What can you expect from a plasma cutter?
   / What can you expect from a plasma cutter? #41
The built in compressor is only available in the 110 volt model as far as I can remember. That's the model I have and it worked well on the project that I bought it for and on several occasions since. For me, it's a real advantage to be able to use it away from the shop compressor. It's just one less thing that I have to haul to the farm if I need to do some work there. The only problem with it is its limited cutting capacity of 3/16" but if that's all you need, it'll do a good job.
   / What can you expect from a plasma cutter? #42
can you simply increase your cutting thickness by running on one side, then flipping over and doing from the other side, or does it have to blow thru to the other side to cut ?
   / What can you expect from a plasma cutter? #43
I think the unit the rental was quoted for was this model, Thermal Dynamics Cutmaster 51, like this one on ebay:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3864700021&ssPageName=ADME:B:SS:US:1
Sure looks nice and I've heard nothing but good about Thermal Dynamics. Some places will let you apply a rental toward a purchase too.
Basically 10% of the new purchase price, seems like a common rental charge formula.
If I can get multiple jobs lined up and ready to go and rent it maybe I can get by for now. Better yet would be to find two or three guys in a local area who are willing to split the cost of a rental! Anybody in the Portland Oregon metro area want to talk? I'll provide the compressor, and 220 AC, miscellaneous other tools, drill press, even a metal lathe (but I have to hook it up).
A week is a lot of plasma cutting. If I get everything ready in advance, I should be able to do all I need in one day.
   / What can you expect from a plasma cutter? #44
You want to blow thru.The self contained units I find are weak.A freind of mine has one and it's frustrating to use after having my Cutmaster 50
   / What can you expect from a plasma cutter? #45
I got some how to welding dvd's for Christmas from Northern and I highly reccomend them.I mostly have been self taught and these are very informative.I highly reccomend them
   / What can you expect from a plasma cutter? #46
<font color="blue">Gene, sounds like you have a great set-up. I have read this thread with interest. I don't weld now, nor have any equipment....but a dream of mine to someday get started.
Your cart combo sounds good. I always thought it would be great to have a "welding trailer", where one could be portable. It would include one of those big generator/ stick welder combos....an air compressor, mig welder, and plasma cutter...and place for tanks. Sounds like you have a mini version of that. Could a guy fit all that on one of those small 4X8 trailers?
How's that for a pipe dream....albeit an expensive one. </font>
You just described exactly what I've got! /forums/images/graemlins/grin.gif
Being a little crazy according to some, I've spent way too much on welding equipment over the years, considering it is just a hobby. I finally got tired of having to extract a machine from the tangle of cables, maybe hook up the gas cylinder, weld, and then put it all away later. I had an old tent trailer and stripped it down to the frame. Turned out it was exactly 4'x8' and a 3/4" piece of plywood made a perfect deck for it. I tried a few different placements of all the stuff and came up with an arrangement that is nicely balanced with about 30lbs hitch weight so I can pull it with my quad. Everything is bolted or strapped down and I made a common ground from a length of 3/4" copper water pipe with a ground cable soldered into one end. All the grounds from the machines just clamp to the pipe thus leaving a single common ground clamp for the whole mess.
Total inventory sitting on the trailer is as follows:
-10,000 watt generator - 220V and 110V output, 3 welder receptacles wired up.
-Full size oxy-acetylene tanks
-5 gallon air compressor with blower nozzle and hose for plasma cutter.
-Lincoln Pro-Cut 25 plasma cutter
-Lincoln SP170T MIG welder with gas bottle & regulator
-Lincoln 175A AC/DC TIG/Stick welder with gas bottle & regulator
-usually an angle grinder, gloves, goggles, helmets, vice grips, etc. strewn about
I arranged everything so all the "business ends" are on the same side of the trailer and everything is operated from that side. I keep it parked in the garage as close to the wall as I can so everything is useable at a moment's notice. If I need to go portable, just hook up the quad and out to the field or the neighbors or wherever. The 10Kwatt generator does a reasonable job although the TIG machine makes it work and can pop a breaker if you aren't careful. No real problem though. The biggest problem is that I don't think the axle is rated for the 1200 or so pounds sitting on the frame and it's bowed a bit in the middle. I don't take it on the road anyway, so I'm not too worried.
I don't have a good picture of the setup right now, but I'll try to remember to take a couple in the next day or so and post them here.
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2005 TerraGator 8104 (A55302)
2005 TerraGator...
2009 JACK COUNTY KILL TRAILER (A58214)
2009 JACK COUNTY...
