Whay weight synthetic should i use?
   / Whay weight synthetic should i use? #1
piper
I have recently purchased a Kubota B7800 and i want to use the Amsoil synthetic motor oil. My question is i don't know which one to use for my tractor. Are there any Kubota owners out there that use Amsoil in their tractor?
If so what weight do you use or would recommend.
My tractor has 20 hours on it now and the engine is diesel.
The Kubota manuel recommends SAE30, 10W-30 or 10W-40
above 25 degrees.
Engine oil: API Service classification CD, CE or CF
Thanks in advance,
Piper
   / Whay weight synthetic should i use? #2
   / Whay weight synthetic should i use? #3
This large picture certainly looks like a product endorsement advertisement to me..... /forums/images/graemlins/grin.gif
   / Whay weight synthetic should i use? #4
Piper—I use their 15w-40 HDD&M oil. I feel their series 3000 is overpriced and it is not worth the extra money, nothing really added for the price. Used it (15w-40 HDD&M ) in all my diesel toys since 1997 and works great!
Plus the freeze point is like –45 so pour point is around –20 degrees. Also I think the 15-w40 has a better additive package then a 10-30 or 10-40
If their Series 3000 is so great, compare it to their 15w-40 HDD&M oil and see what the results are.
…Just my slanted pitch.
   / Whay weight synthetic should i use? #6
I agree with gsxr1100 about Amsoil's 15W40 as that is what I am using in my 3130..
   / Whay weight synthetic should i use? #7
a 15w40 is a 15w40 regardless of blend mix if it specs a 10w or 5w use a 5w
   / Whay weight synthetic should i use? #8
</font><font color="blue" class="small">( a 15w40 is a 15w40 regardless of blend mix if it specs a 10w or 5w use a 5w )</font>
So are you stating that a 100% synthetic 15w-40 is the same as a regualar 15w-40?? If so, that is wrong.
I would not use a 5w-30 in a diesel since there is no need and a 15w-40 does have a better add' package. I believe in Amsoil's case the freeze temps are very close so what does there 5w-30 Series 3000 get? Only a higher invoice or bill.
Most diesel oils today are pretty good just know what you are looking for and wha there going rate or price is.
   / Whay weight synthetic should i use? #10
I went with Mobil 1, 10W-30 and added a block heater, I think I am ready for winter now. Good thing, we have 10 inches of the white stuff on the ground today. /forums/images/graemlins/grin.gif
I plan to change oil and filter every 100 hours as per mfg recommendations. With dino oil I was changing every 50 hours the oil and filter.
   / Whay weight synthetic should i use? #11
NY_Yankees_Fan --10 inches so far! You weenie..we only have like 5 to 6 here to far. We WERE to have 12 - 18 but I think the super doplar 10,000 was/is wrong. I was looking forward to plowing the streets with the BX!!!! /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
   / Whay weight synthetic should i use? #12
so ur saying a 15w40 flows the same and has same viscocity as a 5w30 ah? so what the frail do they have viscocity #'s for then if it flows the same as a 5w at low temp it'd be a 5w40.. hmm..
   / Whay weight synthetic should i use? #13
</font><font color="blueclass=small">( so ur saying a 15w40 flows the same and has same viscocity as a 5w30 ah? so what the frail do they have viscocity #'s for then if it flows the same as a 5w at low temp it'd be a 5w40.. hmm..
)</font>
Well I use Amsoil (100% synthetic oil) and at their site it has Series 3000 5w-30 Pour Point (-60) and 15w40 HDD&M is Pour Point of (-47).
So they are within 20% of eachother. Pretty close in my book. It is never that cold anyways. Plus the pumping temp which is more import is -27 min when using 15w-40. I bet that is better then most regular 5w-30's out there.
To close you can go to their site and get the same #'s or just use whichever you need in your climate. Unless you live in ALaska the 5w-30 is a waste.
There are my "frail" #'s. Yippee
   / Whay weight synthetic should i use? #14
So ur saying a 15w40 will flow and protect a engine better at -30 degrees than at 0w-30??? hmmmm... ur about 10yrs ago. most oil companys are now focusing on 0w-20 0w-30 oils not high resistance products. That protect much better than high visc. products.
   / Whay weight synthetic should i use? #15
I never stated that anything about protection just an additive package or fighting acids and some metals and freeze/ pump tempos.
I said in my last post that the freeze temp of 15w-40 is –47 and 5w30 is –60 in Amsoil case. To find pumping temp is like another 20 degree added. S0 it is –27 and –40 respectfully. This is for a true flow temp. As far as protection is concerned, I do not know if you mean the four ball test results or like protection from acids. If you mean the protecting the engine, the 15w40 is BETTER as stated on their website. If you mean from acids (TBN) they are both really close at or around 12.2 TBN
This is not 10-year old data or thinking. It is today and it works like a charm. Many oil manufactures are going 5w-30 and 0-30 for one reason only….called emissions.
This data is using Amsoil’s data sheets since I use it since 1994 (started in gas engines). I am not comparing other oil since it will not be “apple to apple” comparison.
Lastly, feel free to use whatever oil you want. I am not an oil expert just know what I have used in almost 10 years using there stuff. Not the best oil either but it works perfect in my application and again, there is no need for a 5w-30 since the #'s do not show anything great and wonderful in 5w-30 (as posted on the web)
   / Whay weight synthetic should i use? #16
<font color="blue"> there is no need for a 5w-30 since the #'s do not show anything great and wonderful in 5w-30 </font>
Thanks for this information. It's about time for me to order some more oil, and I will be getting the 15w-40. No sense paying 61% more for so little difference.
   / Whay weight synthetic should i use? #17
Not for emmissions i can assure u.. ur pretty well set on ur amsoil brain washing sad to see someone waste away like that oh well..
/forums/images/graemlins/crazy.gif
   / Whay weight synthetic should i use? #18
</font><font color="blue" class="small">( Not for emmissions i can assure u.. ur pretty well set on ur amsoil brain washing sad to see someone waste away like that oh well..
/forums/images/graemlins/crazy.gif )</font>
KubotaBling- Well then, what is the precise reasons then..hmm? Post the data and not some little short post. Well oil expert lets see it.
Again if you re-read my post I said there were other good oils out there. Again read it. It came down to oil weight and not a brand war. I wanted to compare the same product since that is a good comparison to start with.
If you do not like Amsoil then do not use it. It is not brain washing rather then thinking ahead rather then behind. It is amazing that you feel that way and can’t think outside the box mentality. With you thinking we would still be using horse carriages and rotary phones. That is what separates the men from the boys (thinking outside the box)
Lastly, do you really think I care if you use it? I am not a dealer only a customer. I just stated what I used per the post at hand. Please reply to the thread with answers or help rather then posting childish replies.
   / Whay weight synthetic should i use? #19
Amsoil makes a great product, too bad it is not on store shelves. In every independent test I have ever seen the facts don't stack up tp Amsoils advertizing page--tests. In the 4 ball test in a recent motorcycle oil test the Mobil 1, Amsoil and I forget the other came out equal, the Mobil 1 had the highest flash point and the least reduction in viscosity over time, the Amsoil had a better additive package for long oil change intervals, buffers and stuff like that. The tests were incomplete in that they obviously did not cover a full range from each maker. They were all great oils and the differences were inconsequential.The drive towards oils like 0W-20 and such as that is strictly EPA mileage driven. Since most wear on an engine occurs during cold start (a cold start is any start the engine is not already warm) an oil that flows faster and is engineered to provide lubrication under that condition as quickly as possible is a good thing. Such oils are 15W-40, 5W-30, 5W-40 are a good range. I think the 0W-20 might be Okay in Minnesota in the winter but it is a little light for Arizona in the summer.
Why does Amsoil spend so much time comparing themselves to Mobil 1. They make a great products with several lines not covered by Mobil but their stuff is impossible to find. I am not going to buy my oil out of the trunk of someones car. Put it in a store and I will consider it. J
   / Whay weight synthetic should i use? #20
<font color="blue"> I am not going to buy my oil out of the trunk of someones car. </font>
UPS brings my Amsoil. /forums/images/graemlins/smile.gif
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
UNUSED RAYTREE RMBD72-72" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2021 JOHN DEERE 50G EXCAVATOR (A60429)
2021 JOHN DEERE...
2015 CHEVROLET 2500 HD CREW CAB FLATBED TRUCK (A60430)
2015 CHEVROLET...
2004 VE ENTERPRISES 500BBL FRAC TANK (A58214)
2004 VE...
