Northern Tool Pto Gen
   / Northern Tool Pto Gen
I picked up the generator and now I need a mount. I see 3pt carryall for a $100. Are these sufficient for the gen? I realize that I will have to make a mounting board for the gen. Are they strong enough for the twisting force? Thank
   / Northern Tool Pto Gen #22
I can't vouch for all of them, but I should think most would be strong enough.
   / Northern Tool Pto Gen #23
I've got the 7500W NT generator. Bolted a piece of 3/4 inch plywood to a carryall bought at TSC then bolted the generator to that. It works great. You should be able to get a drive shaft for it at TSC.
   / Northern Tool Pto Gen #25
I just got some more info on the unit. It is 4 years old never used. No carrier or shaft. I can get it for$550. Is this a good deal?
A couple hundred foot pounds max running torque. Not so much. You always want to spin/start it up smoothly tho in any case to avoid a significantly higher peak during acceleration . I have the lightest duty driveshaft made on mine so Im naturally careful on startup.
larry
I am going to order the carryall and the shaft at the same time. Any idea what length shaft I should get?
   / Northern Tool Pto Gen #27
Sketch up your situation, and do the math...or buy one too long and know you have to cut it...your choice.
I did the sketch and the math, and I found I needed to cut a little, but I knew it in advance. I may have saved a buck or two buying the shaft closest in length to my needs to begin with though.
My tractor is a BX, so getting pretty persnickety pays off when you are smallish to begin with. My genny is bolted to its custom pallet, and obviously I want the genny stored in prime dry clean real estate, so optimizing it's storage size was important. My pallet sits on a dolly so I can roll it around, etc.
I don't know your scale. My scale, it's tough...but I can pick up my carryall with my bare hands and insert it into the pallet if I want to. :)
   / Northern Tool Pto Gen #28
i mentioned EXACTLY that in my post.
i used fence corall boards to make a deck onthe carryall.. then lag bolted and safety braid wired the pallate to it that the pto gen came on.
works fine.
   / Northern Tool Pto Gen #29
fwtw My gen is trailer mounted so if needed I can throw a stick welder on and fix things around the property etc food for thought. Nice find btw hope she works as expected! :thumbsup:
   / Northern Tool Pto Gen #30
yep.. that's a good use. the corner of my pallate has room for my stick welder as well.
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A56438)
2017 Yale GLC050VX...
2000 ITASCA SUNCRUISER 37G CLASS A RV (A58214)
2000 ITASCA...
2017 Nissan Altima 4 door (A56438)
2017 Nissan Altima...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
2021 KOMATSU PC490LCI-11 EXCAVATOR (A60429)
2021 KOMATSU...
