Any GradeMaster owners here?
   / Any GradeMaster owners here? #51
Lookin' good :thumbsup: ... although it doesn't look like the blade is higher on one side than the other - The space between the top of the blade & the top edge of the member it's mounted on looks to be pretty much the same left & right:
   / Any GradeMaster owners here? #52
I was thinking the same thing. :confused:
It is hard to tell in the picture but there is about a half inch difference. The pic of it full of gravel shows how much migrates to the left or center of the roadway.
I will say this, a 7'er is really almost too big for small one lane driveways because on the return pass it puts the crown way off center. I think a 6'er would have been a better choice, but then again maybe I should just widen the driveway some;)
   / Any GradeMaster owners here? #54
I think that just means you need to tilt the left side up a little more so that the left skid doesn't touch the ground, i.e. that the right skid does skid & only 3 or 4 feet of the blade touches ground, not the entire thing. Does that make sense?
That is, of course, if you're trying to crown your driveway where it has a peak in the middle.
I am having a problem with my side link cylinder leaking down and it makes it hard to hold a angle for any length of time. I think I am going to have to replace it since the shaft is bent a wee bit...but that's another story.
   / Any GradeMaster owners here? #56
$275 for a custom side link for your DK40, 2 1/2" dia cylinder, 4" stroke, 1 1/2" dia rod. Equal tilt to both sides. Flow restrictor, hoses & shipping are additional costs. ;)
I was doing a little research on hyd cylinders w/check valves, but have not decided on one yet.
   / Any GradeMaster owners here? #58
Does either of your rear remotes have a float position? If one of them does, I would skip the side link with the DPOCV. But that may just be me and a few others. ;)
MtnView,
No, I have draft control, but no float. My top cylinder does not leak down, and I am pretty sure the side one is pooched from the bent shaft. I am just hesitant to replace it, then have the same problem since they ain't cheap. So if I want to guarantee against leak down what do you recommend?
2013 FORD F-350 FLATBED (A58214)
2013 FORD F-350...
Forklift (A59228)
Forklift (A59228)
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
18" PIN ON BUCKET (A52707)
18" PIN ON BUCKET...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2000 Kiefer Bilt 20' Gooseneck Trailer (A59814)
2000 Kiefer Bilt...
