Slow leak in tire
   / Slow leak in tire #11
with a leak this slow.. I doubt he will find it easilly.. I think I might unload the tire than air it then look for the leak.. I bet that rimguard don't move thru a small hole as easy as air would...
tire would be easy to manage then too.. after leak found and fixed, reload tire.
soundguy
   / Slow leak in tire #12
I have the same problem and found this (I have not tried it):
Hydro-Seal is a flat preventative specifically formulated for water-filled tires. The same time-proven technology used in MULTI-SEAL Heavy Duty is used in Hydro-Seal to prevent 90-95 % of job stopping flats in ballast-filled tires. Hydro-Seal is compatible with calcium chloride, anti-freeze or water-filled tires and will prevent air loss from slow leaks in the bead and rim areas of the tires. Additionally, Hydro-Seal will protect against flats due to multiple punctures in equipment utilizing ballast tires
Web Site
MULTI-SEAL CORPORATION Hydro Seal Tire Sealant
   / Slow leak in tire #13
Dear Sir
I presume you have liquid filled tires, so the actual volume of air is alot less than a regular tire. So any loss of air is going to be amplified. I supported the axle and with the valve at 12 oclock I replaced my valve stems with stainless spring valves. Silly idea try parking with the valve stems down and check, also get a gauge that can handle liquid fill as it is very hard on regular gauges.
Craig Clayton
   / Slow leak in tire #14
heck.. even the 'wet' gauges don't wast long if your ballast is corosive..
soundguy
2014 Kia Optima Sedan (A56859)
2014 Kia Optima...
Case Welcome Saw Sign (Orange) (A57454)
Case Welcome Saw...
2020 DRAGON ESP...
1998 Homemade S/A 12x6.5ft Trailer (A56859)
1998 Homemade S/A...
2007 Chrysler Aspen SUV (A56859)
2007 Chrysler...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
