Overpowered, overpriced new cars
   / Overpowered, overpriced new cars #101
RobertN said:
My Uncles was gray, with white interior. He did a restoration on it in the mid 80's, stayed gray, but went with black interior. It had the highest output motor 375HP, buckets, console with tach ect.
When I was a year old, my parent got a '63 Impala SS327 4spd, in 1964. For the size of car, it went pretty good...
The only reason dad shied away from the 375hp model was the solid lift cam. He did not want the hassle of periodic valve adjustments. There was quite a difference performance wise between the 350 & 375 hp cars, maybe a little more hp in the 375 than the factory claimed. I have a 327 in my 70 chevelle. Revs quick but not enough cubes to really make that heavy car move. Only making around 300hp or so.
   / Overpowered, overpriced new cars #102
A neighbor had a '37 Ford pickup with a SBC in the mid 70'2. It had a balanced 283 with a 327 crank as it was explained to me as a early teenager back then. Basically made a 302? The motor had a short stroke and would rev up instantly! Sure made that light weight '37 pickup move quick!
One of those little tricks like boring a 318 Mopar 20 over and putting a standard bore 340 master kit in it...
   / Overpowered, overpriced new cars #103
Ultimately, I would like to replace the 327 with a mild 454 or 427 BB, say 450-500 hp but streetable. The 327 would do very well in a lighter body, like a 66 Nova, T-bucket or one of my favorites a '32 Ford coupe. The 327 has a lot of sentimental value to me as it was the first engine dad and I built together. It is .060 over, about 9.5:1 compression, stock iron heads (1.94/1.50 valves) milled .015, aluminum intake, small cam (.423I/.442E), 600cfm carb and headers. Like I said, maybe 300hp. Unfortunately, the car is being stored in my dirt floor tractor barn and the mice have chewed some wiring in it. I am planning a shop now and will tear into it again when my shop is complete. I have owned the car for about 16 years now and it is really time to do something with it. As for the motor, I will probably upgrade the came to about .480 lift and upgrade the heads to a better cc and 2.02/1.60 valves. Try for the 350hp mark. I will see if I have some pics to post.
   / Overpowered, overpriced new cars #104
Funny you say that...I have a 283 also but I do not believe I can combine the 2 due to some journal differences. I can't remeber if my 327 is large or small journal. But yes, the destroked 327 is quite quick on the revs. They used this combo I believe in Trans Am racing in the 60s.
   / Overpowered, overpriced new cars #106
Chevy 283 had a 3 7/8" bore and 3" stroke. The 327 had a 4" bore and 3 1/4" stroke. So, the 4" bore with the 3" crank was the "302" not counting any overbore.
Thats how I remember it. Being my 327 is .060 over, no 302 for me!!
   / Overpowered, overpriced new cars #107
Well it is amaZing that those Mouse Chevy engines could put out so much power and not have special steel parts? Like the forged cranks, special head bolts and don't forget the small rod bolts...No Morosso parts used and they were still fun to build and run hard.Now add some of these parts and port the heads and OMG the supper mouse motor was born...Sorry don't speak much Ford?
   / Overpowered, overpriced new cars #108
I was only 13 back then... I remember it was SBC, it was destroked, balanced, and would spin up real fast. Maybe it was a 327 destroked...? Sure made that '37 pickup get with it...
I dunno, I have always been a Mopar guy.
   / Overpowered, overpriced new cars #110
I've rebuilt a number of Ford 289/302 Mustang Motors...
Did one for my brother 30 years ago and it is still going strong 150,000 miles later.
Didn't have much money, so I carefully honed the cylinders in the garage... did send the heads out to be machined... installed a $65 rebuild kit with gaskets, seals, rings and bearings...
Right now, I have a sick 327... actually it has been sick for almost 2 years... I was out driving and heard something let go... a valve rocker backed-off and the push rod jumped out and got mangled... put a new one in $3 but the problem is the rocker stud... so I just parked it.
It's a little disappointing because the 62 Corvette was sold as having a rebuilt engine with hardened valve seats etc... with less than 2,000 miles.
The car is parked because once you start working on a car... it takes up more room...
Case SV280B (A60462)
John Deere 7410 (A53317)
John Deere 7410...
2017 HAMM HD+140I DBL DRUM ROLLER (A60429)
2017 HAMM HD+140I...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
500BBL WHEELED...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
