New Pole Barn project getting started.
   / New Pole Barn project getting started. #41
Well, it seems like it has taken forever but I think I'm finally ready for trusses. I still need all the Y bracing at the top of the post but have a week to do them as the trusses will be set next weekend. That is the only time I could round up enough people to help. Can't wait to have a roof on as everything else will be easy and I can do it myself. Here are the pics to bring it up to date.
Just a quick question: looking at the pictures I have the impression that the distance between the posts on the long sides are no egual. Can you confirm this? If this is true, was any reason? Anyhow, I can see the last two posts on the long side are quite close each other; any reason or just to reinforce the corners?
Thanks
   / New Pole Barn project getting started. #42
Thanks for the pictures
   / New Pole Barn project getting started. #43
IME, the easiest way to install the trusses is to have the boom truck set them on top of your [finished] frame at delivery!:)
Thanks for posting pics, very nice scenery you have there. I may try a pole barn myself this season- your project is helpful to me.
Hey Rick, I have thought a lot about doing something like that. Just wasn't sure how it would work as my walls are 12' and the trusses are another 12' for a total height of 24'. As the tractors lifting height is some where around 8-9', wasn't sure if I could rig something on the pallet forks or bucket that would make up the 16+ feet that I would need. I am going to have people there to help with the trusses and would hate to have them standing around if I couldn't get my lifting arm to work right. If the barn was a little smaller or with less pitch, I would probably try to rig something like that up. Just not enough experience with something like that to feel confident it will work. I do appreciate the suggestions though. Always looking for the best ways to do things.
Darren
Rogerius, the post are spaced by the truss spacing. The trusses are spaced every 4' in this barn so the post are spaced 8' so that every other truss sits on a post. It just works out that on one end, the posts are 4' apart. I bought the materials from a pole barn company and they give you engineered drawings as part of the price. Hope this explains it for you, good question though.
Darren
Rockshaft, I agree with setting the trusses that way but they delivered my trusse on a truck in which the trusses were standing and they basically push them off the truck. I thought this was kind of strange and they even broke the two end trusses. They brought me two new ones two days later but it seemed not the best ideal for unloading. I think I am going to hire a guy with a boom truck for $100.00/hr to set the trusses. I could rent an all terrain fork lift, 36' buy then I would have to pick them up, drive them into the building, and put them in place. The boom truck can set up, boom to where the trusses lie, lift them up over the wall and swing them into place. Seems like the best way for me at this point.
Glad if this helps in your pole barn in any way. I am learning as I go so if there is anything I can help you with, feel free to ask.
   / New Pole Barn project getting started. #46
Preparing the drive way and then the gravel. The crusher run was more difficult then I thought it would be. They could only back up to where the stone ended and then dump the whole load. Trying to spread the pile was a pain as the stone wanted to get wider and wider as you push. The stone went out wider then the driveway fabric which is all mud and soft. So when the next truck came and got off to the side a little, he just sank in and got stuck. Had to pull at least three trucks out with the dozer. About 300 tons of crusher run in all and that included the pole barn. Alot of money for a driveway. This time of year is not the best for drives as the ground is so soft. I hope this driveway will hold up. The fabric will help alot but how much? Anyway, the trusses came and are now down next to the site of the barn. Hopefully this weekend I can get some post in the ground.
I'm planning a post building for this summer. Can you describe the layers you used for your driveway and for under the concrete slab?
Also, are you going to have electric door operators for your overhead doors? What band are you going to use?
Thanks.
Thanks.
For the driveway and barn, I just dug off the topsoil ( top 6 - 8" ), laid down driveway fabric and then about 6-8" of crusher run. I needed the driveway fabric because of the soil conditions. Why the ground is dry here, it is very hard, but when wet, it is very soft. I didn't want all my stone sinking every time it rained and creating pot holes. The fabric works great for keeping everything solid. Inside the barn, to level it up, I had to dig down about 2' at one end and build the other end up about 2'. I used the driveway fabric in there also. Then put down the crusher run. I will have to compact the barn gravel before pouring concrete. I am going to have an electric overhead door and as I don't know a whole lot about them ( quality wise), I will probably get a door from Wayne- dalton or some such place and get a commercial grade opener. Still open for suggestions on the overhead door though.
   / New Pole Barn project getting started. #48
What thicknesses of crusher run, gravel and concrete are you planning for inside?
   / New Pole Barn project getting started. #49
Last week when I was at the JD dealer I noticed that they were using a boom pole mounted on the front loader of tractor to lift mowers up to work on them. I was thinking that if you could make something like that it could be used to lift a truss up. I am not a welder so I do not know how hard it would be to make it. Just an idea.
Rick
When I did mine, I already had a round bale spear that mounted on my front end loader bucket. I found a length of pipe that I used as a sleeve to slide over the spear to make it longer. With a short lengh of chain wrapped around the top of the truss and hooked to the end of the pipe, it worked well. I'd have a rope with a person on one end of the truss to steady/guide it. The main thing is to make sure you don't hit or bump the truss hard enough that the hook would jump out of the pipe. It helped that the tractor was a larger 90HP model and the loader has above average reach. Top plate of walls is 14 feet with the trusses another ~ 8 feet (from memory). Good luck.
I put between 8" and 12" of crusher run inside. I used it to final level the inside. I'm not sure on thickness of concrete yet. Standard around here is 4" and I got a price of $6500 to pour and finish it. I might go with 6" of concrete. Trying to keep costs down but would hate to have concrete not hold up.
2008 CATERPILLAR 272C SKID STEER (A52705)
2008 CATERPILLAR...
2121 (A51244)
2121 (A51244)
2022 John Deere 317G Track Loader (A53485)
2022 John Deere...
2014 Ford Explorer SUV (A53424)
2014 Ford Explorer...
Krause Dominator 4850-18ft (A57024)
Krause Dominator...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
