Trailer choices
   / Trailer choices #61
megaboz said it right about weight ratio with no brakes on trailer. Due to limited budget, I have opted not to upgrade my current blazer towing the bota in 16ft trailer. I added weight distrubuting bars and sway control due to short wheelbase of truck which is simalar to your honda. I have driven it without the extra addons, and it can be a white knuckle experience due to idiots on the road. Adding on the weights bars really helps with the braking and balancing. I added the sway when I know the weight is approaching 5k or so in trailer and it really helps.
You can do it in a pinch with your pilot truck but heed others if not me. Get brakes, you won't be sorry.
   / Trailer choices #62
Just another vote here for dual axels and brakes and a wooden deck...
5500K or 7000K
I had a steel dump trailer that I used to haul my B series and it would slide all over the place if things were not binded down like a huricaine was coming.... Be safe and do it right the first time...
As for length, 14 would probably work, you'll be happier with 16 total flat deck or a 14 +2 beaver tail. (what I'm using now)
Good luck
   / Trailer choices #63
I found something for you:2009 Load Max 36 Ft. Tri-axle Gooseneck Trailer *LOTS OF EXTRAS*
Just to bring things back to the posters reality, the OP wishes to haul a BX1860 with FEL which is, at most, in the 2000 to 2100 pound range total weight with a length of 11 feet and he estimates he'll trailer the unit a couple times a year. The tow vehicle is a relatively light duty SUV with a max GVRW of 4500 pounds.
Inferring from a couple posts I get the impression he wants to spend about $1500 dollars so that limits his options and pretty much eliminates aluminum, dual axle/brakes from the equation. At this point there are only a few options available and key is keeping the entire towing package as light as possible so not to tax his SUV's braking system excessively and not to infringe excessively on the vehicle GVRW rating in an effort to maximizie towing comfort and safety.
From my perspective the choice of trailer is fairly obvious, a 12 to 14 foot long, 5 to 6 foot wide, single 3500# torsion axle, steel trailer. To shave a few more pounds from the tare look for a flat deck design with no side rails.
   / Trailer choices #64
I realize maximizing the amount of what you spend and what you get is a big concern these days, but spending a few hundred dollars for brakes to me is a small price to pay to be safe. After all how much does a human life cost? What if it was you hit by an out of control truck pulling too much weight? Or with an overloaded trailer that could be handled by the tow vehicle?
There has been a lot of input on here, and most of it is pretty good. Should be more than enough to make a wise decision.
I only paid $2200 for my 18 foot dovetail with brakes on both axles, new.
The only part about the 12 foot trailers, I think you're going to find they have a load capacity of about 2100 pounds (give or take a little).
Depending on how far and where he would be towing it, he will have it pretty well maxed out. So now you have a 1000 lb trailer, 2100 lbs loaded tractor for 3100 lbs, with a tow vehicle that only weighs about 4500 lbs, the weight ratio isn't very good if he is going to be towing long distances, which was never really specified, it does/could make a difference. If it is towed long distances, it could be hard on the brakes of the tow vehicle. If it is going to be towing down steep hills that aren't paved, the trailer brakes are going to save his life with that weight ratio.
Personaly, now this is my preference, I don't like using a trailer that is nearly loaded to the max. Too much wear and tear.
I think this topic has been beat to death. I belive everyone here has pretty much said the same thing fo rthe most part. Some think the dual axles and brakes (at least on one axle) is over kill and others think it is a necessity.
Metal or Wood? I love the wood, I love replacing it every couple of years because it rots, twists and snaps under the weight. Metal, I love it too because it can be slick as snot and it rusts, but a can of paint and a can of Duplicolor bed liner will fix that.
   / Trailer choices #67
So mow4fun you've been fairly quiet lately, have you decided it's safer to justy hop on the tractor and drive it to its destination:D or have you narrowed down your choice of trailer?
   / Trailer choices #68
I don't know about mow4fun, but I am now afraid to use mine for anything and will now contact someone from Megamovers the next time I need to transport anything.
   / Trailer choices
Good idea, just drive it there, hmmmm...
Well, I appreciate all the different views and opinions and it got me thinking more and more.
Basically, I need to haul the tractore maybe 2 times or 3 times per year max for a distance of 15 miles. There could be one trip per year where I might do which is about 100 miles, this might be an occurance of once every few years. When I haul it, it might be with the FEL or the Chipper but won't be both which sets the weight at about 2200 lbs max at haul time.
I decided that trailer must be minimum 12 feet long but 14 feet would be better. Single axle would do the job but could max the trailer GVWR, dual axle is better and insures that I am not worried about maxing the trailer. SO, I am looking at both and depends on the deals. 6 feet or 7 feet width.
Brakes are good to have but would require additional work on the truck which in turns increases the investment including additional cost for the trailer. If I can find a good condition used trailer with brakes then might be worth it but not the goal with a new trailer.
I am looking for a Utility or Car Hauler trailer at this point, I think either would do the job but paying a lot of attention to the weight of the trailer. I am checking ebay, craigslist, and few dealers around me in NJ and PA. There are few out there in both new and used that could be a good choice. The thrill of the hunt goes on. :)
   / Trailer choices #70
I am in NJ and the truck is a 2010 Honda Pilot AWD.
Here is the info I got. A 2010 Pilot AWD has a max tow rating of 4,500#. As for NJ here you go.
Maximum Speed Limit: 55
Maximum Dimensions for trailer:35'L x 8'W x 13'6"H
Maximum Length with Trailer:50'
Minimum Weight requiring Separate Trailer Brakes:3,000
Trailer Equipment Requirements:
Safety Chains:Y
Brakelights:Y
Taillights:Y
Clearance Lights:N/A
License Light:Y
Turn Signals:Y
Reflectors:Y
Flares:N/A
Breakaway Brakes:Y
Tiedowns:N/A
Two Trailers:N
Insurance:N
Wide Trailer Permit Phone Number: 609-633-9403 Agnt: 800-257-9003
Basically what its saying for NJ is you need brakes on any trailer over 3,000# and a brake-away kit along with the standard lights, safety chain, ect.
As for brakes or not brakes you must have them in your state. I sell trialers for a part time job and deal with this all the time. If you were to have a accident and you were towing over 3,000# (trailer plus cargo) your insurance company is going to run from you and leave you hanging. On top of that you would get a citation for no brakes. Its the law that any trailer over 3,000# must have brakes in NJ. Plain and simple.
As for saving money its will not. It will wear out the brakes on that little Pilot ASAP and you will be spending it one way or another.
Chris
UNUSED X-STAR SKID STEER TREE SPADE DIGGER (A51243)
UNUSED X-STAR SKID...
2015 FREIGHTLINER CASCADIA DAYCAB (A52472)
2015 FREIGHTLINER...
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
2012 Hyundai Sonata LIMITED (A50324)
2012 Hyundai...
UNUSED JCT QUICK ATTACH BACKHOE DIGGING ARM (A51244)
UNUSED JCT QUICK...
2020 John Deere 160G Excavator (A47384)
2020 John Deere...
