Why do I need an L3130???
   / Why do I need an L3130??? #21
Recommend the L3130 HST. I started out looking at a much smaller tractor, but after getting comments and advice from TBN, went with the L3130 HST. No major regrets, but there are times when it's a little too big for some of my woods trails - but then nothing is perfect - I mow those with a Honda Foreman and 8HP Bush hog tow behind. Sold my old AC WD after getting the L3130 - it's a pleasure to operate - the WD would wear me down.
penokee /forums/images/graemlins/smile.gif
   / Why do I need an L3130??? #22
When I was shopping. I looked at and test drove a few diferent manufacturers and decided on Kubota. Once a manufaturer was chosen, I had to decide what model. I use the 3pt alot so I wanted a nice 3pt with extendable arms and high capacity, so it came down to a 2910 or Grand L. I planned on doing dirt work, both moving it and breaking it and also live in WV on the side of a hill, so I got the heavier of the two, the Grand L. Trying to stay close to my budget, I got the 3130. I got the GST because it felt more natural than the HST but not as clumbsy as the FST.
If Kubota had made something between the 2910 and 3130, size and weight, I wouldve gone with that instead. The 3130 has prooven to be just a tad large for some of the stuff Im doing but I think the 2910, while Im sure it wouldnt have let me down, would have been a tad small. My Kubota has been top notch as far as qualityand service but If I had to do it all over, I may look a little harder at the midframe Deeres as they would be exactly the right size for me.
For you, there is a huge size difference between the BX and 3130. A good in between tractor for you would be a B7800 or 2910. They arent much bigger in demension than a bx but have alot more capacity.
</font><font color="blue" class="small">( When I was shopping. I looked at and test drove a few diferent manufacturers and decided on Kubota. Once a manufaturer was chosen, I had to decide what model. I use the 3pt alot so I wanted a nice 3pt with extendable arms and high capacity, so it came down to a 2910 or Grand L. I planned on doing dirt work, both moving it and breaking it and also live in WV on the side of a hill, so I got the heavier of the two, the Grand L. Trying to stay close to my budget, I got the 3130. I got the GST because it felt more natural than the HST but not as clumbsy as the FST.
For you, there is a huge size difference between the BX and 3130. A good in between tractor for you would be a B7800 or 2910. They arent much bigger in demension than a bx but have alot more capacity. )</font>
When you say a mid sized JD are you talking about a 4310 or 4410? Are they that much smaller than a L3130? Thanks
   / Why do I need an L3130??? #25
</font><font color="blue" class="small">( The JD 4310 and 4410 are comparable in size. A little different HP. )</font>
The 4310 is very comparable in size/weight/HP to the 3130 but a good in between size is the 4210 at about 500lbs and 6" shorter than the 3130.
I guess I shouldnt discount the Kubota L2800/3400 as options for an in between. I didnt really consider them an option when I was shopping because of the continuous PTO. In retrospect, I could have dealt with it and saved some $$$
   / Why do I need an L3130??? #26
Doesn't Kubota have a 4400 or 4300? I could swear I saw a 4300 on their website, and seen a dealer around her with a 4400. Seems like maybe the 4400 is replacing the 4300? Might be worth a look anyway?
   / Why do I need an L3130??? #27
Hi Ray,
I tried the L3400 4wd dt with a fel. It had a live PTO. I too could have saved over 2500 if I had stayed with the L3400 instead of the L3130 GST, but I like the L3130 better because of the bigger size. I have a LA513 fel on the L3130. I'm not too fond of the GST yet because of the dealer warning me how easy it is to destroy the clutch if I use it very much. I have pretty much dismissed what he said because others on this site have told me they use thier clutch when using the fel and they haven't had any problems.
   / Why do I need an L3130??? #28
Your guess is as good as mine. I've 7.5 acres (no big deal), which was quite rough when I purchased such 4 years ago, with large trees down (hurricane a decade earlier), swampy spots, brush all over and stands of small pines. So, I obtained an L3410 (GST, because I needed the pto power but was way past tired from a 5 speed stick shift in my car to buy another geared shifter). Anyhow, the tractor was underpowered for many things I attempted, most but not all successfully, and now, after 4 years of hard work, every darn weekend, the tractor is overpowered. Basically, when I need to brush/treee cut with a 1100 lbs unit (5 feet wide Woods), post hole dig a fence line, dig out tree roots, box blade a 1000 foot driveway (crown, ditches, etc), the L3410 was "challenged" (being politically correct). Now, with the heavy stuff done, most of the property covered with field grass and semi-groomed trees, my wife had "observed" (OK, she's bitching) about tractor tracks on the lawn when I mow the field grass (now with a lighter duty and sharpened blade 6 foot cutter). So, a smaller/lighter "footprint" tractor would be optimal.
BUT --- most of us (including me) can only reasonably afford one tractor per decade, so ----- the L3410 was, and remains, a compromise.
Sort of reminds me of skiies. I liked to ski moguls, but when it snowed heavily, the powder slopes beckoned. A good mogul ski is NOT optimal for moguls. So, not having the cash for 2 sets of skies, I purchased a compromise "all purpose" set. The alternative was to get a specialized ski, and rent another pair when needed. However, renting another tractor is not easy.
So, figure out what you need, over the next decade, and select whatever tractor is the best compromise - that's life
   / Why do I need an L3130??? #29
<font color="blue"> I'm not too fond of the GST yet because of the dealer warning me how easy it is to destroy the clutch if I use it very much. </font>
I don't know why your dealer would have told you that. The hydraulic clutches in your tractor will out last 10 or more regular clutchs or they seem to. They just don't seem to wear hardly at all.
   / Why do I need an L3130??? #30
Clearance. The BX will not have the clearance needed for your 100 acres. I'm in southern Ohio with plenty of hills and lots of clay / rock. I have the older version of the L3130 the L3010. The weight make a big difference for me traversing the hills / trails. I don't tend all 50 acres, 35 to 40 of it is wooded. But I have trails through most of it. I did not make them. I found it made more sense to hire a dozer for a day or two and just have him make the path. Then I'd come thru and finish it off with the box blade or wear the path down with an ATV.
Hope this helps,
Moon of Ohio
UNKNOWN  SPOOL TRAILER (A58216)
UNKNOWN SPOOL...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59575)
2016 FREIGHTLINER...
Landoll 876C Soil Finisher (A59814)
Landoll 876C Soil...
2018 CON-WAY DOLLY (A59575)
2018 CON-WAY DOLLY...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
2006 Trail King RGN 45ft. Heavy Haul Lowboy Equipment Trailer (A60460)
2006 Trail King...
