What are the "weak spots" on your tractor?
   / What are the "weak spots" on your tractor? #11
Re: What are the \"weak spots\" on your tractor?
John:
Sometimes you worry me. /forums/images/graemlins/grin.gif
   / What are the "weak spots" on your tractor? #12
The weakest spot on my Kubota is that big ol' NUT right behind the steering wheel..... /forums/images/graemlins/smile.gif
<font color="blue"> Could they make it in a 65 pto hp model scaled up to match! That would be perfect. </font>
Ken, I knew I liked you, right from the start. /forums/images/graemlins/smile.gif
   / What are the "weak spots" on your tractor? #14
I forgot about the step. I painted mine with spray on bed liner in black. Adds traction and looks great. I will take a photo later, it's dark out and snowing /forums/images/graemlins/frown.gif
ksmmoto
<font color="blue"> Sometimes you worry me. </font> /forums/images/graemlins/grin.gif
Daryl, only sometimes? Dang, I'm slipping! /forums/images/graemlins/laugh.gif
<font color="blue"> The weakest spot on my Kubota is that big ol' NUT right behind the steering wheel..... </font>
Dwight, mine has the same design flaw - care to join me in a class-action lawsuit? /forums/images/graemlins/smile.gif
ksmmoto, great idea for the step, I think I'll do that as well.
And Kubotafan, I'm pretty sure you're not really mad at me, but just in case, I want you to know that I more than forgive my 'bota for her weak spots, as I hope I am forgiven for mine. /forums/images/graemlins/tongue.gif /forums/images/graemlins/smile.gif
   / What are the "weak spots" on your tractor? #16
Lights are my biggest complaint, I haven't been able to figure out with the loader on what they are useful for?
I wish the four wheel drive lever was up on the fender like the NH's, I am continually hitting the lever knocking her out of 4wd.
Where the joystick is does limit your abiltiy for using that side to mount/dismount the tractor.
Other than these items, I haven't found too much else. Overall I am very happy with my machine.... Maybe a post next on weak spots on our wives, I could fill a page... Just joking of course.... /forums/images/graemlins/grin.gif
   / What are the "weak spots" on your tractor? #17
That is the biggest complaint my tractor has.
Egon /forums/images/graemlins/grin.gif
   / What are the "weak spots" on your tractor? #18
I echo the complaint about the quick attach bucket popping off. I looked at my friend's Bobcat and the pins engage much farther in the holes. Based on another posting from this site I added several flat washers under the springs of the quick attach levers to cure the problem. It hasn't come off in the last 1.5 years since I made the fix.
   / What are the "weak spots" on your tractor? #19
</font><font color="blue" class="small">( I echo the complaint about the quick attach bucket popping off. I looked at my friend's Bobcat and the pins engage much farther in the holes. Based on another posting from this site I added several flat washers under the springs of the quick attach levers to cure the problem. It hasn't come off in the last 1.5 years since I made the fix. )</font>
Any chance of you posting a shot of that so I can see what you did exactly..?
Pete
   / What are the "weak spots" on your tractor? #20
</font><font color="blue" class="small">( Grill guard. Not the guard itself of course, but the spaces in between. )</font>
On my L3010 I welded in some expanded metal mesh and painted it orange. Worked fine for years, so I'll do the same on the 4630.
</font><font color="blue" class="small">( Tail lights. How I haven't smashed them yet, I do not know )</font>
Since I never drive w/o a rear implement, this has never been an issue for me.
</font><font color="blue" class="small">( Valve stems. Why on earth don't all wheels have stem protectors?? I've knocked 2 off so far. )</font>
The thought of losing a valve stem in the woods terrified me, so I had skidder-style protectors installed before taking delivery.
</font><font color="blue" class="small">( Bucket level indicator )</font> I'm going to remove mine. I just glance at the side of the bucket to tell my position.
</font><font color="blue" class="small">( Loader hoses rubbing on hood. I secured them away from the hood with a spring and zip-tie )</font>
I need to do this too. Do you have a pic so I can see your arrangement?
The other thing I didn't like was the degree of difficulty lowering the folding ROPS. On the L3010 I drilled out the captured nut and replaced the bolt with a hitch pin. On the L4630 I just ground the threads off the bolt so it slid in and out easily. It turned a five minute struggle into a 30 second piece of cake.
Pete
Kubota RTV-X1140 4x4 Diesel Utility Cart (A59228)
Kubota RTV-X1140...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2006 TerraGator 8104 (A56438)
2006 TerraGator...
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2015 Peterbilt 579 T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Peterbilt 579...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
