Yanmar Models
   / Yanmar Models #1
DeltaWebmaster
Michigan\'s Upper Peninsula
Yanmar wannabe
I was wondering if Brett or others could repost the model number information. Specifically, xx00, xx01, xx10, etc. I understand the first two digits are related to pto horsepower at least losely and the D at the end specifies 4 wheel drive. What confuses me is the specification for power this and shift on the fly that.
   / Yanmar Models #2
YMXX00 are typically 2 cylinders. The exception is the the YM2500, then the YM3000 and up. The YM2700 however is a 2 cylinder. The 00's are all manual transmission, no powershift. Then you have the YMXX01 which is the first compact 3 cylinder series and it too had a manual trans. In the same time frame as the XX01 was the YMXX10. The 10 series had 3 cylinder engines with the powershift transmission. The shifter was located in the normal position. The only 2 cylinders in the 10 series were the YM1110 and the 2210. The next series was the YMXX02. Again 3 cylinder engines, same basic transmission. The YMXX20's were 3 cylinder Powershift models with the shifter on the dashboard. Hope this gets you started.
Brent
   / Yanmar Models #3
I'll look but I dont want to deny Roger his favorite subject. Let him have it Roger!!
   / Yanmar Models #4
Brent...
Would you happen to have a chart you can post showing the Yanmar engine models in particular Yanmar Tractors...? /w3tcompact/icons/smile.gif
Thanks...
   / Yanmar Models #5
models with 4 numbers are grey market tractors, meaning they were not intended for original sale in the US and may not have some required saftey features of US sold models. YM models are older vintage, ususally 70's. F series are later, 80's. The letter D after a model denotes 4 wheel drive. First 2 numbers of a 4 number models, ie, YM 1700, 17 is HP at the PTO. Transmission varies between models. I think this is mostly correct. bw
   / Yanmar Models #6
Unfortunately I don't have a chart to lost. I wil keep looking to make sure though.
Brent
   / Yanmar Models #7
Here is some data from the Best Used Tractors website. I have added some various models over time. The specs are close.
Model** HP** Cyl** Trans** Year ** WT
YM 1100D ** 4 WD ** 14 ** 2 ** gear ** 77-82 ** 948
YM 1300 ** 2 WD ** 16 ** 2 ** gear ** **
YM 1300D ** 4 WD ** 16 ** 2 ** gear ** 75-80 ** 1135
YM 1301 ** 2 WD ** 16 ** 3 ** gear ** 81-83 ** 1124
YM 1301D ** 4 WD ** 16 ** 3 ** gear ** 81-83 ** 1190
YM 1401 ** 2 WD ** 18 ** 3 ** gear ** 79-81 ** 1080
YM 1401D ** 4 WD ** 19 ** 3 ** gear ** 79-81 ** 1168
YM 1500 ** 2 WD ** 17 ** 2 ** gear ** 75-79 ** 1333
YM 1500D ** 4 WD ** 17 ** 2 ** gear ** 75-79 ** 1433
YM 1502D ** 4 WD ** 19.5 ** 3 ** gear ** 81-83 ** 1510
YM 1510 ** 2 WD ** 19.5 ** 3 ** pwr shift ** 79-81 ** 1235
YM 1510D ** 4 WD ** 19.5 ** 3 ** pwr shift ** 79-81 ** 1345
YM F15D ** 4 WD ** 19 ** 3 ** gear ** 83-86 ** 1709
YM 1600 ** ** ** ** ** **
YM 1601 ** 4 WD ** 20 ** 3 ** gear ** 79-81 ** 1587
YM 1602D ** 4 WD ** 20 ** 3 ** gear ** 82-83 ** 1521
YM 1610 ** 2 WD ** 20 ** 3 ** pwr shift ** 79-81 ** 1499
YM 1610D ** 4 WD ** 20 ** 3 ** pwr shift ** 79-81 ** 1609
YM F16D ** 4 WD ** 20 ** 3 ** gear ** 83-86 ** 1907
YM 1700 ** 2 WD ** 20 ** 2 ** gear ** **
YM 1700BD ** 4 WD ** 20 ** 2 ** gear ** 79 ** 1829
YM 1702D ** 4 WD ** 21 ** 3 ** gear ** 82-83 ** 2050
YM 1720D ** 4 WD ** 21 ** 3 ** pwr shift ** 82-83 ** 2072
YM F17D ** 4 WD ** 21 ** 3 ** gear ** 84-? ** 2161
YMG 1800D ** 4 WD ** 21.5 ** 3 ** gear ** 88-? ** 1918
YM 1802 ** 2 WD ** 21.5 ** 3 ** gear ** **
YM 1802D ** 4 WD ** 21.5 ** 3 ** gear ** 82-83 ** 2260
YM 1810 ** 2 WD ** 21.5 ** 3 ** pwr shift ** **
YM 1810D ** 4 WD ** 21.5 ** 3 ** pwr shift ** 81 ** 1808
YM 1820 ** 2 WD ** 21.5 ** 3 ** pwr shift ** **
YM 1820D ** 4 WD ** 21.5 ** 3 ** pwr shift ** 82-83 ** 2314
YM F18D ** 4 WD ** 21.5 ** 3 ** gear ** 84? ** 2183
YM 1900 ** 2 WD ** ** 2 ** gear ** **
YM 2000 ** 2 WD ** 22 ** 2 ** gear ** 75-77 ** 1664
YM 2000BD ** 4 WD ** 22 ** 2 ** gear ** 79 ** 1940
YMG 2000D ** 4 WD ** 23.5 ** 3 ** gear ** 88-? ** 1918
YM F20 ** 2 WD ** 23.5 ** 3 ** gear ** **
YM FX20D ** 4 WD ** 23.5 ** 3 ** gear ** 84-? ** 2416
Model ** ** HP ** Cyl ** Trans ** Year ** WT
YM FX20D ** 4 WD ** 23.5 ** 3 ** pwr shift ** 84-? ** 2438
YM 2001 ** 2 WD ** 23.5 ** 3 ** gear ** **
YM 2001D ** 4 WD ** 23.5 ** 3 ** gear ** 81 ** 2039
YM 2002 (D) ** 4 WD ** 23.5 ** 3 ** gear ** 82-83 ** 2314
YM 2010 ** 2 WD ** 23.5 ** 3 ** pwr shift ** 80-81 ** 1918
YM 2010 (D) ** 4 WD ** 23.5 ** 3 ** pwr shift ** 80-81 ** 2061
YM 2020 (D) ** 2 WD ** 23.5 ** 3 ** pwr shift ** 82-83 ** 2491
YM 2202 ** ** ** ** ** **
YM 2210 ** 2 WD ** 25 ** 2 ** pwr shift ** 77 ** 2083
YM 2210D ** 4 WD ** 25 ** 2 ** pwr shift ** 77 ** 2194
YM 2210BD ** 4 WD ** 25 ** 2 ** pwr shift ** 79 ** 2194
YM 2220 ** 2 WD ** 25 ** 3 ** pwr shift ** **
YM 2220D ** 4 WD ** 25 ** 3 ** pwr shift ** 82-83 ** 2635
YM F22D ** 4 WD ** 25 ** 3 ** gear ** 84-? ** 2458
YM FX22 ** 2 WD ** 25 ** 3 ** gear ** **
YM FX22D ** 4 WD ** 25 ** 3 ** pwr shift ** 84-? ** 2480
YM 2301 ** 2 WD ** 26.5 ** 3 ** gear ** **
YM 2301D ** 4 WD ** 26.5 ** 3 ** gear ** **
YM 2310 ** 2 WD ** 26.5 ** 3 ** pwr shift ** 80-81 ** 1984
YM 2310D ** 4 WD ** 26.5 ** 3 ** pwr shift ** 80-81 ** 2127
YM 2402D ** 4 WD ** 28 ** 3 ** gear ** 82-83 ** 2711
YM 2420 (D) ** 4 WD ** 28 ** 3 ** pwr shift ** 82-83 ** 2723
YM FX24 (D) ** 4 WD ** 28 ** 3 ** pwr shift ** 84-? ** 2623
YM 2610 (D) ** 4 WD ** 30 ** 3 ** pwr shift ** 79-81 ** 2712
YM 2620 ** 2 WD ** 30 ** 3 ** pwr shift ** 82-83 ** 3582
YM 2620D ** 4 WD ** 30 ** 3 ** pwr shift ** 82-83 ** 3813
YM 2820D ** 4 WD ** 33 ** 3 ** pwr shift ** 82-83 ** 3825
YM FX28 (D) ** 4 WD ** 33 ** 3 ** pwr shift ** 84-? ** 3792
YM 3000 ** 2 WD ** 33 ** 3 ** gear ** 77 ** 2557
YM 3110 ** 2 WD ** 35 ** 3 ** pwr shift ** 79-81 ** 2733
YM 3110D ** 4 WD ** 35 ** 3 ** pwr shift ** 79-81 ** 2910
YM 3220D ** 4 WD ** 35 ** 3 ** pwr shift ** 82-83 ** 3219
YM 3810D ** 4 WD ** 42 ** 3 ** pwr shift ** 79-81 ** 2921
YM 4220D ** 4 WD ** 45 ** 3 ** pwr shift ** 82-83 ** 3351
YM FX42D ** 4 WD ** 45 ** 3 ** pwr shift ** 84-? ** 3902
   / Yanmar Models #9
The US Yanmars were numbered by engine horse power. 186D had an 18 hp engine. As a rule of thumb I subtract 4hp to get PTO hp. Roger_scotty says a more accurate system is to subtract 20 percent.
Chris
   / Yanmar Models #10
I have a JD 1250. It has a Yanmar 3t95j engine 40hp at the pto and was made in 1982 or 1983
2013 JLG 8K TELEHANDLER (A58214)
2013 JLG 8K...
1983 Ford 8000 Tandem Grain Truck (A59814)
1983 Ford 8000...
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
Deere 335P (A53317)
Deere 335P (A53317)
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52709)
2015 GENIE...
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
