What are the "weak spots" on your tractor?
   / What are the "weak spots" on your tractor? #11
Re: What are the \"weak spots\" on your tractor?
John:
Sometimes you worry me. /forums/images/graemlins/grin.gif
   / What are the "weak spots" on your tractor? #12
The weakest spot on my Kubota is that big ol' NUT right behind the steering wheel..... /forums/images/graemlins/smile.gif
<font color="blue"> Could they make it in a 65 pto hp model scaled up to match! That would be perfect. </font>
Ken, I knew I liked you, right from the start. /forums/images/graemlins/smile.gif
   / What are the "weak spots" on your tractor? #14
I forgot about the step. I painted mine with spray on bed liner in black. Adds traction and looks great. I will take a photo later, it's dark out and snowing /forums/images/graemlins/frown.gif
ksmmoto
<font color="blue"> Sometimes you worry me. </font> /forums/images/graemlins/grin.gif
Daryl, only sometimes? Dang, I'm slipping! /forums/images/graemlins/laugh.gif
<font color="blue"> The weakest spot on my Kubota is that big ol' NUT right behind the steering wheel..... </font>
Dwight, mine has the same design flaw - care to join me in a class-action lawsuit? /forums/images/graemlins/smile.gif
ksmmoto, great idea for the step, I think I'll do that as well.
And Kubotafan, I'm pretty sure you're not really mad at me, but just in case, I want you to know that I more than forgive my 'bota for her weak spots, as I hope I am forgiven for mine. /forums/images/graemlins/tongue.gif /forums/images/graemlins/smile.gif
   / What are the "weak spots" on your tractor? #16
Lights are my biggest complaint, I haven't been able to figure out with the loader on what they are useful for?
I wish the four wheel drive lever was up on the fender like the NH's, I am continually hitting the lever knocking her out of 4wd.
Where the joystick is does limit your abiltiy for using that side to mount/dismount the tractor.
Other than these items, I haven't found too much else. Overall I am very happy with my machine.... Maybe a post next on weak spots on our wives, I could fill a page... Just joking of course.... /forums/images/graemlins/grin.gif
   / What are the "weak spots" on your tractor? #17
That is the biggest complaint my tractor has.
Egon /forums/images/graemlins/grin.gif
   / What are the "weak spots" on your tractor? #18
I echo the complaint about the quick attach bucket popping off. I looked at my friend's Bobcat and the pins engage much farther in the holes. Based on another posting from this site I added several flat washers under the springs of the quick attach levers to cure the problem. It hasn't come off in the last 1.5 years since I made the fix.
   / What are the "weak spots" on your tractor? #19
</font><font color="blue" class="small">( I echo the complaint about the quick attach bucket popping off. I looked at my friend's Bobcat and the pins engage much farther in the holes. Based on another posting from this site I added several flat washers under the springs of the quick attach levers to cure the problem. It hasn't come off in the last 1.5 years since I made the fix. )</font>
Any chance of you posting a shot of that so I can see what you did exactly..?
Pete
   / What are the "weak spots" on your tractor? #20
</font><font color="blue" class="small">( Grill guard. Not the guard itself of course, but the spaces in between. )</font>
On my L3010 I welded in some expanded metal mesh and painted it orange. Worked fine for years, so I'll do the same on the 4630.
</font><font color="blue" class="small">( Tail lights. How I haven't smashed them yet, I do not know )</font>
Since I never drive w/o a rear implement, this has never been an issue for me.
</font><font color="blue" class="small">( Valve stems. Why on earth don't all wheels have stem protectors?? I've knocked 2 off so far. )</font>
The thought of losing a valve stem in the woods terrified me, so I had skidder-style protectors installed before taking delivery.
</font><font color="blue" class="small">( Bucket level indicator )</font> I'm going to remove mine. I just glance at the side of the bucket to tell my position.
</font><font color="blue" class="small">( Loader hoses rubbing on hood. I secured them away from the hood with a spring and zip-tie )</font>
I need to do this too. Do you have a pic so I can see your arrangement?
The other thing I didn't like was the degree of difficulty lowering the folding ROPS. On the L3010 I drilled out the captured nut and replaced the bolt with a hitch pin. On the L4630 I just ground the threads off the bolt so it slid in and out easily. It turned a five minute struggle into a 30 second piece of cake.
Pete
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A60429)
2016 CATERPILLAR...
2019 CAT TL1055D (A58214)
2019 CAT TL1055D...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Kubota L4701 (A53317)
2022 CATERPILLAR 289D3 SKID STEER (A60429)
2022 CATERPILLAR...
