Need Help with quick hitch/snowblower Kubota BX2230
   / Need Help with quick hitch/snowblower Kubota BX2230 #31
Conflict with the front axle is what blows my mind. Something is just wrong.
Take great care, friend, great care.
I agree, blows my mind too, but literally, the QH is up against the hydraulic steering piston and if that wasn't there, the axle is right behind it at the same height.
   / Need Help with quick hitch/snowblower Kubota BX2230 #33
Yes, I see the manual cryptically shows the schematic of the position of the wedge. I have tried it in that position. I simply don't have confidence in the locking ability of that positioning. Wear through vibration will eventually groove that wedge/frame mating place. This makes little sense to me. Little wonder the manual calls for re-tightening every day of use. Again, this design can be improved upon.
While the design may not be perfect, it is far better than the old design. I have never had mine loosen up. The wedge holds well and the hitch is easy to install. My dealer had the wedge taper up so it would bind in the hitch and never tighten!!!
   / Need Help with quick hitch/snowblower Kubota BX2230 #34
I just took everything apart and tried it all again, this time with a second set of eyes and hands to help... still the same result, unfortunately the QH can't get any closer to the bumper no matter what I try because the front axle prevents it from being brought any closer... I think I have done all I can do at this point, I have cranked the T bolt as hard as I can and nothing wiggles, I can even pick up the front wheels of the tractor with the snowblower and the hydraulics of the QH and it doesn't move... I think my problem last time is it wiggled a little, just enough to have the PTO shaft slip off (I bought the tractor used and I think the PTO shaft may have been for the BX18, maybe it was already twisted or just a hair too short)... I plan on taking it easy and snowblowing at low RPMs - I think I may opt for a rear blower for next season...
I wonder if the 30 series is supposed to use the new style hitch??????????
Every thing is close under there for sure. Is the hitch narrower than the frame by a couple inches??? if so it may be for a BX1500 which had a different frame.
When I went from the 1500 to the 1850 I had to buy a new hitch as the old would not fit the 50 series.
Your dealer should be able to figure this out.
   / Need Help with quick hitch/snowblower Kubota BX2230 #35
My first guess is that somehow you got the quick hitch for the slightly larger B series (B2320, etc.) That would explain the extra distance between the bumper, and hitch, and other differences. It could have been marked wrong, or just have been a simple mistake. I would mention that possibility to your dealer, and see what he thinks.
   / Need Help with quick hitch/snowblower Kubota BX2230 #36
Low RPM is no good.......Get the front hitch problem fixed....the front blower is an awesome tool when you get hooked up right.
   / Need Help with quick hitch/snowblower Kubota BX2230 #37
I'm not sure I'm going to be much help here, my BX2750 quick hitch was the same as bp fick's and I can't tell from the pictures you posted where the T-bolt is going on your hitch. My old mount made sense, in that it locked at the bottom where the mmm levers went, then the whole system was pulled in tight when the t-bolts were tightened...forcing the wedges to pull up on the whole assembly. In the Spring I would have to loosen the t-bolts and then give them each a light whack with a rubber mallet to break the wedges free.....if any of that makes sense. I'm also having a hard time seeing how yours is supposed to work, but agree that you should not have that space. John
Hey Dyer, how ya been?
Your tractor is an 1800, right?? If so the OP has a hitch for a 1500. Mine was like his and my new one is like yours and BP fick.
It may confirm that he simply has the wrong hitch and driveline. The 1500 frame was a couple inches shorter which would explian his short drive shaft and clearance issues.
   / Need Help with quick hitch/snowblower Kubota BX2230 #38
Brilliant!! I gotta believe Kevin is on to something here. Find out, somehow, from someone knowledgeable, if that hitch is for your machine. For sure, the new style would fit properly. It comes nowhere near the front axle.
Perhaps you said, did you get the snowblower separately from the tractor purchase?
   / Need Help with quick hitch/snowblower Kubota BX2230 #39
Well, THAT would never work!!!:D:D:D I think you have two viable options here, but that isn't one of them.
   / Need Help with quick hitch/snowblower Kubota BX2230 #40
Since I moved I use the blower on the 3940 with cab, that pig hogs off 72" per pass while I'm nice and warm:D.
I am adding a pic of the 1500 with blower and the 3940
Hays LT1 Tender (A56438)
Hays LT1 Tender...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
2022 Dodge Ram 4500 Miller 8,000lbs Wrecker Tow Truck (A59230)
2022 Dodge Ram...
2022 BROCE BW260 SWEEPER (A60429)
2022 BROCE BW260...
