Thoughts on Alumaloy/Duraweld/WizardWeld?
   / Thoughts on Alumaloy/Duraweld/WizardWeld? #11
I used the stuff a couple times, once on a decorative piece that fell over and broke, fixed close enough but zero stress, second is still going but took way too much time and experimenting. Metal has to be VERY clean and very evenly heated, some joints might look good but are weak...
   / Thoughts on Alumaloy/Duraweld/WizardWeld? #12
that stuff has it's place. Like everyone has said it's all in the prep. The metal needs to be completely oxide free, stainless wire wheel and acetone, or alcohol to clean. Prep it like you would if you were TIG welding a pressure vessel lol otherwise it doesn't work that great.
   / Thoughts on Alumaloy/Duraweld/WizardWeld? #13
Same as welding any material, clean works better. Any time you weld aluminum, it has to be very clean even when using TIG or MIG so I would not expect the low temp solder to be any different.
   / Thoughts on Alumaloy/Duraweld/WizardWeld? #14
I can't find the exact video anymore but the one I watched on Youtube from a guy in the UK showed that it was a surprisingly solid connection when done right (Durafix Easyweld, available in Europe but apparently the same product). He attached a piece of aluminum at 90* to an aluminum channel and it took some significant use of a BFH to delaminate it. Again, not something to be used for mission critical structural fastening but it certainly seems like more than a useless gimmick.
Also, it seems like some of these come with flux in the rod.
Anyway, I guess I should just try it. I'll check into the alternative products mentioned above.
Rob
Played with HTS 2000 worked OK- haven't bought any since getting a Tig for Aluminum
when done correctly pretty strong
Vid shows several repairs including fuel tank, transmission housing, engine accessory bracket, stripped threads
HTS 2000 Aluminum Repair - YouTube
They have a new 2nd gen version that is composed of 9 ingredients claims to be better than others, I have not tried it.
Not to be confused with Alumaloy, Alumaweld, Alumarod, Durafix, Aladdin 3 in 1, or any other first generation rods most of them consisting of 3 alloys. HTS-2000 is a unique stand-alone product, Comprised of nine alloys that cost more to produce and through exhaustive testing led to this superior advanced technology. HTS-2000 has an elongation of 10% in 2 inches (rather than the standard 3% like the first generation rods listed above) which makes HTS-2000 3 times more flexible and stronger than any of its competitors. It also easily penetrates past impurities that lay below the metal痴 surface which may be impossible to penetrate with competitors materials. Also unlike the first generation rods HTS-2000 does notrequire steel or special cleaning brushes. All of this means not only a more expensive manufacturing process with new technology but also superior quality (this is the best brazing rod you can buy anywhere at any price) direct to the customer, see our testimonials and video and it will be easy for you to choose HTS-2000 as your #1 choice.
   / Thoughts on Alumaloy/Duraweld/WizardWeld? #15
My BIL,, who, in fact knew nothing about welding,, had 20 all aluminum jon boats at his marina,, this was in the early 1970's,,
He stopped in a welding shop one day, and asked what was the cheapest way to weld aluminum,,
the counter guy sold him a pound of 14 inch coated aluminum arc welding rods,, 1/8" rods,, IIRC,, kinda like a 6011 steel rod, except it was for aluminum,
After trying to arc weld with them, (that was a TOTAL disaster on the thin boats!!) he decided to try the oxy-acetylene torch.
Well, he simply gas welded with the coated aluminum rods, and the oxy-acetylene torch,, the weld could not have looked more professional,
He said it was no different than welding steel with steel filler metal,
he never took a boat to anyone for repair after that,
   / Thoughts on Alumaloy/Duraweld/WizardWeld? #16
I can only think of one time when I've needed to weld aluminum.
   / Thoughts on Alumaloy/Duraweld/WizardWeld? #17
This is true. Aluminum stick electrodes are better for brazing than stick welding. 3/32 makes a nice bead.
   / Thoughts on Alumaloy/Duraweld/WizardWeld? #18
In 1978 a welding supplier left me some flux cored aluminum rods for brazing that he wanted me to try. Using an oxy-acetylene torch I welded up a butt joint in some 3" aluminum pipe and it was as good as a TIG weld. I dont recall the name though and never saw them in any welding supply catalogs after that. They were similar in design to flux cored lead solder but they were stronger than the aluminum. We cut straps from the pipe and bent them using a standard ASME bending jig. I sure wish I had saved that info on those rods.
One thing of note is that I quarter rolled the pipe out while staying on the top quarter so I cant say how they would be in all positions.
   / Thoughts on Alumaloy/Duraweld/WizardWeld? #19
You can still get those flux cored aluminum rods from Weldcote Metals. If you look at their website they are under "point of purchase" They are kinda nasty though. They will eat the box they come in and the shelf they sit on. Work pretty good though if you can stay out of the fumes.
2006 Case 445 Skidsteer (A59814)
2006 Case 445...
4 Inch Stargrip (A57454)
4 Inch Stargrip...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
Kubota 72in Bucket with Tractor Attachment (A57454)
Kubota 72in Bucket...
excavator trenching bucket- one bucket per lot (A56436)
excavator...
Preliminary Listing / Full Catalog Coming Soon! (A53317)
Preliminary...
