Wind Turbine ********. Just opened the mail and seen the plan for three massive units
Status
Not open for further replies.
   / Wind Turbine ********. Just opened the mail and seen the plan for three massive units #41
Duke University just published a study that states Global Warming is more moderate than the IPCC scenarios.
More moderate than the worst case predictions, not the ones with the highest confidence. The paper also is self-published and not picked up by a major journal, which usually says there's problems with it.
Most of the IPCC Scenarios that we hear about in the media are "worst case" scenarios.
Duh, the media loves to sensationalize everything. Why focus on the high probability scenarios when you can scare the crap out of everyone with the unlikely, extreme scenarios. You get more money from both the supporters and deniers if you do that.
I do not believe in the "worst case" scenarios of global warming or that man is the primary cause.
Thankfully, you're not a climate scientists, so your beliefs (like mine) don't matter a darned bit. Among scientists qualified to hold an opinion, anthropogenic climate change is not in doubt. As you noticed, the magnitude of warming is still uncertain.
CO2 is not a pollutant.
Depends on how you define pollutant. If pollution means byproducts of doing things that we need to do which have negative consequences for the environment and us, then the amount of CO2 we're talking about absolutely is a pollutant.
If we put 1/2 the money spent on CO2 reduction into reducing real pollution (NOx, SOx, Lead, Mercury, etc) we would be much better off. An also probably reduce CO2 as a side benefit.
While I agree with you that a whole-system view is more useful than focusing on one specific symptom, CO2's role in climate change is a bigger danger to us and our children than anything you listed.
Our contribution to CO2 in the atmosphere is minimal. About 4% per year.
If our emissions, no matter their size, are measurably stepping on the gas pedal of climate change, they're a problem. And they are.
We are worried about running out of water. Did you know that burning 1 gallon of diesel fuel creates 1.5 gallons of water? All the fuel we are burning is actually adding water to the atmosphere. Isn't that a good thing?
First, your 1:1.5 ratio is off. Someone is doing chemistry wrong. If you do the reaction correctly, 1 gallon of diesel reacts with oxygen to form .99 gallons of water plus a bunch of CO2. While this doesn't really matter due to my next point, it's still worth being correct when possible.
It's still not a good thing. We're running out of potable water in places we need it. The water isn't disappearing, it's just moving to places we can't use it and becoming contaminated with things that prevent us from taking advantage of it. The water produced by oxidizing diesel only helps us if it comes back to the ground as rain or snow in a time and place we need it. If it falls somewhere we already have to much of it (flooding) or if it falls in the ocean, it doesn't help us at all. In fact, the contributions of that water vapor and the accompanying CO2 will just further accelerate climate change making things worse overall.
   / Wind Turbine ********. Just opened the mail and seen the plan for three massive units #42
I agree. One of the big issues I have these days is that everything is so polarizing and each side only presents evidence that supports their claim. I'm more of a moderate, and "fact" based thinker that prefers to look at empirical evidence. If the changes are going to adversely impact some areas, doesn't it stand to reason that the same changes might improve some other areas?
Example: I know this is probably overly simplistic, but if the climate change raises the world temperature and makes some areas too hot for agriculture, wouldn't it stand to reason that areas that were previously too cold, may now have an optimal temperature for crops?
If this happened very, very slowly, there's a good chance we could adapt. After all, the geological record shows lots of climate changes and the animals and plants evolved to adapt to the new environment. The problem is the rate of change. Climate change is happen at a fast (geologically speaking) rate already and we're making it faster, not slower. The real question is whether we, as a species, can adapt to the changing climate at the rate we're causing the climate to change. Sure, everyone in a low-lying coastal area could be relocated to higher ground over time. Can you relocate New York City, London, most of the Boston-Atlanta metropolitan axis, about half of India, and who knows how much of China to higher ground as fast as the storms are flooding places? Who's going to accept the refugees from NYC or Miami Beach? Where are we going to house them. Who's going to pay for all this? Same story for crops. If the Salinas Valley becomes too dry for farming, there might be somewhere else in the world that opens up. How do you get the infrastructure there as fast as we need it to happen so worldwide food production doesn't dip for a decade or more? Where's the infrastructure come from? How are you going to move all the people to the new place? What do you do with all the people who are already there? Who pays for this?
The last question is really the big one. We're living in a world crippled by debt, facing declines in energy affordability, with only higher costs in the future. How are we going to pay for the massive global upheaval required to adapt to a warmer climate as fast as we're causing that climate to change?
Isn't the earth to still naturally warming up since the last ice age ?
   / Wind Turbine ********. Just opened the mail and seen the plan for three massive units #44
We're still in an ice age. The scientific definition of ice age is having any ice at all at either of the poles. We've got ice in both the arctic and the antarctic.
We are only 12,000 years into the 115,000 warm season between iceages. Safe to say there is going to be more natural warming up before the climate cools down again. mankind or not.
   / Wind Turbine ********. Just opened the mail and seen the plan for three massive units #46
All of my life I have been looking at the visual pollution of telephone /electrical poles and overhead wiring along our streets and roadways. I view this pollution as more objectionable than wind turbines although I don't want to see turbines on every ridge-line.
I would like to make the developers of wind turbine projects bury X amount of poles and wiring underground for every turbine they install.
Every windfarm I've seen go up here in Indiana has no wires in the farm. They do eventually connect to transmission lines somewhere, though.
   / Wind Turbine ********. Just opened the mail and seen the plan for three massive units #47
So far all delivery systems have thier unique problems of being up to date. Don't think I'd want to live along side of high voltage transmission line corridor.
Pro'&con's
Aww heck! I spent the first 24 years of my life with a high voltage transmission line running right through our neighborhood and it didn't effect me in the least.... I'm a completely normal human being with no physical or mental problems. Just look at all the completely lucid posts I've made over the past 13 years............
hahahahahahahahaaaaa!!! hahahahaaa!!! hahahahaaaa, haha!!! Ouch! I think I hurt myself. :laughing:
   / Wind Turbine ********. Just opened the mail and seen the plan for three massive units #48
Wow...I'm glad to see some support for CLEAN, RENEWABLE ENERGY--I was getting worried, until I got to page 3--LOL. (In other words, I was beginning to think, when reading so many ANTI-wind posts)...wow...and I actually seek out tractoring advice from these people? :laughing: Obviously, areas of people's interest and expertise varies, but as someone who has studied renewable energy options, for years, it is easy to tell who is possession of FACTS and who is simply recycling BIG OIL, GAS and COAL's PROPAGANDA....
One thing that continues to amaze me by its total absence of discussion, about wind, solar, hydro, tidal and geothermal energy--is that these energy sources DELIVER THEMSELVES TO THEIR RESPECTIVE POWER PLANTS. IOW, there is no daily trucking/rail/pipelines involved (and our country desperately needs a new, beefier, electrical grid ANYWAY, regardless of the power source, so that "build out" should be planned with renewables in mind, to maximize the potential savings involved).
Again...the RENEWABLE (and FAR-LESS CABRON-INTENSIVE) ENERGY, DELIVERS ITSELF.
Kindly indulge me, and think about that, for just a moment, if you please. :) (Because I'm the only one I've ever heard say it, and I think it's a pretty important piece of the total cost/benefit analysis of the life cycle of renewables vs carbon-based energy systems).
That savings, alone, in fuel/carbon footprint/time and labor, is something I feel is an overlooked benefit of renewables that, in and of itself, represents a CONSIDERABLE SAVINGS, of both energy and pollution.
Now...where is my Nomex (flame-retardent) driving suit? :D
My Hoe
We installed 15 kw of solar panels at our home 3 years ago and have been absolutely pleased with our experience. They generate enough electricity to power our home each month. Any excess is fed back into the local grid and is sold by the utility to our neighbors. The utility is only required to pay us wholesale rates for the surplus when we sell our home and/or disconnected our service. Our only maintenance has been a seasonal washing of pollen and dust.
   / Wind Turbine ********. Just opened the mail and seen the plan for three massive units #49
Nice testimonial:dance1:, LAFarm
   / Wind Turbine ********. Just opened the mail and seen the plan for three massive units #50
Wind and solar work , just not very well , that's why the Ontario Gov. has to pay the carpet baggers 10 times as much per KWH as viable producers ---Trevor
   / Wind Turbine ********. Just opened the mail and seen the plan for three massive units #51
Works much better in areas of wind and sun.
But even in those locations gov't faces significant pressure from petroleum lobbyists paid to influence gov't controls set to preserve a market (your purchases) for their petrol.
   / Wind Turbine ********. Just opened the mail and seen the plan for three massive units #52
Wind and solar have been around for a long time. Far longer than the oil/coal type plants.
   / Wind Turbine ********. Just opened the mail and seen the plan for three massive units #53
Just remember your neighbors paid for a big part of that system, not you! You are welcome. HS
   / Wind Turbine ********. Just opened the mail and seen the plan for three massive units #54
I have stood out in the middle of wind farms near my house, in eastern Iowa, and south central South Dakota I have yet to hear noise from the windmills. I hear wind, I hear cars on roads, I hear lots of birds and other things but not the windmills. Where does this thing about noise come from? I have been standing within 200 ft of the tower and there is nothing on the ones I have been around.
   / Wind Turbine ********. Just opened the mail and seen the plan for three massive units #55
The only issue I have against windmills is their economic viability. Without government subsidies there would not be many built. The other big issue is distribution - where there is lots of wind - think plains states - there is not a lot of consumption and typical electrical transmission loses about half the energy it transmits every 1000 miles. Nobody in this country wants ultrahigh voltage transmission so the transmission losses continue.
   / Wind Turbine ********. Just opened the mail and seen the plan for three massive units #56
This is funny.
Neighbors paid for a big part of the grid system too (perhaps more) and will continue to pay for the expansion (dams, transmission lines, nuclear plants, coal burning, petrol-burning, and windmills too). Those who buy their your own eqpt are funding infrastructure expansion, a benefit to "the neighbors" in several ways.
Perhaps most important to the consumer, the electric utilities are forced to be competitive with rates. Because if they charge too much then people will pursue other methods to get power, or reduce their usage.
Currently there seems to be enough fat to pay lobbyists to your gov't to make it harder for consumers to gather their own power. Also theres enough fat there to fund marketing schemes that spread confusion on the matter (radio, TV, forums etc). If there's enough money to pay for lobbying & marketing that ought to tellya something!
Sodo . You can run with the cospiracy story if you want . I can't see why however . The oil companies are not stopping the Almighty from adding new elements to the periodic table. To make solar cells or new batteries lighter, smaller, cheaper, more reliable and safer. We have the batteries, solar cells and electrical conductors we have because they are all there is to work with.
   / Wind Turbine ********. Just opened the mail and seen the plan for three massive units #58
]it is easy to tell who is possession of FACTS and who is simply recycling BIG OIL, GAS and COAL's PROPAGANDA
The greenies have their own propaganda. There are sound scientific facts to back up all side of the arguments to a point. Beyond that is mere speculation. I personally don't think either side is "right" in 90% of their claims. I think anyone who sides one way or the other is mostly close-minded. There should always be a "happy medium" but too many lunatics are in charge screaming "my way or the highway" and shooting for the extremes. There are simply too many actual unknowns to say who is right and who is not. Results of scientific studies are not always facts, they're simply results. People (even scientists) tend to fail to make that distinction.
Here's some propaganda for you: it doesn't matter what we do or don't do as a people, we're doomed. All we can do is do our best in our own lives with the situations provided to us...
   / Wind Turbine ********. Just opened the mail and seen the plan for three massive units #59
You can call it a conspiracy, but its just marketing, lobbying and operating within the bounds of what the citizens tolerate. This is how its all done nowadays. Huge wealth can be generated by manipulating government. Which is always easier if citizens are distracted or confused and certainly while they are divided.
   / Wind Turbine ********. Just opened the mail and seen the plan for three massive units #60
well said
Status
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
2005 CATERPILLAR 420D BACKHOE (A60429)
2005 CATERPILLAR...
2018 JLG 742 TELESCOPIC FORKLIFT (A60429)
2018 JLG 742...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2012 CATERPILLAR D4K LGP CRAWLER DOZER (A60429)
2012 CATERPILLAR...
