How do you put your tire chains on ?
   / How do you put your tire chains on ? #31
beenthere,
That is a good fit, I agree the proper length of the chains makes a big difference.
   / How do you put your tire chains on ? #32
I hand tighten mine (no tighter), and have no slop in the side chains or cross chains.
I would cut the inside side-chain to just the length needed, and the outside side-chain to leave just two extra links for easier hand tightening.
Then there is no need for any tighteners strung between the outside of the tire to take up slop. IMO :D
Good one! The two extra links on the outside side chain has always helped me tremendously when installing.
   / How do you put your tire chains on ? #33
Trygg says you should be able to put a fist between the tire and the side chain. That's about where i run mine, seems to be a good fit, and no, I don't use tighteners or rubber straps either.
Those auto chains are ok. I had a set on a plow truck a few years ago. Not great, but better than nothing. We also run them on all our fire apparatus and ambulances and most oil trucks and school busses around here have them. Again, handy in a pinch, but not as good as real chains.
Thanks ATGREEN.
   / How do you put your tire chains on ? #34
We'll jack a wheel slightly off the ground, try and center and secure the inside of the chain to the tire. Then do the same with the outside of the tire. We finish by using those rubber chain straps with the 2 'S' hooks to take the slop out of the chains.
My Dad said the chains are on right if you don't hear them.
   / How do you put your tire chains on ? #35
How much slack should there be in the chains? How much slack CAN there be? I have been trying put my new ones on for the first time todayand it has been tough considering I am working alone and have never done it before. I guess what I need to know is how just loose they can be before I have to resort to cutting links out to modify their size?
Thanks!
Tirechains.com instructions state to attach the inner hook as tight as possible with no tools. "With no tools" means hand tight. As heavy as these chains are (and I have the 4 link style which are probably the lightest of those tractor chains), one is only going to get them "so tight".
Mine were tight enough to allow a few fingers under the cross links before using bungee tensioners.
After a few trips up and down the drive (in mid-range 3rd gear), the chains settled enough to allow me to tighten a couple more links on the outer hook.
Then, I connected the bungee tensioners.
I had a few overlapping links but I didn't cut them off. I used wireties to prevent them from flopping about during travel.
A couple more trips up and down the drive...well, they seem to be OK to me.
This was my first time installing chains too, BTW.
   / How do you put your tire chains on ? #36
Tirechains.com instructions state to attach the inner hook as tight as possible with no tools. "With no tools" means hand tight. .............
Not to lessen the message, but if the inside chains are attached first, then the tirechains.com instruction makes little sense (to me).
The inside chains are going to be loose if attached first, so seems the instructions would be to just attach the inside chains on the first link. Don't want any loose links rattling around on the inside. If there are extra links on the inside, then that inside chain should be shortened to fit (that might need to happen after the first fitting) so cut off those links. Life will be much better after that.
   / How do you put your tire chains on ? #37
The idea is if you put the inside on first then when you do the outside it will pull the chain towards the outside and tighten up the inside and outside together.
I have a set of Tellefsdal Supers. They have two chian that run around the outside of the tire on top of the tread. They use a forged c shaped clip to hold them together. Both inside and outside have arms to tighten the chains up so I tighten up the inside then outside then go back and see if I can get another link on the inside until the chains are very tight. Tellefsdal says they shouldn't be that tight but I've never used bungees or springs on the sides.
I have found on my truck if the chains are too loose the cross links will roll on the tire and snap.
   / How do you put your tire chains on ? #38
By far the best way to get them on is to lift the tractor with the back-hoe outriggers after you have them draped over the tire!!!! Then remove the hoe and install the blower/back blade
Yup, that's why I bought the Backhoe! It also helps with flats!
I know, I know, I still need to put on tensioners.
/edit - and I got them from tirechains.com as recommended, fairly tight fit, not yet enough link to have to cut off.
   / How do you put your tire chains on ? #39
The way I read those instructions was to fit the inside as tight as possible (but with no tools), then the outer hook. Then run the machine for bout a 1/4 mile, then re-tighten. Even after settling, I didn't get more then another link on the inside...2-3 on the outside.
Chains were pretty snug before I bungeed. Like the OP's question...how snug is snug enough? Well, guess I'll find out.
As far as the "extra" links, it was either tirechains.com or another site recommended wire tieing....makes sense as the chain company doesn't know how worn a customer's tires may be. Also, of course, another tire manufacturers replacement tire might be have a larger (or smaller) circumference, should a tire require replacement. Makes sense to me...
Anyway, the chains don't flop around when operating at 8-10 MPH and nothing has hit the fenders, so I reckon they're OK.
   / How do you put your tire chains on ? #40
If you jack the tire up and keep working with the chains while rotating the tire you can get them pretty tight. I have read it both ways. Some say the chains should be tight and some say not.
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2016 Toro Workman HDX-D Diesel Utility Cart (A59228)
2016 Toro Workman...
2017 Ford F-550 (A55973)
2017 Ford F-550...
2014 F-150 STX (A56438)
2014 F-150 STX...
Butler MFG Water Tanker (A56438)
Butler MFG Water...
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
