Slow leak in tire
   / Slow leak in tire #11
with a leak this slow.. I doubt he will find it easilly.. I think I might unload the tire than air it then look for the leak.. I bet that rimguard don't move thru a small hole as easy as air would...
tire would be easy to manage then too.. after leak found and fixed, reload tire.
soundguy
   / Slow leak in tire #12
I have the same problem and found this (I have not tried it):
Hydro-Seal is a flat preventative specifically formulated for water-filled tires. The same time-proven technology used in MULTI-SEAL Heavy Duty is used in Hydro-Seal to prevent 90-95 % of job stopping flats in ballast-filled tires. Hydro-Seal is compatible with calcium chloride, anti-freeze or water-filled tires and will prevent air loss from slow leaks in the bead and rim areas of the tires. Additionally, Hydro-Seal will protect against flats due to multiple punctures in equipment utilizing ballast tires
Web Site
MULTI-SEAL CORPORATION Hydro Seal Tire Sealant
   / Slow leak in tire #13
Dear Sir
I presume you have liquid filled tires, so the actual volume of air is alot less than a regular tire. So any loss of air is going to be amplified. I supported the axle and with the valve at 12 oclock I replaced my valve stems with stainless spring valves. Silly idea try parking with the valve stems down and check, also get a gauge that can handle liquid fill as it is very hard on regular gauges.
Craig Clayton
   / Slow leak in tire #14
heck.. even the 'wet' gauges don't wast long if your ballast is corosive..
soundguy
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
Pace American MW8516TA2 T/A Enclosed Concession Trailer (A56857)
Pace American...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
2014 AMERITRAIL TUGGER TRAILER (A58214)
2014 AMERITRAIL...
Toro z turn (A56859)
3 Row Twin Row Renaldo Planter (A53317)
3 Row Twin Row...
