Where to mount a tool box?
   / Where to mount a tool box? #51
Here's the post that Jtullis referenced. I use lots of Goodwill stuff repurposed to carry tools on the tractors. $10??? ... $5 is my upper limit for junk like this. :D
:thumbsup:
Hey, did you put any drain holes in the bottom of the bags with a plastic grommet should it rain?
   / Where to mount a tool box? #52
:thumbsup:
No. The tractors are never out in rain, almost never outdoors overnight.
(Unfortunately the appearance of both shows they spent years, decades, left outdoors before I bought them).
   / Where to mount a tool box? #53
Figured I would jump in as well.....after researching a number of options, this worked well for me:
   / Where to mount a tool box? #54
LIKE
:thumbsup:
Nice pix resolution. The box is a Husky. Looks durable and it should keep rain out. I do like the clasps on the box as vibration could be an issue. Plus, a good closed box will keep our tiny critters making a nest inside.
For the fire-extinguisher, is that held on with velco straps ????
   / Where to mount a tool box? #55
LIKE
:thumbsup:
Thanks. It stays bone dry and the clasp has never loosened up. The extinguisher mount does have Velcro straps and has worked well for a number of years now. It is actually sold as a holder for a JEEP, but also fits the ROPS nicely.
I also have a "Woodsman's Pal" mounted on the ROPS. Very handy for when the need arises to take care of a small limb,brush, sapling, etc.... (pic from when they were mounted on my old tractor)
   / Where to mount a tool box? #56
Had no idea what a "woodsman's pal" so I looked one up on Amazon!! WOW that's a lot of money for something that just sits on the rops.
   / Where to mount a tool box? #57
I welded a pc of 2x2 angle between the uprights of the ROPS and mounted a tool box on the angle.
enhance
THe problem here would be not being able to see your 3 pt hitch now . I had the same issue and had to move the tool box .
   / Where to mount a tool box? #58
I got one for $4 at H-F. :thumbsup:
18 in. Machete with Serrated Blade
It's come in handy a bunch of times already. Whack things or use the serrated blade like a saw, it does well.
   / Where to mount a tool box? #59
If you look up what a "woodsman pal " is it's a brand with that fancy wood handle and some short looking shaped machete. But same basic tool. The $5 works as well. I have some combi tool thing that's like machete and hatchet I got free I could do the same with
   / Where to mount a tool box? #60
Most of my tractors came with tool boxes, but usually I want a bigger tool box, so I mount a second one.
Once I figure out where it will fit, I bend up some flat bar out of my scrap steel box, and use existing threaded holes in the tractor to bolt it to,
Then it's just a matter of bolting the tool box to the flat bar,
The extra boxes have worked out pretty good for me...
SR
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
2013 GREAT DANE 53FT REEFER TRAILER (A59905)
2013 GREAT DANE...
2008 DRAGON PNEUMATIC TRAILER (A58214)
2008 DRAGON...
2005 GMC Canyon (A57148)
2005 GMC Canyon...
