Snow Attachments Snowblowers vs PTO HP
   / Snowblowers vs PTO HP #41
There are many different types of snow too. Fluffy snow, dry snow, packed in drifted snow. Sometimes we get 3 foot drifts that you can walk on top without snow shoes.
   / Snowblowers vs PTO HP #42
So true. Has to be a big difference in the weight of what is being thrown by the blower depending on the moisture content and density of the snow.
It seems like the impeller rotating through and lifting the snow fed to it by the auger would use the majority of the horses on a blower.
   / Snowblowers vs PTO HP #43
Don't know, it does sound like a lot of blower for the HP. Let us know how it works out please.
If you go to the Puma website, the recommended PTO HP is 20 to about 45. I looked at very nice Puma 72" before I bought the Woods snow blower (which is 30 to 50 PTO HP for the 74" unit). The Puma was nice, but the Woods was $600 cheaper and works quite well behind my (30 PTO HP) Deere 4400.
The Woods is a heavier machine...always had good luck with Woods equipment, so I stuck with Woods.
But that Puma was a nice machine too!
   / Snowblowers vs PTO HP #44
I am not sure if this is sized right as I just got it new this summer. The tractor is a Kubota B2920 HST (21 PTO HP) with a FEL and the blower is a Pronovost Puma 72.
The dealer sized it as said that the 2920 will handle it and told me to try it for the first couple storms. If I am not happy I can have the next size down (Puma-64) no questions asked.
I thought it was large for the tractor at the time and just put it on the other day and still think it is large but I have been surprised at how much heart this little unit has.
Your Thoughts
Al
I have the Pronovost 64 on my L2250 with 21 HP at the PTO and it throws snow like crazy. Your dealer seems to want you to be happy which is a good thing; sounds like great customer service. The 72 seems large for your tractor, but try it out and go from there. My 64 is plenty of size and power for my applications. In fact any bigger and I believe I would have less maneuverability. Good luck and here is hoping we get plenty of the white stuff to play with!
   / Snowblowers vs PTO HP #45
Tks for the positive feedback on the blower Deerslayer.
You are the first person on the forum that is running the Pronovost blower. Not to say the same HP also. Not many seem to have this brand but people that have looked at them like the style and workmanship but think they are to expensive. For me it was a package deal so cost was a small factor as I plan to keep it for many many years.
Yes it is a good dealer to work with. He was a bit lower than other dealers and gave his best price out of the gate. He also took my old tractor, front mount mower and blower back to his lot and sold it for me as a package unit. With no commission.
Not many will do that these days.
Al
   / Snowblowers vs PTO HP #46
I think you'll like the big blower. MOST snowfalls won't max it out. For that one per year, go slower. Hydrostat is THE way to go for blowing.
I have a 72 on my L3940, and K only says to put the 64" on (no way!). Same situation, though quite a bit bigger tractor.. =)
   / Snowblowers vs PTO HP #47
I only use the blower on DEEP snow because I can do it so much quicker with the blade.
   / Snowblowers vs PTO HP #48
In shopping for snowblowers I've been looking at every brand out there. I found a great price on a Farm King 60". My rookie question...it calls for a minimum of 20 PTO HP. Kubota says my 2620 has 19 PTO HP. Is that enough to be worried about or should I be OK?
Farm King's next size down is 50" and the width of my tractor footprint is 49". That seems a little too close.
   / Snowblowers vs PTO HP #49
In shopping for snowblowers I've been looking at every brand out there. I found a great price on a Farm King 60". My rookie question...it calls for a minimum of 20 PTO HP. Kubota says my 2620 has 19 PTO HP. Is that enough to be worried about or should I be OK? Farm King's next size down is 50", and the width of my tractor footprint is 49" wide. That seems a little to close.
I wouldn't worry about it. Tractordata says your 2620 has over a thousand pound lift at the 3ph, the Farm King 60" weighs 470lbs. It takes a certain amount of total work energy to move a given amount of snow, the power determines how fast you can deliver that energy total. The horsepower recommendation is based on a lot of assumptions. That 60" wide times some height of snow times some density of snow at some rate of feed. Lets make up numbers and say 50 horsepower can feed 200 lbs of snow every 1 second, then a 25 horsepower tractor can feed 200 lbs of snow every 2 seconds, (or 100 lbs of snow every second). Follow? The power required (and speed you can travel) will vary for every snowstorm as the snow hieght and density (wet snow/dry powder varies).
   / Snowblowers vs PTO HP #50
Agreed, especially if you have a hydrostatic drive.
I know at least one person that regrets getting a blower just barely wider than his wheels.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 John Deere 304L Wheel Loader w/ LM90 Worksite Pro Bucket (A56438)
2020 John Deere...
2019 LOAD TRAIL 35+5 GOOSENECK TRAILER (A58214)
2019 LOAD TRAIL...
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
2019 ALLMAND MAXI-POWER 25 GENERATOR (A58214)
2019 ALLMAND...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
