but is slow rough work. Rough, because , I found, on bulletproof baked clay and/or with gravel encased in clay, you have to get the rippers to chisel the ground to start ... it won't really rip till you bust thru the surface. I had to tilt the box way forward so the ripper points were near 45° when contacting the ground. I had to take a few passes in-line with the road ... it may have cut in 1/4" is all. Then, I would make several passes doing a zig zag (sine wave) pattern. The rippers would start hooking on the slight cuts made previously. The chiseling action and zig zag, at a crawling speed, really seems to have done the trick. BTW, the chiseling action, especially on embedded gravel, will drive you insane after a few hours. Once you get down a couple of inches it will really go faster though. My box blade only weighs 430# ... I think the job would have been easier if I didn't have a baby tractor and if I had a 4000# blade. Attached is a pic showing, very subtley, how the ground is starting to break up after a lot of scratching. After taking this pic, I was able to rip the whole thing 6-8" deep.
Cheers!
/ Ripper teeth? #4
Whatever you do, don't pull them with your 80 hp tractor! Mine is only 55hp and didn't slow down too much when I hit BIG rocks and BIG roots. See picture.
Of course these are not the ones from Agri Supply. I bought them to replace these. We'll see how they hold up. If you don't get too much resistance, like a giant rock or big root, they should hold up better. However, I did get some bending (not breaking) when I pulled slightly at an angle, instead of straight ahead. There is no support sideways and they give. Always lift your rippers when turning. My sideways pulling was a result of tilting the boxblade way up to create a decent angle for cutting my gutters. This results in one lower leg being way up in the air and the other down. When this happens, the boxblade was not sitting "square" to the tractor anymore and that's how I bent them. Their breaking off was a result of big obstacles.
/ Ripper teeth? #5
Like I said earlier, I bought the Agri-Supply ones to replace the broken, bent ones. Although their design is different, with the hole through them instead of a slot, I still wanted to add support to REDUCE their bending and breaking. I'm going to give this a try by adding 5/8" thick side and back supports for them. This picture shows them tacked in place, ready to weld. They are in the retracted position but will extend down about 4" to 6" when ripping. I would recommend you doing something like this to support them in your project.
I'm right in the middle of a project to "beef up" and improve my boxblade. This is one of the steps. My plan is to strengthen the boxblade and also add a hydraulic ripper system that is gear driven (rack and pinion). It should add approx 350 lbs. to the blade. Some of it is really tough to get it all together at camp, and make it work! I'll post pics when I'm done.
/ Ripper teeth? #6
Hi Rob! Neat project! We are talking about tractors with 25HP or less. Can't say I've heard of anyone tearing off shanks with our size tractors ... and I've snagged some pretty big stuff ... but I guess it's possible.
Keep up the great work.
Cheers!
/ Ripper teeth? #7
Back on topic, I have long contemplated a separate ripper bar, as opposed to the standard box scraper implementation. My thoughts, in line with Rob's, is the ability to add full length gussets to the back of the shanks, if needed, to control bending, breaking, flexing of cheap shanks. Most of us are stuck with cheap shanks. When you don't have to allow for the shanks being retracted thru the box blade tube, there's a world of possibilities ...
/ Ripper teeth? #8
I made what you are describing using some shanks that were given to me.
I used a 26" length of 4" X4" sq tubing 1/4" wall and cut slots on 2 faces to accomodate the shanks and then capped the ends with 1/2 flat that had cat 1 pins installed.
I then added a pair of 1/2" X 2" flats predrilled for the Cat 1 upper in center of my 'ripper'.
The rig looks like a "T" adapted for CAT 1 3-pt. with the shanks inserted in the slots.
This is used on a 20hp MT180D and performs very well ripping up compacted gravel and tough clay.
Bigger roots kinda act as an anchor as the MT is not all that heavy.
I have also used successfully yanking modest stones that pop up in the spring thaw.
Basically quite a useful tool.
/ Ripper teeth? #9
I believe landpride has exactly what you arew wanting to build. if it's not landpride it's Woods. It is a scarifiar bar with rippers only and it has a quick hitch built onto the rear of it so you could hook up a boxblade or other item quickly and still have your scarifiar bar.
/ Ripper teeth? #10
I've bent the bajeepers out of 2 teeth and ripped the tips off of three with 30 HP and a 5 foot box. I have had luck with heating them up and bending them back so I haven't had to replace them yet.
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2021 KENWORTH T680...
2021 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Equipment Trailer (A59230)
1986 Eager Beaver...
2016 Dodge Journey SUV (A59231)
2016 Dodge Journey...
1998 Ditch Witch 3700DD 4x4 Ride-On Trencher (A59228)
1998 Ditch Witch...
BUYERS PREMIUM & PAYMENT TERMS (A59908)
BUYERS PREMIUM &...
